Autor Thema: osmc vero4 drivers install problem  (Gelesen 6013 mal)
inah
« am: Februar 17, 2018, 11:18:07 Vormittag »
Hello
I have problem with sundtek drivers install to osmc :
Wollen Sie fortfahren [J/N]:
y
unpacking...
checking system... testing libc OK 2.24.0
64Bit ARM detected
Downloading architecture specific driver ... arm64
ERROR: ld.so: object '/opt/lib/libmediaclient.so' from /etc/ld.so.preload cannot        be preloaded (wrong ELF class: ELFCLASS64): ignored.
Starting driver...
This system is using systemctl for starting the driver...
done.
and of course i dont see adapter from tvheadend
but command
osmc@osmc:~$ /opt/bin/mediaclient -e
device 0: [MediaTV Pro III (EU)]  DVB-C, DVB-T, DVB-T2, ANALOG-TV, FM-RADIO, REM        OTE-CONTROL, OSS-AUDIO, RDS
  [DVB-C,DVB-T,DVB-T2]:
     VIDEO0: /dev/video11
Re:osmc vero4 drivers install problem
« Antwort #1 am: Februar 17, 2018, 11:33:06 Vormittag »
32 / 64bit environment mismatch.
You would have to install the driver which matches tvheadend.
However we are currently adding an option to our software so tvheadend will connect via network (or local loopback) to our driver. You will have to wait a few more days. This will be the most portable way across all systems (even Android)
« Letzte Änderung: Februar 17, 2018, 11:34:40 Vormittag von Sundtek »
inah
« Antwort #2 am: Februar 17, 2018, 11:35:03 Vormittag »
OK i wait ;D
inah
« Antwort #3 am: Februar 21, 2018, 05:25:47 Nachmittag »
Hello
Tried driver from 20.02 still same error
osmc@osmc:~$ sudo -s
root@osmc:/home/osmc# cd /tmp
root@osmc:/tmp# wget http://sundtek.de/media/sundtek_netinst.sh
--2018-02-21 17:19:30--  http://sundtek.de/media/sundtek_netinst.sh
Resolving sundtek.de (sundtek.de)... 85.10.198.106
Connecting to sundtek.de (sundtek.de)|85.10.198.106|:80... connected.
Length: 129093 (126K) [text/x-sh]
Saving to: 'sundtek_netinst.sh'
sundtek_netinst.sh  100%[===================>] 126.07K   403KB/s    in 0.3s
2018-02-21 17:19:31 (403 KB/s) - 'sundtek_netinst.sh' saved [129093/129093]
root@osmc:/tmp# sh sundtek_netinst.sh
Busybox installation
(C)opyright 2008-2016 Sundtek <kontakt@sundtek.de>
Legal notice:
Nutzungsbedingungen:
y
unpacking...
64Bit ARM detected
Starting driver...
inah
« Antwort #4 am: Februar 22, 2018, 08:17:55 Nachmittag »
Someone can answer new driver is released or no ?
« Antwort #5 am: Februar 22, 2018, 08:38:57 Nachmittag »
it's not the driver, it will be our streamingserver which can be used with TVHeadend. Unfortunately this week we didn't have time to update it - it's planned for next week.
