Autor Thema: Update 9. September 2011 (Linux)  (Gelesen 17610 mal)
« am: Februar 07, 2011, 10:45:28 Nachmittag »
Version: http://www.sundtek.de/media/sundtek_installer_110909.1537.sh
* added DVB_netTuner_starten.sh and DVB_netTuner_autostart.sh (16. April 2011)
* Added support for alternative RC5 remote controls (19/20. April 2011)
* Updated analogTV of first ATSC generation (22. April 2011)
* remote control mechanism is now managed per device (23. April 2011)
* Updated delay for automatic loading of network driver instances (23. April 2011)
* Updated RC5 support for 8 bit remote controls (25. April 2011)
* added WSS demodulation support in the driver:
      WSS_4_3_FULL
       WSS_14_9_LETTERBOX_CENTRE
       WSS_14_9_LETTERBOX_TOP
       WSS_16_9_LETTERBOX_CENTRE
       WSS_16_9_LETTERBOX_TOP
       WSS_16_9_LETTERBOX_DEEPER
       WSS_14_9_FULL_HEIGHT_4_3
       WSS_16_9_FULL_HEIGHT_16_9
       WSS_UNABLE_TO_DEMODULATE   (wurde ab dem 28. April hinzugefügt)
driver will run a script which is defined in /etc/sundtek.conf keyword wss_callback (27. April 2011)
* added wss timeout option in case WSS could not be demodulated wss_demodulation_timeout=[value in milliseconds]. (28. April 2011)
* Updated RC5 support to 16 bit (28. April 2011)
* Updated DVB-S2 QPSK support (28. April 2011)
* added C-Band option (28. April 2011)
* added support for devices which won't require active AC adapters for active multiswitches (25. May 2011)
* added support to read the signal statistics (value in ESNO) (25. May 2011)
* added support to change transfer type between Bulk and Iso  (25. May 2011)
* updated initialization of S2 dongle - fixes red light when connecting the stick (30. May 2011)
* added option to set voltage to 0V (30. May 2011)
* added option to initially set the analogTV audio volume (valid range 0 - 127), eg. in /etc/sundtek.conf volume=127 (customerrequest, 15. June 2011)
* updated driver to show how many clients are connected to a certain device via network (customerrequest, 15. June 2011)
* updated devicedetection in order to support bugged linux kernelversions (customerrequest, 15. June 2011)
* Update OpenPLI System support (customerrequest, 20. June 2011)
* Update DMX_SET_BUFFER_SIZE, returnvalue is now 0 (customerrequest, 22. June 2011)
* Update DVB-S/S2 Demodulator/Tuner driver including firmware (28. June 2011)
- standby only requires a few milliseconds with new firmware (28. June 2011)
- Diseqc and tone won't be resetted after standby (28. June 2011)
* support for Microsoft Mediacenter remote controls, RC6 Mode 6A (customerrequest, 29. June 2011)
* Update RC6 Support, mce_rc6 can be loaded directly (customerrequest, 30. Juni 2011)
/opt/bin/mediaclient -s 3
/opt/bin/mediaclient -l
id   protocol name
0 .. NEC IR Protocol
1 .. RC5 IR Protocol
2 .. RC6 Mode0 IR Protocol
3 .. RC6 Mode6A IR Protocol (active)
/opt/bin/mediaclient --setrcmap=/lib/udev/rc_keymaps/rc6_mce
* Fix ATSC (USB Stick Version 1) driverupdate for new firmware (30. June 2011)
* Update OpenPLI Support for Dreambox (customerrequest, 30. June 2011)
* Support Clarke Tech ET5000 (customerrequest, 2. Juli 2011)
* AnalogTV Plugin Support (customerrequest, 26. Juli 2011)
(Add support for external plugins to support certain new optional features eg. encoding).
* Pluginsupport für AnalogTV um die Funktionalität des Treibers zu erweitern (26. Juli 2011).
* Update DVB-S/S2 Support for upcoming devices for northern europe (z.B. Thor5) (7. August 2011)
* Update Clarke Tech ET9000 (new Image) support (customerrequest, 7. August 2011)
* Update ReadyNAS Support (customerrequest, 7. August 2011)
* Update Clarke Tech/XTrend ET5000/OpenPLI 2.1 (new Image) Support (customerrequest, 8. August 2011)
* Support for usb_transaction_delay in /etc/sundtek.conf for throtteling the USB device setup (8. August 2011)
* fix short analogTV audio clicking issue within the first second (11. August 2011)
* Fix WSS Unable to demodulate when option is not set (11. August 2011)
* fix memory leak in network support (customerrequest, 19. August 2011)
* USB 1.1 Support for Bulk Modus for DVB-C und DVB-T, especially for Embedded Boards (customerrequest, 19. August 2011)
* enhanced video stabilization for new AnalogTV devices (22. August 2011)
* Further updates for new DVB-S/S2 devices for northern europe  (24. August 2011)
* lowered remote control key repeat rate (24. August 2011)
* Updated latest Kaffeine version to be able to handle the driver with KDE 4.6  (24. August 2011)
* DVB-S/S2 Option for enforcing 0V - tone OFF (29. August 2011)
* Updated device notification support (29. August 2011)
* Fix VLC support for new analogTV plugin API for custom encoders (30. August 2011)
* moved analogTV 2px to the left (31. August 2011)
* --readsignal also prints the MER (customerrequest, 1. September 2011)
* added vtuner_skip0 and vtuner_skip1 Option to /etc/sundtek.conf (1. September 2011)
* Dreambox scripts are trying to detect sundtek devices automatically (1. September 2011)
* enhanced Dreambox Devicemanagement (1. September 2011)
* libmcsimple is not linked against libmediaclient anymore (yaVDR developerfeedback, 1. September 2011)
* Dreambox Devicemanagement Dreambox bugfix (2. September 2011)
* Dreambox, allow support for disabling the PID filter (8. September 2011)
script example:
#!/bin/bash
su username -s /usr/bin/tvtime-command TOGGLE_ASPECT
« Letzte Änderung: Oktober 15, 2011, 06:56:41 Nachmittag von Sundtek »
Re:Update 8. September 2011 (Linux)
« Antwort #1 am: September 08, 2011, 09:03:53 Vormittag »
pushing up
Alfafa
Re:Update 9. September 2011 (Linux)
« Antwort #2 am: Oktober 15, 2011, 05:48:23 Nachmittag »
Pleasy make a correct download link :)
« Antwort #3 am: Oktober 15, 2011, 07:00:55 Nachmittag »
already updated thanks, please note it's always recommended to use the Beta driver as it will become the next stable driver after some time anyway.
