Autor Thema: ERROR: video data stream broken + EPG bugfix statistics  (Gelesen 12653 mal)
t_turner
« am: Mai 19, 2010, 08:41:12 Nachmittag »
Zwei Dinge vorab:
Und los (bzw. weiter) gehts... :)
Der gewünschte Auszug des mediasrv.log:
2010-05-16 22:30:21 [787] Channel found (378000000)
2010-05-16 22:30:21 [787] =============
2010-05-16 22:30:21 [787] Symbol rate: 6899968
2010-05-16 22:30:21 [787] Constellation: QAM256
2010-05-16 22:30:21 [787] Mirroring: Mirrored
2010-05-16 22:30:24 [787] Channel found (378000000)
2010-05-16 22:30:24 [787] =============
2010-05-16 22:30:24 [787] Symbol rate: 6899970
2010-05-16 22:30:24 [787] Constellation: QAM256
2010-05-16 22:30:24 [787] Mirroring: Mirrored
2010-05-16 22:30:25 [787] Channel found (378000000)
2010-05-16 22:30:25 [787] =============
2010-05-16 22:30:25 [787] Symbol rate: 6899967
2010-05-16 22:30:25 [787] Constellation: QAM256
2010-05-16 22:30:25 [787] Mirroring: Mirrored
2010-05-16 22:30:26 [787] Channel found (378000000)
2010-05-16 22:30:26 [787] =============
2010-05-16 22:30:26 [787] Symbol rate: 6900000
2010-05-16 22:30:26 [787] Constellation: Unknown
2010-05-16 22:30:26 [787] Mirroring: Unknown
2010-05-16 22:30:29 [787] Channel found (378000000)
2010-05-16 22:30:29 [787] =============
2010-05-16 22:30:29 [787] Symbol rate: 6899967
2010-05-16 22:30:29 [787] Constellation: QAM256
2010-05-16 22:30:29 [787] Mirroring: Mirrored
2010-05-16 22:30:30 [787] Channel found (378000000)
2010-05-16 22:30:30 [787] =============
2010-05-16 22:30:30 [787] Symbol rate: 6899967
2010-05-16 22:30:30 [787] Constellation: QAM256
2010-05-16 22:30:30 [787] Mirroring: Mirrored
2010-05-16 22:30:32 [787] Channel found (378000000)
2010-05-16 22:30:32 [787] =============
2010-05-16 22:30:32 [787] Symbol rate: 6900000
2010-05-16 22:30:32 [787] Constellation: Unknown
2010-05-16 22:30:32 [787] Mirroring: Unknown
2010-05-16 22:30:33 [787] Channel found (378000000)
2010-05-16 22:30:33 [787] =============
2010-05-16 22:30:33 [787] Symbol rate: 6900000
2010-05-16 22:30:33 [787] Constellation: Unknown
2010-05-16 22:30:33 [787] Mirroring: Unknown
2010-05-16 22:30:34 [787] Channel found (378000000)
2010-05-16 22:30:34 [787] =============
2010-05-16 22:30:34 [787] Symbol rate: 6900000
2010-05-16 22:30:34 [787] Constellation: Unknown
2010-05-16 22:30:34 [787] Mirroring: Unknown
2010-05-16 22:30:36 [787] Channel found (378000000)
2010-05-16 22:30:36 [787] =============
2010-05-16 22:30:36 [787] Symbol rate: 6900000
2010-05-16 22:30:36 [787] Constellation: Unknown
« Letzte Änderung: Mai 27, 2010, 01:53:14 Nachmittag von Sundtek »
t_turner
Re:ERROR: video data stream broken + EPG bugfix statistics
« Antwort #1 am: Mai 19, 2010, 08:42:00 Nachmittag »
Ich habe dann am Mittwoch abend die Treiber aus der PN-Nachricht ausprobiert. Dabei bin ich wie folgt vorgegangen:
Zunächst habe ich den alten Treiber deinstalliert:
sudo ./sundtek_installer_100506.sh -u
Dann einen Neustart durchgeführt:
sudo reboot
Und dann, nachdem ich zunächst vdr gestoppt habe, die Treiber aus der PN installiert:
sudo ./sundtek_installer_100514.sh
Legal notice:
Nutzungsbedingungen:
Wollen Sie fortfahren [J/N]:
j
unpacking...
checking system... testing libc OK 2.11.1
32Bit System detected
installing...
