Autor Thema: Linux Installation DVB-S, DVB-S2  (Gelesen 201003 mal)
Re:Sundtek SkyTV Ultimate - DVB-S, DVB-S2 Installation (Linux)
« Antwort #30 am: November 17, 2010, 03:24:03 Vormittag »
We are doing, and those who received the devices also know what's going on due the information sheet. All DVB-S/S2 customers are supposed to have their devices - if some did not arrive yet there's something wrong (as far as I've seen some packages also came back during the last few days although they are in the working queue right now here). I can also imagine that some didn't get picked up at the right time.
However the final stage of DVB-S/S2 is coming soon anyway again, everyone will receive his device and will be happy with it in the end (even though our start was terrible with it)
« Letzte Änderung: November 17, 2010, 03:26:18 Vormittag von Sundtek »
elektron
« Antwort #31 am: November 17, 2010, 10:53:07 Nachmittag »
ich habe meinen DVBS/S2 Stick inzwischen erhalten.
Problem ist, dass er nicht vernünftig funktioniert.
Beim Sendersuchlauf erhalte ich ständig die Meldung:
w_scan -o7 -fs -s S19E2 -D0c DE > /var/lib/vdr/channels.conf
w_scan version 20100316 (compiled for DVB API 5.1)
using settings for 19.2 east Astra 1F/1G/1H/1KR/1L
frontend_type DVB-S, channellist 6
output format vdr-1.7
        /dev/dvb/adapter0/frontend0 -> DVB-S "Sundtek DVB-S/S2": very good :-))
Using DVB-S frontend (adapter /dev/dvb/adapter0/frontend0)
Using DVB API 5.1
frontend Sundtek DVB-S/S2 supports
INVERSION_AUTO
DVB-S
DVB-S2
using LNB "UNIVERSAL"
(time: 00:00)
(time: 00:03)
(time: 00:06) (time: 00:13) signal ok:
        S  f = 10744 kHz H SR = 22000  5/6 0,35  QPSK
Info: NIT(actual) filter timeout
(time: 00:26)
(time: 00:29)
(time: 00:36) (time: 00:39) signal ok:
        S  f = 10788 kHz V SR = 22000  5/6 0,35  QPSK
(time: 00:52)
(time: 00:59)
(time: 01:02) ^C
ERROR: interrupted by SIGINT, dumping partial result...
dumping lists (0 services)
Done.
Ich habe auch mal channels.conf aus dem Netz runtergeladen, dann sehe ich zumindest bei zwei drei Sendern einen EPG, aber so recht will das nicht.
Hat das schonmal einer zum Laufen bekommen???
Viele Grüße
Michael
_____________________________________________________
just a view word in english:
I've received a Sky-Ultimate Stick, but ich have problems with the Channelscan...
Someone give me a Hint?
Michael712
« Antwort #32 am: November 17, 2010, 11:06:56 Nachmittag »
Also mein Stick läuft soweit, bis auf die Tatsache mit dem Senderwechsel, was aber auch auf dem zettel stand.
Ich vermute, dass dadurch der Suchlauf auch nicht richtig klappt. Mit kaffeine hab ich jedenfalls bei den ersten Versuchen nur mäßigen Erfolg gehabt (nur so Sender wie Bibel TV gefunden).
Was geklappt hat: Nacheinander die Frequenzen der Transponder in scanfile.dvb eingetragen, wovon ich Programme empfangen möchte:
#Ausschnitt aus .kde4/share/apps/kaffeine/scanfile.dvb
[dvb-s/Astra-19.2E]
S 12266000 H 27500000 3/4
S 12187500 H 27500000 3/4
S 12544000 H 22000000 5/6
S 12109500 H 27500000 3/4
S2 11361700 H 22000000 2/3 AUTO AUTO
Der erste Eintrag in der Liste klappt auf jeden Fall immer, danach kann das Einstellen der Frequenz fehlschlagen. Also einfach die gefundenen Sender in die Programmliste aufnehmen, kaffeine schließen, Reihenfolge der Frequenzen tauschen, und wieder Scannen.
(die frequenzen hab ich übrigens einfach von den Senderwebseiten übernommen; die letzte ist z.B. von ARD/ZDF/Arte HD)
« Antwort #33 am: November 18, 2010, 09:16:42 Vormittag »
Was für einen Treiber verwenden sie?
Die endgültigen Geräte durchlaufen derzeit gerade QA-Testing.
elektron
« Antwort #34 am: November 18, 2010, 09:29:21 Vormittag »
wie finde ich am einfachsten die Treiberversion raus?
Ich habe den Treiber wie auf Ihrer Website beschrieben per Shell-Script instaliert...
« Antwort #35 am: November 18, 2010, 07:21:53 Nachmittag »
Siehe:
http://www.sundtek.de/media
http://www.sundtek.de/media/sundtek_installer_development.sh zeigt immer auf den aktuellen Treiber
Mit /opt/bin/mediaclient --build wird das jeweilige Build Datum angezeigt
elektron
« Antwort #36 am: November 19, 2010, 08:35:29 Vormittag »
Hallo
Für die Installation habe ich genau dieses Shellscript verwendet.
Datum von Mediaclient: 17.Nov 21.56
mjoern
« Antwort #37 am: Dezember 13, 2010, 02:10:29 Nachmittag »
ich habe ebenfalls einen DVB-S2 USB-Stick und bekomme leider keinen Sendersuchlauf gestartet.
