Autor Thema: Installation on a Dreambox settopbox  (Gelesen 127361 mal)
« am: August 11, 2010, 04:20:08 Nachmittag »
In order to set install the driver on Settopboxes we provide some easy tools for Windows and Mac.
All you need is the ip address and the password (if set) of your settopbox.
Documentation:
http://sundtek.de/support/Sundtek_MediaTV_setting_guide.pdf
Windows:
http://sundtek.de/media/ssi.zip
Mac:
« Letzte Änderung: Mai 28, 2016, 11:52:22 Vormittag von Sundtek »
Re:Installation on a Dreambox settopbox
« Antwort #1 am: September 15, 2010, 11:19:05 Vormittag »
This howto is for people who want to use more than 1 USB DVB Sticks
In order to set up more than 1 USB DVB-C Stick please use following commands:
root@bm750:~# /opt/bin/mediaclient -e
device 0: [Sundtek SkyTV Ultimate]  DVB-S/S2
device 1: [ Sundtek MediaTV Pro]  DVB-C, DVB-T, ANALOG-TV, FM-RADIO, REMOTE-CONTROL, OSS-AUDIO, RDS
     DVR: /dev/dvb/adapter2/dvr0
     DMX: /dev/dvb/adapter2/demux0
$ /opt/bin/mediaclient --enabledreambox=/dev/dvb/adapter1/frontend0
$ /opt/bin/mediaclient --enabledreambox=/dev/dvb/adapter2/frontend0
verify if the tuners are loaded:
$ cat /proc/bus/nim_sockets
NIM Socket 0:
        Type: DVB-S2
        Name: BCM7335 DVB-S2 NIM (internal)
NIM Socket 1:
        Type: DVB-S2
NIM Socket 2:
        Type: DVB-S2
        Name: Sundtek SkyTV Ultimate (USB)
NIM Socket 3:
        Type: DVB-C
        Name: Sundtek MediaTV Pro (USB)
restart enigma:
$ killall enigma2
please not that not all Dreambox systems support multiple USB DVB-C devices, some VU+ systems also don't support DVB-C yet -- in case of VU+ the PLi Firmware Image is currently known to support USB DVB-C tuners, VTI is in progress but this is out of our hands
« Letzte Änderung: September 15, 2010, 04:01:35 Nachmittag von Sundtek »
dwaas
« Antwort #2 am: November 05, 2010, 11:31:27 Vormittag »
when installing i get a failure,
segmentation fault
/usr/sundtek/mediaclient
error while loading shared libraries : unexpected reloc type 0x7E
is there a solution for this problem, the dm800 can't find the usb C tuner at this moment
« Antwort #3 am: November 05, 2010, 12:32:31 Nachmittag »
Are you using openPLI on a dreambox?
Please follow up in following thread:
http://support.sundtek.com/index.php/topic,348.msg2125.html#new
hannhimhe
« Antwort #4 am: Dezember 09, 2010, 03:50:36 Vormittag »
Does this work with both the MediaTV Pro and MediaTV Digital Home tuners? What about the SkyTV Ultimate tuner if one would like an extra satellite tuner?
« Antwort #5 am: Dezember 09, 2010, 03:59:11 Vormittag »
SkyTV is upcoming soon, it is supposed to work with the Dreambox System. A software engineer from Dream Multimedia is also cooperating with this.
MediaTV Pro and MediaTV Digital Home tuners are supported.
Latest Reports:
* DM800 works (good support depends on the reencoding of the TV channels of your provider, the old DM800 is picky about that).
* DM8000 works again with the latest drivers
* DM500HD works with network mode
* DM800SE the dream Multimedia Software engineer reported it works another customer reported that it doesn't (so this software engineer is checking it again with the customer).
« Letzte Änderung: Dezember 15, 2010, 01:11:25 Vormittag von Sundtek »
wmthwat
« Antwort #6 am: April 18, 2011, 10:58:19 Nachmittag »
Hi
I have tried to install a DVB_S2 on a DM800HD-S and have som problems.
The installation proceeds as the instruction but it don't create the catalog /dev/dvb/adapter1
When I try to start the Suntek DVB_S2_Tuner Enigma craches  :'(
Here are some screenshots:
root@dm800:/tmp# ./sundtek_installer_development.sh
Busybox installation
Legal notice:
Nutzungsbedingungen:
das System oder die angebotenen Dateien entstehen k├Ânnen.
Wollen Sie fortfahren [J/N]:
j
unpacking...
checking system... testing libc OK 2.3.90
MIPSel (old libc) System detected
installing...
Using /dev/misc/vtuner0 interface
Starting driver...
done.
root@dm800:/tmp#
root@dm800:/usr/script# ./DVB_S2_Tuner_starten.sh
DVB-S/S2 Tuner start
switching off loglevel
unable to open /dev/dvb/adapter1/frontend0
Enigma restart
root@dm800:/usr/script# ./DVB_Tuner_Info.sh
DVB Tuner info
NIM Socket 0:
         Type: DVB-S2
         Has_Outputs: yes
root@dm800:/usr/script# /opt/bin/mediaclient -e
Could it be that you have any idea why?
wmthwat
« Antwort #7 am: April 18, 2011, 11:01:14 Nachmittag »
One more thing...
I'm using Gemini 4.7 on this DM800
Thanks in advance!
« Antwort #8 am: April 19, 2011, 12:31:37 Vormittag »
that's strange, what does "lsusb" show up, or "/usr/sundtek/mediaclient --lsusb"
wmthwat
« Antwort #9 am: April 20, 2011, 09:36:22 Nachmittag »
-sh: /usr/sundtek/mediaclient: not found
root@dm800:/usr/sundtek# ls
khelper-src.tar.gz  kpatch              sun_dvb.sh
I will upgrade the box to Gemini 5.10 tomorrow and try to install the USB tuner again after that.
It could be that some drivers are upgraded in the latest release...
I will let you know the result.
« Antwort #10 am: April 21, 2011, 02:14:19 Nachmittag »
Our engineers are currently in Taiwan again for one month to verify new devices. So the answer will be a little be delayed for such questions.
wmthwat
« Antwort #11 am: April 22, 2011, 02:03:40 Nachmittag »
I have now upgraded my DM800 from Gemini 4.7 to 5.1 (second stage loader 75 to 76).
I'm very pleased to tell you that my DVB_S2_Tuner now works  :D
During the installation detected that it was a Dreambox 800/800se.
When I tried beforde the upgrade it said "MIPSel (old libc) System detected"
Thanks for your support!
« Antwort #12 am: April 22, 2011, 04:15:27 Nachmittag »
It was probably too old and missing the dualtuner support so it used the generic drivers. But good to know maybe we should add a version-check and tell the user about that in the future.
Alesm
« Antwort #13 am: Mai 27, 2011, 11:00:28 Vormittag »
Hello, tried to install the driver. I can tune all DVB-C channels, but I can see the free channels only. Does this tuner works with CI module with smart card to decrypt channels?
I have ClarkTech ET9000, PLI firmware, SMiT Conax chipset pairing CAM, UPC smart card (Czech). Thank you. Ales
« Antwort #14 am: Mai 27, 2011, 12:41:58 Nachmittag »
Hello,
this works with some settopboxes (VU+ was working on this some time ago), if possible can you post this in the clarketech forum?
Technically it should be possible to use it of course.
This is a little bit out of our hands since this is done in the proprietary clarketech drivers.
