Autor Thema: Extrem viele Fehler auf allen Sendern im 114mhz Band (Kabel1HD,ArteHD)  (Gelesen 5572 mal)
fleixi
« am: Februar 13, 2018, 08:12:25 Nachmittag »
Seit 2-3 Wochen kann ich nicht mehr Kabel1 HD und Arte HD schauen. Ich bekomme in meinem Tvheadend nur einen hohen BER-Wert 7000-35000 und diese Fehler:
2018-02-13 18:53:21.241 mpegts: 114MHz in Mellix - tuning on Sundtek DVB-C (III) #0 : DVB-C #0
2018-02-13 18:53:21.339 subscription: 0004: "epggrab" subscribing to mux "114MHz", weight: 4, adapter: "Sundtek DVB-C (III) #0 : DVB-C #0", network: "Mellix", service: "Raw PID Subscription"
2018-02-13 18:53:47.061 subscription: 0005: "::ffff:127.0.0.1 [ xbmc | Kodi Media Center ]" subscribing on channel "arte HD", weight: 100, adapter: "Sundtek DVB-C (III) #0 : DVB-C #0", network: "Mellix", mux: "114MHz", provider: "ARD", service: "arte HD", profile="htsp", hostname="::ffff:127.0.0.1", username="xbmc", client="Kodi Media Center"
2018-02-13 18:53:47.099 TS: Mellix/114MHz/arte HD Transport error indicator (total 1)
2018-02-13 18:53:47.271 parser: Mellix/114MHz/arte HD: AC3 @ #6662: DTS and PCR diff is very big (1669934789)
2018-02-13 18:53:47.271 parser: Mellix/114MHz/arte HD: AC3 @ #6669: DTS and PCR diff is very big (1669934789)
2018-02-13 18:53:48.111 TS: Mellix/114MHz/arte HD: H264 @ #6661 Continuity counter error (total 1)
2018-02-13 18:53:49.125 TS: Mellix/114MHz/arte HD: AC3 @ #6669 Continuity counter error (total 1)
2018-02-13 18:53:49.125 TS: Mellix/114MHz/arte HD: TELETEXT @ #6664 Continuity counter error (total 1)
2018-02-13 18:53:49.125 TS: Mellix/114MHz/arte HD: AC3 @ #6662 Continuity counter error (total 1)
2018-02-13 18:53:49.125 TS: Mellix/114MHz/arte HD: AC3 @ #6663 Continuity counter error (total 1)
2018-02-13 18:53:51.860 TS: Mellix/114MHz/arte HD: H264 @ #6661: Invalid start code c0:cd:f4
2018-02-13 18:53:57.094 TS: Mellix/114MHz/arte HD Transport error indicator (total 507)
2018-02-13 18:53:58.241 TS: Mellix/114MHz/arte HD: H264 @ #6661 Continuity counter error (total 68)
2018-02-13 18:53:59.534 TS: Mellix/114MHz/arte HD: AC3 @ #6669 Continuity counter error (total 8)
2018-02-13 18:53:59.758 TS: Mellix/114MHz/arte HD: AC3 @ #6663 Continuity counter error (total 17)
2018-02-13 18:53:59.890 TS: Mellix/114MHz/arte HD: AC3 @ #6662 Continuity counter error (total 9)
2018-02-13 18:54:02.897 TS: Mellix/114MHz/arte HD: TELETEXT @ #6664 Continuity counter error (total 10)
2018-02-13 18:54:05.067 subscription: 0005: "::ffff:127.0.0.1 [ xbmc | Kodi Media Center ]" unsubscribing from "arte HD", hostname="::ffff:127.0.0.1", username="xbmc", client="Kodi Media Center"
2018-02-13 18:54:05.869 subscription: 0004: "epggrab" unsubscribing
Mein reseiver:
[fleixi@daisy ~]$ /opt/bin/mediaclient -e
device 0: [MediaTV Digital Home III (EU)]  DVB-C, DVB-T, DVB-T2, REMOTE-CONTROL
     STATUS: ACTIVE
  [DVB-C,DVB-T,DVB-T2]:
Das Gerät ist direkt mit an der Wandbuchse angeschlossen und mit dem besten USB-Kabel was ich im Conrad kaufen konnte an meinem Rechner angeschlossen (ArchLinux Kernel 4.15.*).