Weder mit Kaffeine oder w_scan ist ein Sendersuchlauf möglich:
w_scan -fs -s S19E2 -c DE -X > channels.conf
w_scan version 20091230 (compiled for DVB API 5.1)
output format czap/tzap/szap/xine
Using DVB API 5.1
INVERSION_AUTO
DVB-S
DVB-S2
(time: 00:00)
(time: 00:04)
(time: 00:08) (time: 00:13) signal ok:
(time: 00:26)
(time: 00:30)
(time: 00:34) (time: 00:38) signal ok:
(time: 00:52)
(time: 00:56)
(time: 01:00)
(time: 01:05) (time: 01:09) signal ok:
S  f = 10847 kHz V SR = 22000  5/6 0,35  QPSK
(time: 01:23)
Mein Linux hat folgende Konfiguration:
root@fluffy:~# cat /etc/debian_version
squeeze/sid
root@fluffy:~# uname -a
Linux fluffy 2.6.32-26-generic #48-Ubuntu SMP Wed Nov 24 10:14:11 UTC 2010 x86_64 GNU/Linux
Folgenden Treiber habe ich erfolgreich installiert:
/opt/bin/mediaclient -e
device 0: [Sundtek SkyTV Ultimate]  DVB-S/S2
root@fluffy:~# /opt/bin/mediaclient --build
Build date: Dec  9 2010
root@fluffy:~# lsusb -v -d 'eb1a:51b2'
Bus 002 Device 003: ID eb1a:51b2 eMPIA Technology, Inc.
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass            0 (Defined at Interface level)
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
  idVendor           0xeb1a eMPIA Technology, Inc.
  idProduct          0x51b2
  bcdDevice            1.00
  iManufacturer           3 Sundtek
  iProduct                1 SkyTV Ultimate
  iSerial                 2 123456789ABCD
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength           41
    bNumInterfaces          1
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              500mA
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass       255 Vendor Specific Class
      bInterfaceSubClass      0
      bInterfaceProtocol      0
      iInterface              0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x84  EP 4 IN
        bmAttributes            1
          Transfer Type            Isochronous
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0000  1x 0 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            1
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x03ac  1x 940 bytes
        bInterval               1
Device Qualifier (for other device speed):
  bLength                10
  bDescriptorType         6
  bcdUSB               2.00
  bDeviceSubClass         0
  bDeviceProtocol         0
  bMaxPacketSize0        64
Device Status:     0x0000
  (Bus Powered)
folgende fehlermeldung habe ich Logdir des Treibers:
root@fluffy:~# tail -5 /var/log/mediasrv.log
2010-12-12 16:17:03 [14480] TS Sync byte not aligned, realigning stream (0)
Wo liegt der Fehler, ich weiss nichtmehr weiter? Ich habe bereits einen normalen SAT-Receiver angeschlossen, der natürlich alle Sender findet.
mfg mjoern
« Antwort #38 am: Dezember 13, 2010, 03:38:13 Nachmittag »
17. November? Bitte das ganze nocheinmal herunterladen, es gab in der Zwischenzeit recht viele Änderungen.
Nebenbei bemerkt werden die nachgebesserten Geräte in kürze verfügbar sein.
mjoern
« Antwort #39 am: Dezember 13, 2010, 05:41:53 Nachmittag »
Warum 17.11?
Der Treiber ist vom 9.12:
« Antwort #40 am: Dezember 13, 2010, 06:49:14 Nachmittag »
Wäre es möglich das wir uns dieses Problem kurzfristig via SSH auf Ihrem Rechner ansehen können? Die Überprüfung sollte nicht länger als 10-15 Minuten dauern.
mjoern
« Antwort #41 am: Dezember 13, 2010, 07:03:26 Nachmittag »
Ich richte heute abend SSH ein und sende die Zugangsdaten per email zu.
An welche Email-Adresse?
« Antwort #42 am: Dezember 13, 2010, 07:06:27 Nachmittag »
kontakt at sundtek de
elektron
« Antwort #43 am: Dezember 26, 2010, 10:08:54 Nachmittag »
und wie ist das Ergebniss dieser Untersuchung?
Ich habe immernoch das gleiche Problem und von den Ersatzsticks die am 21.12.2010 versand wurden ist bei mir noch keiner angekommen...
Aber ich gehe mal davon aus, dass die Lieferung im allgemeinen Schneetreiben stecken geblieben ist und dann morgen oder übermorgen ankommt...
Viele Grüße
Michael
« Antwort #44 am: Dezember 27, 2010, 08:59:15 Vormittag »
Wir haben noch Zusatztests gemacht, die Pakete gehen am Dienstag raus, es funktioniert soweit hervorragend. Ein kleines Treiberupdate kommt noch für Kaffeine.
Das Gerät ist sehr stabil bei den finalen Tests, es wurden auch mehrere SAT Installationen überprüft.
Standby wurde ebenfalls noch einmal nachgebessert, die offizielle Dokumentation eines Chips funktioniert diesbezüglich nicht - unsere Entwickler haben hierbei jedoch einen guten Weg gefunden damit die Sticks doch komplett abkühlen.
« Letzte Änderung: Dezember 27, 2010, 09:08:54 Vormittag von Sundtek »