Starting driver...
done.
t_turner
« Antwort #2 am: Mai 19, 2010, 08:43:25 Nachmittag »
Nach der Treiber-Installation habe ich vdr wieder gestartet und eine Aufnahme angestossen. Kurz darauf erneut der Absturz (ERROR: video data stream broken um 22:27:48). Hier das ganze log zwischen dem Starten des vdr nach der Treiber-Installation und dem Absturz:
May 18 22:01:10 srv204 vdr: [1736] VDR version 1.7.14 started
May 18 22:01:10 srv204 vdr: [1736] switched to user 'vdr'
May 18 22:01:10 srv204 vdr: [1736] codeset is 'UTF-8' - known
May 18 22:01:10 srv204 vdr: [1736] found 25 locales in /usr/share/locale
May 18 22:01:10 srv204 vdr: [1736] loading plugin: /usr/lib/vdr/plugins/libvdr-femon.so.1.7.14
May 18 22:01:10 srv204 vdr: [1736] loading /var/lib/vdr/setup.conf
May 18 22:01:10 srv204 vdr: [1736] loading /var/lib/vdr/sources.conf
May 18 22:01:10 srv204 vdr: [1736] loading /var/lib/vdr/diseqc.conf
May 18 22:01:10 srv204 vdr: [1736] loading /var/lib/vdr/channels.conf
May 18 22:01:10 srv204 vdr: [1736] loading /var/lib/vdr/timers.conf
May 18 22:01:10 srv204 vdr: [1736] loading /var/lib/vdr/commands.conf
May 18 22:01:10 srv204 vdr: [1736] loading /var/lib/vdr/reccmds.conf
May 18 22:01:10 srv204 vdr: [1736] loading /var/lib/vdr/svdrphosts.conf
May 18 22:01:10 srv204 vdr: [1736] loading /var/lib/vdr/keymacros.conf
May 18 22:01:10 srv204 vdr: [1737] video directory scanner thread started (pid=1736, tid=1737)
May 18 22:01:10 srv204 vdr: [1738] video directory scanner thread started (pid=1736, tid=1738)
May 18 22:01:10 srv204 vdr: [1736] reading EPG data from /var/cache/vdr/epg.data
May 18 22:01:10 srv204 vdr: [1738] video directory scanner thread ended (pid=1736, tid=1738)
May 18 22:01:10 srv204 vdr: [1737] video directory scanner thread ended (pid=1736, tid=1737)
May 18 22:01:10 srv204 vdr: [1736] registered source parameters for 'A - ATSC'
May 18 22:01:10 srv204 vdr: [1736] registered source parameters for 'C - DVB-C'
May 18 22:01:10 srv204 vdr: [1736] registered source parameters for 'S - DVB-S'
May 18 22:01:10 srv204 vdr: [1736] registered source parameters for 'T - DVB-T'
May 18 22:01:11 srv204 vdr: [1736] probing /dev/dvb/adapter0/frontend0
May 18 22:01:11 srv204 vdr: [1736] creating cDvbDevice
May 18 22:01:11 srv204 vdr: [1736] new device number 1
May 18 22:01:11 srv204 vdr: [1736] frontend 0/0 provides DVB-C ("Sundtek DVB-C")
May 18 22:01:11 srv204 vdr: [1739] tuner on frontend 0/0 thread started (pid=1736, tid=1739)
May 18 22:01:11 srv204 vdr: [1740] section handler thread started (pid=1736, tid=1740)
May 18 22:01:11 srv204 vdr: [1736] found 1 DVB device
May 18 22:01:11 srv204 vdr: [1736] initializing plugin: femon (1.7.7): DVB Signal Information Monitor (OSD)
May 18 22:01:11 srv204 vdr: [1736] setting primary device to 1
May 18 22:01:11 srv204 vdr: [1736] device 1 has no MPEG decoder
May 18 22:01:11 srv204 vdr: [1736] assuming manual start of VDR
May 18 22:01:11 srv204 vdr: [1736] SVDRP listening on port 2001
May 18 22:01:11 srv204 vdr: [1736] setting current skin to "sttng"
May 18 22:01:11 srv204 vdr: [1736] loading /var/lib/vdr/themes/sttng-default.theme
May 18 22:01:11 srv204 vdr: [1736] starting plugin: femon
May 18 22:01:11 srv204 vdr: [1736] ERROR: /dev/lircd: No such file or directory
May 18 22:01:11 srv204 vdr: [1736] ERROR: remote control LIRC not ready!