Aber nun das ganz komische:
Ich hab mir zum Testen ein reseiver von Vodafone kommen lassen und dieser hat sogar mit Antennenkabel dazwischen keine Probleme das Programm abzuspielen, womit das Problem anscheinend erst nach der Dose kommen muss.
Alle anderen unverschlüsselten und von meinem Vodafone-Vertrag abgedeckten verschlüsselten Sender kann ich ohne oder mit sehr selten Bildfehlern anschauen.
Re:Extrem viele Fehler auf allen Sendern im 114mhz Band (Kabel1HD,ArteHD)
« Antwort #1 am: Februar 13, 2018, 08:25:07 Nachmittag »
Was zeigt denn /opt/bin/mediaclient --readsignal=0 -d /dev/dvb/adapter0/frontend0 an?
Wenn der Tuner (BJ 2014) 3 Jahre problemlos arbeitet dann gibt's auch weiterhin höchst wahrscheinlich kein Problem mit dem Tuner.
Steckt der Tuner an USB 2.0 oder USB 3.0 dran?
Vielleicht mal ein längeres USB Kabel verwenden und/oder eine andere Steckdose für den PC.
fleixi
« Antwort #2 am: Februar 13, 2018, 08:39:35 Nachmittag »
[fleixi@daisy ~]$ /opt/bin/mediaclient --readsignal=0 -d /dev/dvb/adapter0/frontend0
== reading digital TV signal ==
SIGNAL: [..............................   ] ( 90%) BER:      0 CNR: 33,00 FREQ: 834000000  Hz LOCKED: YES SYM: 6900000 MOD: QAM64
SIGNAL: [..............................   ] ( 90%) BER:      0 CNR: 32,70 FREQ: 834000000  Hz LOCKED: YES SYM: 6900000 MOD: QAM64
Mein Rechner hat nur USB3-Ausgänge, aber ich habe auch einen USB2-Hub dranhängen. Habe aber bereits alle Ports direkt am Rechner und an meinem USB3-Hub und an meinem USB2-Hub ausprobiert.
Meiner Rechner ist dieser: https://www.intel.com/content/www/us/en/products/boards-kits/nuc/kits/nuc7i3dnhe.html
Andere Steckdose geht nicht wirklich da in der Ecke des Raums keine weiteren Steckdosen frei sind, bzw die vorhandenen 3 Dosen alle direkt nebeneinander liegen (Sinn des Umsteckens?)
Ich habe bereits 4 Usb-Kabel in längen von 1,5m - 5m durchprobiert.
Die beiden Sender gingen bis vor kurzen auch noch mit genau dem gleichen Setup
« Antwort #3 am: Februar 14, 2018, 04:04:05 Vormittag »
Schalte zuerst auf 114 MHz und starte dann den readsignal Befehl. 834 MHz hat ja keine Probleme.
fleixi
« Antwort #4 am: Februar 14, 2018, 07:32:11 Nachmittag »
Das Stimmt natürlich Tschudigung :-D
SIGNAL: [.......................          ] ( 70%) BER:  27999 CNR: 28,50 FREQ: 114000000  Hz LOCKED: YES SYM: 6900000 MOD: QAM256
SIGNAL: [.......................          ] ( 70%) BER:  29000 CNR: 28,50 FREQ: 114000000  Hz LOCKED: YES SYM: 6900000 MOD: QAM256
« Antwort #5 am: Februar 14, 2018, 08:03:34 Nachmittag »
Also was ich hier sagen kann ist das die Signalstärke extrem schwach ist auf der Frequenz. Versuch mal am Anschluss zu rütteln.
Die CNR sollte über 30 sein, 35 ist eigentlich Standard bei den meisten Leitungen.
