Autor Thema: Sundtek MediaTV Pro and OpenPLI  (Gelesen 10249 mal)
audits
« am: Oktober 19, 2010, 03:39:03 Nachmittag »
Hi
I am unable to install a Sundtek MediaTV Pro (DVB-CT) on a DM800 with OpenPLi.
I get these errors:
/opt/bin/mediaclient -e
/opt/bin/mediaclient: error while loading shared libraries: unexpected reloc type 0x7e
/usr/script/DVB_Tuner_Info.sh
DVB Tuner info
/usr/sundtek/mediaclient: error while loading shared libraries: unexpected reloc type 0x7e
NIM Socket 0:
        Type: DVB-S2
        Has_Outputs: yes
        Frontend_Device: 0
 /usr/script/DVB_T_Tuner_starten.sh
DVB-T Tuner start
Segmentation fault
Enigma restart
How can I fix this?
Re:Sundtek MediaTV Pro and OpenPLI
« Antwort #1 am: Oktober 19, 2010, 04:14:20 Nachmittag »
We never tested OpenPLI on a DM800, in order to fix this issue please add "sundtek" in skype or join our online chat.
Please note our support will be available again from Wednesday - we are currently all finalizing DVB-S/S2 support today.
On a dreambox by default we only install drivers for the Gemini Image, however as you noticed the mipsel2 build in the driver seems to work for it but we need to modify the installer to set up the correct driver on it.
« Letzte Änderung: Oktober 20, 2010, 04:41:30 Vormittag von Sundtek »
audits
« Antwort #2 am: Oktober 20, 2010, 11:24:19 Nachmittag »
Ok, I got it working with the mipsel2 installer.tar.gz and usbkhelper-dm800.ko
Thanks