May 18 22:01:11 srv204 vdr: [1736] switching to channel 1
May 18 22:01:11 srv204 vdr: [1736] setting watchdog timer to 60 seconds
May 18 22:01:11 srv204 vdr: [1736] OSD size changed to 720x480 @ 1
May 18 22:01:11 srv204 vdr: [1736] ERROR: no OSD provider available - using dummy OSD!
May 18 22:01:17 srv204 vdr: [1736] max. latency time 1 seconds
May 18 22:01:39 srv204 vdr: [1736] connect from 127.0.0.1, port 40396 - accepted
May 18 22:01:51 srv204 vdr: [1736] max. latency time 12 seconds
May 18 22:01:56 srv204 vdr: [1736] closing SVDRP connection
May 18 22:03:52 srv204 vdr: [1736] connect from 127.0.0.1, port 57353 - accepted
May 18 22:03:52 srv204 vdr: [1736] timer 1 (1 2105-2225 'CSI: Miami') added
May 18 22:03:52 srv204 vdr: [1736] switching device 1 to channel 1
May 18 22:03:52 srv204 vdr: [1736] timer 1 (1 2105-2225 'CSI: Miami') start
May 18 22:03:52 srv204 vdr: [1736] Title: 'CSI: Miami' Subtitle: ''
May 18 22:03:52 srv204 vdr: [1736] executing '/usr/lib/vdr/vdr-recordingaction before "/var/lib/video.00/CSI#3A_Miami/2010-05-18.21.05.1-0.rec"'
May 18 22:03:52 srv204 recordingaction: executing /usr/share/vdr/recording-hooks/R90.custom before recording /var/lib/video.00/CSI#3A_Miami/2010-05-18.21.05.1-0.rec as shell script
May 18 22:03:52 srv204 vdr: [1736] record /var/lib/video.00/CSI#3A_Miami/2010-05-18.21.05.1-0.rec
May 18 22:03:52 srv204 vdr: [1736] creating directory /var/lib/video.00/CSI#3A_Miami
May 18 22:03:52 srv204 vdr: [1736] creating directory /var/lib/video.00/CSI#3A_Miami/2010-05-18.21.05.1-0.rec
May 18 22:03:52 srv204 vdr: [1736] recording to '/var/lib/video.00/CSI#3A_Miami/2010-05-18.21.05.1-0.rec/00001.ts'
May 18 22:03:53 srv204 vdr: [1780] recording thread started (pid=1736, tid=1780)
May 18 22:03:53 srv204 vdr: [1781] receiver on device 1 thread started (pid=1736, tid=1781)
May 18 22:03:53 srv204 vdr: [1736] closing SVDRP connection
May 18 22:03:53 srv204 vdr: [1782] TS buffer on device 1 thread started (pid=1736, tid=1782)
May 18 22:03:56 srv204 vdr: [1736] timer 1 (1 2105-2225 'CSI: Miami') set to event Tue 18.05.2010 21:15-22:15 'CSI: Miami'
May 18 22:06:04 srv204 kernel: [  600.516063] [drm] Big FIFO is enabled
May 18 22:06:56 srv204 vdr: [1736] connect from 127.0.0.1, port 58479 - accepted
May 18 22:07:14 srv204 vdr: [1736] closing SVDRP connection
May 18 22:12:14 srv204 vdr: [1736] connect from 127.0.0.1, port 36291 - accepted
May 18 22:12:31 srv204 vdr: [1736] closing SVDRP connection
May 18 22:15:02 srv204 vdr: [1740] channel 1 (RTL Television) event Tue 18.05.2010 22:15-00:00 'Monk' status 4
May 18 22:17:02 srv204 CRON[1787]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
May 18 22:17:32 srv204 vdr: [1736] connect from 127.0.0.1, port 54951 - accepted
May 18 22:17:49 srv204 vdr: [1736] closing SVDRP connection
May 18 22:22:49 srv204 vdr: [1736] connect from 127.0.0.1, port 53165 - accepted