SIGNAL: [...............................  ] ( 93%) BER:      0 CNR: 32.70 FREQ: 121000000  Hz LOCKED: YES SYM: 6900000 MOD: QAM64
SIGNAL: [...............................  ] ( 93%) BER:      0 CNR: 33.00 FREQ: 121000000  Hz LOCKED: YES SYM: 6900000 MOD: QAM64
121MHz ist das niedrigste bei meiner persönlichen Leitung zuhause.
fleixi
« Antwort #6 am: Februar 14, 2018, 08:42:15 Nachmittag »
Weiß leider nicht an welchen Anschluss ich noch ruckeln soll. Ich hab ja bereits dutzende Kombinationen an Anschlussmöglichkeiten ausprobiert und im gleichen Vorgang den Stick sowohl an der Wanddose wie auch am Usbanschluss mehrmals abgezogen und wieder angeschlossen ohne eine Besserung feststellen zu können.
Die Frage währe ja noch warum der Reseiver von Vodafone das Problem nicht hat.
Habt ihr keine Möglichkeit das 114mhz Band zu testen?
Ich habe mir zu Testzwecken einen 2ten Usb-Reseiver von einem anderen Hersteller bestellt und werde diesen hoffentlich morgen testen können. Dann kann ich vielleicht den Fehler weiter eingrenzen. Aber eigentlich bin ich mit eurem Ansatz den Treiber im Userspace laufen zu lassen sehr zufrieden und möchte nicht auf dauer auf einen anderen Hersteller wechseln.
fleixi
« Antwort #7 am: Februar 15, 2018, 07:59:28 Nachmittag »
So der neue Reseiver ist sogar schon heute gekommen. Wenn ich den genauso wie euren anschließe gehen die Sender auf 114mhz wieder ohne Probleme. Leider ist der Reseiver nicht so komfortabel wie eurer und ich bekomme nur folgende Infos über die Sendeleistung:
Bei dem Stick handelt es sich laut Kernel um DVBSky T330 und läuft mit den Firmware von hier https://linuxtv.org/wiki/index.php/TechnoTrend_TT-TVStick_CT2-4400
Damit lässt sich der Fehler auf euren Stick zurückführen. Wie kann ich das beheben?
« Antwort #8 am: Februar 15, 2018, 08:13:08 Nachmittag »
Wenn das vorher funktioniert hat dann müsste es jetzt auch noch funktionieren - wir haben ja nichts an Deiner Anlage verändert.
Ich sehe bei dem genannten Model von 2014 jetzt keine Möglichkeit etwas an der HW zu ändern.
Vielleicht wurde der Tuner auch beim Antennenanschluss in den Jahren der Verwendung beschädigt.
Der Chipsatz im benannten Tuner ist 4-5 Jahre alt, in der Zwischenzeit gab's da auch etliche Aktualisierungen.
Bei dem anderen Tuner haben Uncorrectable & Continuity Errors auch Werte (wobei wenn Du den jetzt gekauft hast der wahrscheinlich genau wie unsere aktuellen Tuner Chipsätze verwendet die wohl nicht älter als 1-2 Jahre sind).
Wir hatten vor der Kabelumstellung in Berlin ebenfalls 113 MHz / Kabel Deutschland und damit eigentlich keine Probleme.
« Letzte Änderung: Februar 15, 2018, 08:23:33 Nachmittag von Sundtek »
fleixi
« Antwort #9 am: Februar 15, 2018, 08:27:49 Nachmittag »
Die Fehler vom neuen Reseiver sind nur 2mal beim umschalten aufgetreten und das war bei eurem Reseiver auch schon immer der Fall. Nach einem Neustart hatte ich bisher noch gar keinen Fehler bei dem Reseiver.
Ich verstehe das Ihr bei einem 3-4 Jahre alten nicht genaueres sagen könnt. Da Ihr anscheinend auch keine Idee mehr habt gehen ich davon aus dass das Gerät einfach über die Jahre kaputt gegangen ist. Schade das es schon nach 3 Jahren war, aber das ist natürlich auch schon längst über jegliche Garantie hinaus und nicht eure Schuld.
Daher schließe ich das Thema einfach mit der Aussage das dass Gerät kaputt ist.
