Autor Thema: HEVC on Sundtek  (Gelesen 22430 mal)
anilw
HEVC on Sundtek
« am: Oktober 05, 2017, 04:24:07 Nachmittag »
Hello
Is HEVC support on this tuner (USB DVB-S2)
Re:HEVC on Sundtek
« Antwort #1 am: Oktober 05, 2017, 08:45:50 Nachmittag »
HEVC is no Problem that's just h265 - a video codec.
anilw
Re:HEVC on Sundtek
« Antwort #2 am: Oktober 06, 2017, 08:29:24 Vormittag »
Ok tks for the reply
but now i cannot watch videos.. only audio on on Vu+
is my also needed an upgrade???
Re:HEVC on Sundtek
« Antwort #3 am: Oktober 06, 2017, 12:22:32 Nachmittag »
Which transponder, which Satellite?
anilw
Re:HEVC on Sundtek
« Antwort #4 am: Oktober 06, 2017, 01:28:01 Nachmittag »
Insat 4B (93.5E)
11097V/32000
11010V/32000
11630H/32000
11670H/32000
Re:HEVC on Sundtek
« Antwort #5 am: Oktober 06, 2017, 01:46:10 Nachmittag »
hmm... I do not see those frequencies on lyngsat:
https://www.lyngsat.com/Insat-3A-4B-and-G-Sat-15.html
do you have another list?
anilw
Re:HEVC on Sundtek
« Antwort #6 am: Oktober 06, 2017, 02:00:00 Nachmittag »
hi this change was done just yesterday and these site might take some time to update this.. however pls see the following screen shot to show (taekn from one of my friends 4K box)
anilw
Re:HEVC on Sundtek
« Antwort #7 am: Oktober 06, 2017, 02:05:40 Nachmittag »
Few days ago they were having two test chs of HEVC, pls see below
LInk: http://www.asiatvro.com/channelinfo/93.5G.htm
But this ch was also not possible to view during the test time
Re:HEVC on Sundtek
« Antwort #8 am: Oktober 06, 2017, 02:12:06 Nachmittag »
This is not hevc, this is still h264 (the codec is totally unrelated to this anyway)
What does following command show up:
/opt/bin/mediaclient --readsignal=0 -d /dev/dvb/adapter1/frontend0 --band universal
(abort with ctrl-c)
you might also join the chat http://chat.sundtek.de
anilw
Re:HEVC on Sundtek
« Antwort #9 am: Oktober 06, 2017, 03:02:47 Nachmittag »
ok i'll tonight post you what outcome has found...
tks
anilw
Re:HEVC on Sundtek
« Antwort #10 am: Oktober 06, 2017, 06:37:10 Nachmittag »
Hi Pls have a look on the below.. the following were taken from my box and i see only blank screen (audio only)
Ch Screen Shot
Ch Service info
anilw
Re:HEVC on Sundtek
« Antwort #11 am: Oktober 06, 2017, 06:47:25 Nachmittag »
Pls have a look same ch on two different formats..
AVC- works fine
HEVC- only Audio
Tryon
Re:HEVC on Sundtek
« Antwort #12 am: Oktober 27, 2017, 04:39:07 Nachmittag »
Conclusion of this topic is that HEVC can be used for any resolution. In this case it will work only on UNO4k/Ultimo4k/Solo4k... :-\