May 18 22:23:02 srv204 vdr: [1736] max. latency time 13 seconds
May 18 22:23:07 srv204 vdr: [1736] closing SVDRP connection
May 18 22:25:00 srv204 vdr: [1780] recording thread ended (pid=1736, tid=1780)
May 18 22:25:00 srv204 vdr: [1736] buffer stats: 143820 (2%) used
May 18 22:25:00 srv204 vdr: [1736] timer 1 (1 2105-2225 'CSI: Miami') stop
May 18 22:25:00 srv204 vdr: [1736] executing '/usr/lib/vdr/vdr-recordingaction after "/var/lib/video.00/CSI#3A_Miami/2010-05-18.21.05.1-0.rec"'
May 18 22:25:00 srv204 vdr: [1782] TS buffer on device 1 thread ended (pid=1736, tid=1782)
May 18 22:25:00 srv204 vdr: [1781] buffer stats: 140248 (6%) used
May 18 22:25:00 srv204 vdr: [1781] receiver on device 1 thread ended (pid=1736, tid=1781)
May 18 22:25:00 srv204 recordingaction: executing /usr/share/vdr/recording-hooks/R90.custom after recording /var/lib/video.00/CSI#3A_Miami/2010-05-18.21.05.1-0.rec as shell script
May 18 22:26:02 srv204 vdr: [1736] deleting timer 1 (1 2105-2225 'CSI: Miami')
May 18 22:26:19 srv204 smartd[1284]: Device: /dev/sda, SMART Prefailure Attribute: 1 Raw_Read_Error_Rate changed from 253 to 100
May 18 22:26:19 srv204 smartd[1284]: Device: /dev/sda, SMART Usage Attribute: 190 Airflow_Temperature_Cel changed from 67 to 65
May 18 22:26:19 srv204 smartd[1284]: Device: /dev/sda, SMART Usage Attribute: 194 Temperature_Celsius changed from 67 to 65
May 18 22:26:19 srv204 smartd[1284]: Device: /dev/sdb, SMART Usage Attribute: 190 Airflow_Temperature_Cel changed from 87 to 85
May 18 22:26:19 srv204 smartd[1284]: Device: /dev/sdb, SMART Usage Attribute: 194 Temperature_Celsius changed from 83 to 80
May 18 22:26:19 srv204 smartd[1284]: Device: /dev/sdc, SMART Usage Attribute: 190 Airflow_Temperature_Cel changed from 88 to 86
May 18 22:26:19 srv204 smartd[1284]: Device: /dev/sdc, SMART Usage Attribute: 194 Temperature_Celsius changed from 84 to 81
May 18 22:26:19 srv204 smartd[1284]: Device: /dev/sdd, SMART Usage Attribute: 190 Airflow_Temperature_Cel changed from 85 to 84
May 18 22:26:19 srv204 smartd[1284]: Device: /dev/sdd, SMART Usage Attribute: 194 Temperature_Celsius changed from 81 to 79
May 18 22:26:19 srv204 smartd[1284]: Device: /dev/sde, SMART Usage Attribute: 190 Airflow_Temperature_Cel changed from 86 to 84
May 18 22:26:19 srv204 smartd[1284]: Device: /dev/sde, SMART Usage Attribute: 194 Temperature_Celsius changed from 82 to 79
May 18 22:26:19 srv204 smartd[1284]: Device: /dev/sdf, SMART Usage Attribute: 190 Airflow_Temperature_Cel changed from 87 to 85
May 18 22:26:19 srv204 smartd[1284]: Device: /dev/sdf, SMART Usage Attribute: 194 Temperature_Celsius changed from 83 to 79
May 18 22:26:57 srv204 vdr: [1740] changing pids of channel 284 from 110+110=2:120=deu,121=2ch;125=deu:0:130 to 110+110=2:120=deu,121=2ch;125=deu:131=deu:130
May 18 22:27:12 srv204 vdr: [1736] connect from 127.0.0.1, port 37643 - accepted
