Autor Thema: Installation on a Dreambox settopbox  (Gelesen 127088 mal)
RonH
Re:Installation on a Dreambox settopbox
« Antwort #30 am: März 26, 2012, 02:41:00 Nachmittag »
Ok...
Is it wise to run the DVB_C_Tuner_starten.sh?
Or can I leave it this way with the Sundtek.conf file?
DVB_C_Tuner_autostart.sh
only means to autostart the tuner after the reboot
means immediately start E2 with DVB-C tuner support
In case you started the first script only it's understandable that nothing happened since it just deploys the autostart scripts
« Antwort #31 am: März 26, 2012, 03:18:09 Nachmittag »
first of all you need to ensure that the driver is started automatically when you reboot your settopbox
-> you already did this by running DVB_C_Tuner_autostart.sh
The configurationfile (sundtek.conf) is usually only useful for setups which use 2 USB tuners, but it can also be used for single tuners.
The configurationfile has a higher priority than the *_starten.sh scripts.
In the background both things, the configfile or the scripts do the same (the scripts DVB_*_starten.sh is usually easier for customers)
So either way is correct, the configfile is just more difficult for the enduser.
RonH
« Antwort #32 am: März 26, 2012, 03:42:44 Nachmittag »
Very clear :)
Thanks for all your quick support, wish all people were like this!
RonH
« Antwort #33 am: März 27, 2012, 09:00:55 Vormittag »
As I said, everything is working now.
But there is one fault with the Sundtek in combination with OpenPli. I can switch from DVB-T to DVB-C and back to DVB-T whithout any problems. But if I want to go back to DVB-C once more, it stops working. Only DVB-T will work from then on. The Sundtek doesn't do anything anymore, and says it has 0% signal.
Only a powercycle will resolve that issue, untill you switch from DVB-T to DVB-C for the second time. I guess it's a driver problem. I hope you can reproduce this problem, and resolve this. (it's a common problem with Sundtek if you search the internet)
Pimsat
« Antwort #34 am: März 27, 2012, 10:30:18 Vormittag »
DVB-T should be DVB-S?
The problem is occurring when switching between DVB-S and DVB-C  :)
I started a new topic: http://support.sundtek.com/index.php/topic,844.0.html because this problem is with several types of E2 boxes.
« Letzte Änderung: März 27, 2012, 10:38:27 Vormittag von Pimsat »
polkwan
« Antwort #35 am: Mai 17, 2012, 12:44:52 Nachmittag »
Here is my problem:
I installed properly the dongle with the right script as explained in the beginning of this topic. Everything went fine but it doesn't want to work...
- In the end of the installation, if i chose the dvb-c start-script, the dreambox freezes and it's impossible to reboot it but manually. So, I don't have choice but to chose the "autostart-script". There is no problem. After a reboot, the Dreambox sees the device and i can enter the menu to set it up. BUT--->
-> If I go in the menu to scan services, I get this failure : "ERREUR - échec lors de l'analyse (error starting..."
-> I read that I shouldn't do an automatic scan but I did it previously (some months ago) and I worked fine. Anyway, I decide to scan manually but once again, it doesn't work and I have to reboot the Dreambox manually one more time.
I'm totally stacked with that problem. I can't get any channel. Would anybody help me ?  :'(
Information:
Dreambox 8000 HD PVR
Latest LT Image
Boot Loader #84
Cable Operator : VOO
Country : Belgium
« Antwort #36 am: Mai 17, 2012, 01:18:31 Nachmittag »
Which image do you use?
polkwan
« Antwort #38 am: Mai 17, 2012, 04:27:46 Nachmittag »
we massively updated the drivers recently, however we need to do some fine-tuning still
Advantages are:
* faster zapping
* better stability
* overall better to improve for us
Disadvantage for the short term:
* we need to check the driver with all the STB systems again
* for short term some compatibility problems can arise of course.
« Antwort #39 am: Mai 17, 2012, 05:21:54 Nachmittag »
We updated the driver for Merlin, we also tested LT now and it also works?
However we tested it with a DM800SE, in case you still have an issue with it please contact us via chat (Skype - sundtek) or http://chat.sundtek.de (we prefer Skype Chat)
polkwan
« Antwort #40 am: Mai 17, 2012, 05:52:23 Nachmittag »
Thank you for your active support.
May I contact you any day ?
« Antwort #41 am: Mai 17, 2012, 06:05:52 Nachmittag »
Sure.
« Antwort #42 am: Mai 18, 2012, 03:03:46 Nachmittag »
Driver is updated and should fix that problem now.
RonH
« Antwort #43 am: Juni 15, 2012, 06:08:26 Nachmittag »
Hi Markus,
It has been a while ago, but now I've purchased a second adapter. I've followed the instructions, and my VU+Duo sees the 2 adapters, very good! But...
When I reboot, I only see one tuner, and have to do the lines:
/opt/bin/mediaclient --enabledreambox=/dev/dvb/adapter1/frontend0
/opt/bin/mediaclient --enabledreambox=/dev/dvb/adapter2/frontend0
Again, manually.
How do I force this will happen automatically every reboot?
« Antwort #44 am: Juni 15, 2012, 06:58:54 Nachmittag »
For the dreambox please use the "sundtek control center" Plugin, it should be available in the feed.
