Autor Thema: Update 12. April 2010  (Gelesen 8544 mal)
« am: April 12, 2010, 10:13:14 Nachmittag »
Version: http://www.sundtek.de/media/sundtek_installer_100416.sh
Features:
* it's now possible to switch the device between bulk and isochronous transfer mode (this can work around the USB Isochronous bug which is mentioned in the installation guide which affects 2.6.26-29 and 2.6.32.9 - 2.6.33.1 for DVB)
* added option to disable filtering for MPEG-TS Null packets in order to provide the full bandwidth stream (by default filtering is enabled since mplayer cannot handle MPEG-TS Null packets and corrupts the videostream).
documentation about those features can be found at the bottom of the installation guide
General changes:
* udev will now be stopped by the service process with faulty kernels
* tvtime will also be stopped by the service thread when the stick gets unplugged
* the driver denies VBI access for MythTV since MythTV has a faulty implementation.
* audio will not be played back internally anymore for MythTV
* improved USB Bulk implementation (16. April 2010)
* added support for new Ubuntu Server device notifications (16. April 2010)
Bugfix:
* Device wakeup after device has been suspended in FM Radio Mode
* modified USB devicedetection in order to support older kernel versions again (eg. RHEL 5.4/Kernel 2.6.18)
* Bugfix in MythTV (VBI Cleanup) http://svn.mythtv.org/trac/attachment/ticket/8337/vbi_cleanup.diff
* rare problem with VDR fast zapping and bad or unlocked signal
« Letzte Änderung: April 16, 2010, 02:17:14 Nachmittag von Sundtek »