May 18 22:27:12 srv204 vdr: [1736] timer 1 (202 2150-2240 'Plusminus') added
May 18 22:27:12 srv204 vdr: [1736] switching device 1 to channel 202
May 18 22:27:12 srv204 vdr: [1736] timer 1 (202 2150-2240 'Plusminus') start
May 18 22:27:12 srv204 vdr: [1736] Title: 'Plusminus' Subtitle: 'Das ARD-Wirtschaftsmagazin mit Clemens Bratzler'
May 18 22:27:12 srv204 vdr: [1736] executing '/usr/lib/vdr/vdr-recordingaction before "/var/lib/video.00/Plusminus/2010-05-18.21.50.202-0.rec"'
May 18 22:27:17 srv204 recordingaction: executing /usr/share/vdr/recording-hooks/R90.custom before recording /var/lib/video.00/Plusminus/2010-05-18.21.50.202-0.rec as shell script
May 18 22:27:17 srv204 vdr: [1736] record /var/lib/video.00/Plusminus/2010-05-18.21.50.202-0.rec
May 18 22:27:17 srv204 vdr: [1736] creating directory /var/lib/video.00/Plusminus
May 18 22:27:17 srv204 vdr: [1736] creating directory /var/lib/video.00/Plusminus/2010-05-18.21.50.202-0.rec
May 18 22:27:17 srv204 vdr: [1736] recording to '/var/lib/video.00/Plusminus/2010-05-18.21.50.202-0.rec/00001.ts'
May 18 22:27:17 srv204 vdr: [1821] receiver on device 1 thread started (pid=1736, tid=1821)
May 18 22:27:17 srv204 vdr: [1820] recording thread started (pid=1736, tid=1820)
May 18 22:27:17 srv204 vdr: [1736] closing SVDRP connection
May 18 22:27:17 srv204 vdr: [1822] TS buffer on device 1 thread started (pid=1736, tid=1822)
May 18 22:27:17 srv204 vdr: [1736] timer 1 (202 2150-2240 'Plusminus') set to event Tue 18.05.2010 22:00-22:30 (VPS: 18.05 21:45) 'Plusminus'
May 18 22:27:48 srv204 vdr: [1820] ERROR: video data stream broken
May 18 22:27:48 srv204 vdr: [1820] initiating emergency exit
May 18 22:27:48 srv204 vdr: [1736] emergency exit requested - shutting down
May 18 22:27:48 srv204 vdr: [1736] stopping plugin: femon
May 18 22:27:48 srv204 vdr: [1820] recording thread ended (pid=1736, tid=1820)
May 18 22:27:48 srv204 vdr: [1736] buffer stats: 0 (0%) used
May 18 22:27:48 srv204 vdr: [1736] timer 1 (202 2150-2240 'Plusminus') stop
May 18 22:27:48 srv204 vdr: [1736] executing '/usr/lib/vdr/vdr-recordingaction after "/var/lib/video.00/Plusminus/2010-05-18.21.50.202-0.rec"'
May 18 22:27:48 srv204 vdr: [1822] TS buffer on device 1 thread ended (pid=1736, tid=1822)
May 18 22:27:48 srv204 vdr: [1821] buffer stats: 457404 (21%) used
May 18 22:27:48 srv204 vdr: [1821] receiver on device 1 thread ended (pid=1736, tid=1821)
May 18 22:27:53 srv204 recordingaction: executing /usr/share/vdr/recording-hooks/R90.custom after recording /var/lib/video.00/Plusminus/2010-05-18.21.50.202-0.rec as shell script
May 18 22:27:53 srv204 vdr: [1736] saved setup to /var/lib/vdr/setup.conf
May 18 22:27:54 srv204 vdr: [1740] section handler thread ended (pid=1736, tid=1740)
May 18 22:27:57 srv204 vdr: [1736] ERROR: tuner on frontend 0/0 thread 1739 won't end (waited 3 seconds) - canceling it...
