Autor Thema: unsuccessful frequency scan  (Gelesen 4700 mal)
batstru
« am: Januar 15, 2018, 10:07:15 Nachmittag »
Hi all,
I have a Sundtek MediaTV Pro III that I'd like to use in a Raspberry Pi 3.
I've connected the usb dongle via a powered usb hub.
Following the instruction from http://support.sundtek.com/index.php/topic,4.0.html, I did:
- wget http://www.sundtek.de/media/sundtek_netinst.sh
- chmod 777 sundtek_netinst.sh
- sudo ./sundtek_netinst.sh
- sudo /opt/bin/mediaclient --installstreamer
Below you can find the output.
I tried also many other things, all unsuccessful:
- scan /usr/share/dvb/dvb-legacy/dvb-t/it-All
- scan /usr/share/dvb/dvb-t/it-All
- w_scan -f t -c IT -t 3 -x -vv -F >> IT-channels
All the same: no channels detected.
What can I do? Do you have suggestion?
Regards
pi@decoder:~ $ wget http://www.sundtek.de/media/sundtek_netinst.sh
--2018-01-15 20:42:30--  http://www.sundtek.de/media/sundtek_netinst.sh
Resolving www.sundtek.de (www.sundtek.de)... 85.10.198.106
Connecting to www.sundtek.de (www.sundtek.de)|85.10.198.106|:80... connected.
Length: 129093 (126K) [text/x-sh]
Saving to: 'sundtek_netinst.sh'
sundtek_netinst.sh  100%[===================>] 126.07K   219KB/s    in 0.6s
2018-01-15 20:42:31 (219 KB/s) - 'sundtek_netinst.sh' saved [129093/129093]
pi@decoder:~ $ chmod 777 sundtek_netinst.sh
pi@decoder:~ $  sudo ./sundtek_netinst.sh
(C)opyright 2008-2016 Sundtek <kontakt@sundtek.de>
Legal notice:
Nutzungsbedingungen:
Wollen Sie fortfahren [J/N]:
y
unpacking...
checking system... ARM SYSV HF System detected
Downloading architecture specific driver ... armsysvhf
Starting driver...
This system is using systemctl for starting the driver...
done.
pi@decoder:~ $ sudo /opt/bin/mediaclient --installstreamer
Trying to connect to sundtek webserver
Downloading http://sundtek.de/media/streamer/armsysvhf/rtspd
Starting streamingserver...
Download successful...
Now please go to http://localhost:22000/
Re:unsuccessful frequency scan
« Antwort #1 am: Januar 15, 2018, 10:36:38 Nachmittag »
Mistake No. 1 - remove the USB Hub and attach the tuner directly to the RPI.
I guess your USB HUB is blocking the USB Data for some reason (we have seen that issue in the past, not all Hubs have that problem but a few).
« Letzte Änderung: Januar 15, 2018, 10:38:29 Nachmittag von Sundtek »
batstru
« Antwort #2 am: Januar 15, 2018, 11:06:54 Nachmittag »
Hi, this is what I tried before.
Actually previously I tried to scan for the channels with the dongle directly attached to the Rpi, but the results are unfortunately the same.
Anyway, tomorrow I'll remove the usb hub (the Rpi is on a remote site) and I'll let you know.
Is there a way to increase logging?
More general question:
- how does it work the Sundtek? What is the role of mediasrv and mediaclient?
- I noticed the link of the service /etc/systemd/system/multi-user.target.wants/sundtek.service was broken, and I had to link by hand to /opt/doc/sundtek.service. Before it was pointing to /usr/lib/systemd/system/sundtek.service. Is that a known issue? I have a suspect the installation didn't go through fine. How can I check for that? If I I fire /opt/bin/mediaclient -e I get the following output:
device 0: [MediaTV Pro III (EU)]  DVB-C, DVB-T, DVB-T2, ANALOG-TV, FM-RADIO, REMOTE-CONTROL, OSS-AUDIO, RDS
  [DVB-C,DVB-T,DVB-T2]:
     OSS0: /dev/dsp1
« Antwort #3 am: Januar 15, 2018, 11:53:44 Nachmittag »
* mediasrv is the driver,
* mediaclient the swiss army knife to control the tuner (usually not needed by customers though).
you can check in the chatroom for remote help
http://chat.sundtek.de
Some of our startscripts are deleted on purpose.
« Letzte Änderung: Januar 16, 2018, 01:41:00 Vormittag von Sundtek »
