Autor Thema: Installation on a Dreambox settopbox  (Gelesen 126778 mal)
matt
Re:Installation on a Dreambox settopbox
« Antwort #15 am: September 02, 2011, 11:37:51 Vormittag »
I have DM800HD se. I use the newest firmware from Newnigma2.
If I buy DVB-S card, will that work that I can record one channel and watch another one?
The How-To is for DVB-C and DVB-T, but I can see someone tried to run DVB-S too...?
« Antwort #16 am: September 02, 2011, 12:07:04 Nachmittag »
We tested DVB-S/S2 it works with the Dreambox and various other settopboxes.
It can be used to extend the settopboxes to dual or triple DVB-S/S2 tuners
dwaas
« Antwort #17 am: November 12, 2011, 01:27:50 Nachmittag »
Hello all,
dreambox DM800Se with usb pro stick is very slow with zapping, with every channel spinner in the screen of the television  :-\
Flashed the receiver with the latest Pli and drivers for my sundtek stick
Any idea what i can do to let it work how it did before ?
« Antwort #18 am: November 13, 2011, 03:51:42 Vormittag »
Did you replug the USB device after installing the latest driver?
dwaas
« Antwort #19 am: November 13, 2011, 12:46:19 Nachmittag »
replug ? no i did not.....
so if i understand - unplug the usb device and then install the latest driver with the sundtek plugin before replug the device ?
i will try this, thanx  ;)
« Antwort #20 am: November 14, 2011, 01:02:08 Vormittag »
With the latest driver there was a firmware update introduced, this requires to replug the device after installing the driver.
dwaas
« Antwort #21 am: November 15, 2011, 05:58:11 Nachmittag »
did not work for me here
unplug the device and installed the driver -> reboot de dreambox and plugged the Sundtek stick back in.
the stick works but very slow .....
« Antwort #22 am: November 15, 2011, 10:48:42 Nachmittag »
If you can contact us via Skype (sundtek) we might figure out what's wrong with your setup.
dwaas
« Antwort #23 am: November 16, 2011, 02:14:29 Nachmittag »
I will try that at the end of next week  :)
thanx for your reply  ;)
RonH
« Antwort #24 am: März 26, 2012, 11:32:28 Vormittag »
Last weekend I've tried to install the "Sundtek MediaTV Pro (DVB-CT, Radio, AnalogTV)" on a VU+Duo with OpenPli 2.1 with the last updates. I've used your installation manual (see link). The VU+Duo sees the tuner, but thinks it's a DVB-T tuner. But I need the DVB-C tuner.
What am I doing wrong?
« Antwort #25 am: März 26, 2012, 11:38:11 Vormittag »
Did you run the DVB_C_Tuner_starten.sh script?
RonH
« Antwort #26 am: März 26, 2012, 11:45:56 Vormittag »
I'm starting to doubt wether I ran the DVB_T_Tuner by mistake. I've run the DVB_Tuner_kein_autostart.sh now, followed by DVB_C_Tuner_autostart.sh
I'm not at home at the moment (Just could make an ssh shell to the box from work). I'll give it a try when I'm back home, and let you know.
Thanks for the quick support!
RonH
« Antwort #27 am: März 26, 2012, 12:44:05 Nachmittag »
I've run the DVB_Tuner_kein_autostart.sh to clear the DVB-T tuner autostart. Then I ran the DVB_C_Tuner_autostart.sh to enable the DVB-C tuner. But after a reboot the box still says it has: TunerC: Sundtek MediaTV Digital Home (USDVB-T (DVB-T)
And not DVB-C ... :(
Do I really have to powercycle the box to get it right?
RonH
« Antwort #28 am: März 26, 2012, 01:54:24 Nachmittag »
It works now. I also had a thread on the OpenPli forum and there they adviced me to make a sundtek.conf in the /etc folder. And the sundtek.conf looks like this:
[serial_sundtek]
initial_dvb_mode=DVBC
dreambox_support_fe1=on
The serial can be retrieved by: /opt/bin/mediaclient -e
And now the VU+Duo sees the tuner as a DVB-C tuner!
« Antwort #29 am: März 26, 2012, 02:35:26 Nachmittag »
only means to autostart the tuner after the reboot
means immediately start E2 with DVB-C tuner support
In case you started the first script only it's understandable that nothing happened since it just deploys the autostart scripts