May 18 22:27:57 srv204 vdr: [1736] deleting plugin: femon
May 18 22:27:57 srv204 vdr: [1736] =====================
May 18 22:27:57 srv204 vdr: [1736] EPG bugfix statistics
May 18 22:27:57 srv204 vdr: [1736] IF SOMEBODY WHO IS IN CHARGE OF THE EPG DATA FOR ONE OF THE LISTED
May 18 22:27:57 srv204 vdr: [1736] CHANNELS READS THIS: PLEASE TAKE A LOOK AT THE FUNCTION cEvent::FixEpgBugs()
May 18 22:27:57 srv204 vdr: [1736] IN VDR/epg.c TO LEARN WHAT'S WRONG WITH YOUR DATA, AND FIX IT!
May 18 22:27:57 srv204 vdr: [1736] Fix#011Hits#011Channels
May 18 22:27:57 srv204 vdr: [1736] 3#011724#011SAT 1, kabel eins, ProSieben, N24, 9 Live, DASDING, SWR 4 RP, SWR 4 BW
May 18 22:27:57 srv204 vdr: [1736] 4#01114#011WDR 5, hr2, WDR 4, SWR 2, NDR Kultur, radioeins, 3sat
May 18 22:27:57 srv204 vdr: [1736] 6#0111401#011SWR Fernsehen BW, KIRAKA, Das Erste, Bayerisches FS Süd, hr-fernsehen, Bayerisches FS Nord, ...
May 18 22:27:57 srv204 vdr: [1736] 7#011616#011NDR Info, N-JOY, NDR 90,3, NDR1WelleNord, NDR 1 Nieders., NDR Info Spez., Nordwestradio, ...
May 18 22:27:57 srv204 vdr: [1736] 8#011697#011SAT 1, kabel eins, ProSieben, N24, 9 Live
May 18 22:27:57 srv204 vdr: [1736] 9#011697#011SAT 1, kabel eins, ProSieben, N24, 9 Live
May 18 22:27:57 srv204 vdr: [1736] max. latency time 13 seconds
May 18 22:27:57 srv204 vdr: [1736] emergency exit!
May 18 22:27:57 srv204 vdr: [1736] exiting, exit code 1
May 18 22:27:57 srv204 runvdr: restarting VDR
May 18 22:27:57 srv204 kernel: [ 1913.938094] saa7146: unregister extension 'dvb'.
May 18 22:28:00 srv204 kernel: [ 1916.030042] saa7146: register extension 'dvb'.
May 18 22:28:15 srv204 vdr: [1853] cTimeMs: using monotonic clock (resolution is 1 ns)
May 18 22:28:15 srv204 vdr: [1853] VDR version 1.7.14 started
Positiv:
Das "ständige" wechseln und umbenennen der Kanäle ist mit dem neuen Treiber deutlich besser geworden. Dennoch schreibt er ca. alle viertel/halbe Stunde Folgendes in das syslog:
May 19 03:03:13 srv204 vdr: [1857] changing name of channel 159 from 'Sky Sport 1,Sport1;Sky' to 'Champ. League,;'
May 19 03:03:13 srv204 vdr: [1857] changing name of channel 158 from 'Sky Sport 2,Sport2;Sky' to 'Basketball NBA,;'
May 19 03:03:13 srv204 vdr: [1857] changing name of channel 156 from 'Sky Bundesliga,Buli;Sky' to '2. Liga,;'
May 19 03:03:54 srv204 vdr: [1857] changing name of channel 491 from '434 - 01:00,;' to '434 - 03:15,;'
May 19 03:03:55 srv204 vdr: [1857] changing name of channel 159 from 'Champ. League,;' to 'Sky Sport 1,Sport1;Sky'
May 19 03:03:55 srv204 vdr: [1857] changing name of channel 158 from 'Basketball NBA,;' to 'Sky Sport 2,Sport2;Sky'
May 19 03:03:55 srv204 vdr: [1857] changing name of channel 156 from '2. Liga,;' to 'Sky Bundesliga,Buli;Sky'
May 19 03:04:24 srv204 vdr: [1853] connect from 127.0.0.1, port 38075 - accepted
May 19 03:04:41 srv204 vdr: [1853] closing SVDRP connection
May 19 03:09:42 srv204 vdr: [1853] connect from 127.0.0.1, port 57341 - accepted
May 19 03:09:59 srv204 vdr: [1853] closing SVDRP connection
