Autor Thema: VU+ Solo Support  (Gelesen 10968 mal)
VU+ Solo Support
« am: Dezember 01, 2010, 03:20:18 Nachmittag »
VU+ Solo wird seit 1. Dezember ebenfalls unterstützt.
/sundtek_installer_101201.sh
Legal notice:
Nutzungsbedingungen:
Wollen Sie fortfahren [J/N]:
y
unpacking...
checking system... VU+ Solo detected
installing...
Starting driver...
switching off loglevel
done.
Vielen Dank an unsere Supporter und VU+ welche dies getestet haben.
-> Installationsanleitung
irishchris
Re:VU+ Solo Support
« Antwort #1 am: Dezember 22, 2010, 01:09:32 Nachmittag »
hi
my question is if you have the sundtek media pro tv tuner in a vu+ duo - is it possible to stream over network to a vu+ solo as i see a guide for doing it for pc over network
many thanks
Re:VU+ Solo Support
« Antwort #2 am: Dezember 22, 2010, 03:34:52 Nachmittag »
We will test this in a few days.
Just as information, Sundtek will mostly close until 28th december. Some voluntary support might be given during this time.
irishchris
Re:VU+ Solo Support
« Antwort #3 am: Januar 25, 2011, 07:46:29 Nachmittag »
any more info / instructions on this??
Re:VU+ Solo Support
« Antwort #4 am: Januar 25, 2011, 11:24:41 Nachmittag »
we tested this good news is that Network mode works quite well.
First of all set up a server according to our network documentation:
http://support.sundtek.com/index.php/topic,179.0.html
VU+ Setup:
1. connect to your VU+ using telnet and run following commands:
cd /tmp
wget http://www.sundtek.de/media/sundtek_installer.sh
chmod 777 sundtek_installer.sh
./sundtek_installer.sh
 192.168.1.14     | 0   | Sundtek MediaTV Pro  | 2     | DVB-T, DVB-C | 0110118165610
 192.168.1.13     | 0   | Sundtek MediaTV Pro  | 2     | DVB-T, DVB-C | 0101231110643
-  2 IPTV server found -------------------------------------------------------
echo "REMOTE_IPTV_SERVER=192.168.1.14" > /etc/sundtek.net
cd /usr/script
./DVB_C_netTuner_autostart.sh
./DVB_C_netTuner_starten.sh