May 19 03:15:00 srv204 vdr: [1853] connect from 127.0.0.1, port 60869 - accepted
May 19 03:15:17 srv204 vdr: [1853] closing SVDRP connection
May 19 03:17:01 srv204 CRON[2869]: (root) CMD (   cd / && run-parts --report /etc/cron.hourly)
May 19 03:17:44 srv204 vdr: [1857] changing name of channel 159 from 'Sky Sport 1,Sport1;Sky' to 'Champ. League,;'
May 19 03:17:44 srv204 vdr: [1857] changing name of channel 158 from 'Sky Sport 2,Sport2;Sky' to 'Basketball NBA,;'
May 19 03:17:44 srv204 vdr: [1857] changing name of channel 156 from 'Sky Bundesliga,Buli;Sky' to '2. Liga,;'
May 19 03:18:25 srv204 vdr: [1857] changing name of channel 159 from 'Champ. League,;' to 'Sky Sport 1,Sport1;Sky'
May 19 03:18:25 srv204 vdr: [1857] changing name of channel 158 from 'Basketball NBA,;' to 'Sky Sport 2,Sport2;Sky'
May 19 03:18:25 srv204 vdr: [1857] changing name of channel 156 from '2. Liga,;' to 'Sky Bundesliga,Buli;Sky'
May 19 03:20:18 srv204 vdr: [1853] connect from 127.0.0.1, port 55646 - accepted
May 19 03:20:35 srv204 vdr: [1853] closing SVDRP connection
« Letzte Änderung: Mai 19, 2010, 08:49:17 Nachmittag von t_turner »
« Antwort #3 am: Mai 19, 2010, 08:50:50 Nachmittag »
Kann es sein das vor "May 19 03:03:13 srv204 vdr:" das Signal verloren wurde?
Wie sieht:
/opt/bin/mediaclient -d /dev/dvb/adapter0/frontend0 --readsignal=0
Im Schnitt aus waehrend VDR laeuft?
Versuchen Sie eventuell auch einen Mitschnitt des Streams zu machen und die Qualitaet zu ueberpruefen
cat /dev/dvb/adapter0/dvr0 > /tmp/test.ts
Passiert dies nur mit gewissen Sendern?
(Wir nehmen derzeit Signalprobleme mit dem Tuner an)
Koennen Sie die USB Einstellungen im BIOS eventuell ebenfalls ueberpruefen (vor kurzem gab es diesbezueglich so einen Fall wo der USB Tuner dann nicht ordentlich funktioniert hat)?
Tritt das ganze nur bei Aufnahmen auf? - Ist die Festplatte in Ordnung (dies koennten Sie ueberpruefen indem Sie wie erwaehnt den Stream mit 'cat' mitschneiden)?
« Letzte Änderung: Mai 19, 2010, 09:19:58 Nachmittag von Sundtek »
t_turner
« Antwort #4 am: Mai 20, 2010, 10:37:17 Vormittag »
Haben Sie mir ggf. eine Emailadresse? Ich würde an diese das komplette syslog, Mitschnitte des Signals, etc. senden.
Grüße
« Antwort #5 am: Mai 20, 2010, 10:37:46 Vormittag »
kontakt at sundtek de
t_turner
« Antwort #6 am: Mai 20, 2010, 12:19:26 Nachmittag »
Ich habe die Dateien soeben per Email gesendet (syslog + signal).
Den Mitschnitt mit
kann ich mit vlc zwar öffnen, die Datei wird aber nicht abgespielt (am Anfang ist kurz etwas zu hören, ein Bild wird nicht angezeigt).
Ich habe den obigen Befehl ausgeführt als vdr lief, aber keine Aufnahme getätigt hat. Sollte dieses falsch gewesen sein, bitte kurz posten.
Ich habe verschiedene Sender versucht aufzunehmen (RTL, VOX, ARD, ZDF, nt-v, etc). Soweit ich es beurteilen kann, stürzt der vdr bei allen Sendern ab.
Ich habe die BIOS-Einstellungen meines Boards überprüft. Es gibt keine speziellen Einstellungen bzüglich USB. Mann kann den USB-Hub 1.0 bzw. 2.0 aktivieren bzw. deaktivieren. Das war es aber auch schon.
Die Abstürze treten nur bei Aufnahmen.
Die Festplatte selbst habe ich noch nicht geprüft. Die Datei des Mitschnitts wird aber angelegt und wird auch "größer".
Aufnahmen bis zum jeweiligen Absturz kann ich ansehen. Die Qualität ist ok, keine Ruckler oder Tonaussetzer.
« Antwort #7 am: Mai 20, 2010, 01:11:21 Nachmittag »
Ok anhand der von Ihnen zugesandten Logfiles koennen wir erkennen dass das Signallevel Aussetzer hat.
Wir werden dies nochmal mit Trident zuruecksprechen ob es hierbei eventuell Probleme geben kann, wenn man das Signallevel in einem zu engen Intervall ausliest (laut unserer Chip Dokumentation ist hierbei leider nichts angegeben).
Die syslog Logfile sagt ebenfalls das VDR das Signal verloren hat da der Treiber no Signal uebermittelt hat - dies deckt sich mit der "readsignal" logfile von Ihnen.
Nach der Logfile stufen wir das ganze als Problem beim Auslesen der Signalstaerke ein, dies koennen wir im Treiber nachbessern.
Sofern es tatsaechlich nur an dem Signallevelreporting vom Chip liegt laesst sich dieses Problem relativ einfach beheben. Waere es unter umstaenden moeglich Zugriff auf den Rechner zu bekommen um das Verhalten genauer zu ueberpruefen und ggf eine Testversion einspielen koennten?
t_turner
« Antwort #8 am: Mai 20, 2010, 02:16:28 Nachmittag »
Zunächst einmal Danke für den engagierten Support.
Wenn es irgendwie möglich ist möchte ich einen Zugriff auf den Rechner vermeiden da er gleichzeitig Backup für private und sensible Daten ist.
« Antwort #9 am: Mai 28, 2010, 11:08:37 Vormittag »
Nach den Software Tests ist klar das es sich hierbei um ein Hardwareproblem handelt, eventuell in Verbindung mit dem jeweiligen Kabel Anschluss.
Es konnte keine einzige Sendung ohne Continuity Errors aufgenommen werden.
Das Geraet wird ueberprueft und falls der Fehler bei uns nicht reproduzierbar ist wie gewuenscht zurueckgenommen.
Muschimann
« Antwort #10 am: Mai 30, 2010, 05:22:35 Nachmittag »
Ich habe ein ähnlich komisches Problem, deswegen schreib ich es mal hier mit rein. :)
Also folgendes, der VDR läuft soweit stabil und ich kann auch aufnehmen, aber sowie ich von einem öffentlich-rechtlichen Sender was aufnehmen will zickt der rum, meistens geht das Starten der Aufnahme noch gut und beim Beenden steigt der VDR aus, bzw. runvdr startet neu. Nach dem Neustart des VDR geht aber nix mehr, d.h. ich muß um wieder etwas zu sehen den Rechner komplett neu starten. Mit Privatsendern habe ich dieses Problem nicht, da läufts wie am Schnürchen.
Zuerst hatte ich ein Plugin in Verdacht, aber nach Deaktivierung aller Plugins hat sich nichts gebessert - dann habe ich mal ein Downgrade auf VDR 1.6 gemacht, aber da ist das gleiche in Grün (bzw Schwarz :)).
Nun habe ich mal die Sticks entfernt und eine Technotrend Karte eingebaut und da macht der VDR brav was er soll. Keinerlei Probleme mit den ÖR.
In den Logs finde ich aber auch nichts, lediglich das runvdr neu startet, mehr nicht. Ich bin im Moment echt ein bisschen ratlos.
« Antwort #11 am: Mai 30, 2010, 06:03:38 Nachmittag »
Senden Sie die Logfiles (syslog, mediasrv.log, ggf mediaclient.log von /var/log) bitte an kontakt at sundtek de
Muschimann
« Antwort #12 am: Juni 01, 2010, 09:29:45 Nachmittag »
Hallo, ich hatte eben wieder einen "Vorfall" - habe die Logs, wie gewünscht, per Mail zugeschickt.
