Autor Thema: Problems getting to work on Raspberry Pi (Jessie)  (Gelesen 7497 mal)
dpdpkpcom
« am: August 24, 2017, 09:14:33 Vormittag »
Hi there
I'm trying to run a Raspberry Pi backend tv streaming server with the Pi being the server, running TVHeadend.
The first time I installed it, it got a list of channels and I thought "Great!".
But, for some reason now it doesn't work.
I don't seem to get any signal.
I should point out that I've changed the satellite cable feed to an alternate that I know works, but still nothing.
In case these help :-
root@rasptv:~# /opt/bin/mediaclient -e
     STATUS: ACTIVE
     FESTATUS: ACTIVE
     LNBVOLTAGE: ENABLED
     LNBSUPPLY: USBPOWER
root@rasptv:~# femon
FE: Sundtek DVB-S/S2 (VI) (DVBS)
status       | signal 0000 | snr 0000 | ber 00000000 | unc 00000000 |
Can you point me in the right direction ?
Vielen Dank
dp
Re:Problems getting to work on Raspberry Pi (Jessie)
« Antwort #1 am: August 24, 2017, 10:40:50 Vormittag »
     LNBSUPPLY: USBPOWER
try to use it with an AC adapter?
dpdpkpcom
« Antwort #2 am: August 24, 2017, 10:51:10 Vormittag »
Sorry, I should have mentioned I had tried that. Here are the readouts with the A/C connected. I have tried various voltage levels (highest and lowest) :-
     STATUS: ACTIVE
     FESTATUS: ACTIVE
     LNBVOLTAGE: ENABLED
     LNBSUPPLY: ACADAPTER
Any other ideas ?
Thanks
dp
« Antwort #3 am: August 24, 2017, 10:59:09 Vormittag »
don't use femon it doesn't give us enough information.
/opt/bin/mediaclient --readsignal=0 -d /dev/dvb/adapter0/frontend0 --band universal
dpdpkpcom
« Antwort #4 am: August 24, 2017, 11:10:02 Vormittag »
ok, thanks for that....
Here's the result of that :-
: FEC_5_6 MOD: QPSK VOLTAGE: V(13V) TONE: ON
SIGNAL: [                                 ] (  0%) SATQUALITY:   0%  SNR:   0  BER:      0 FREQ: 12207000   Hz LOCKED:  NO SYS: DVB-S SYM: 27500000 FEC: FEC_5_6 MOD: QPSK VOLTAGE: V(13V) TONE: ON
« Antwort #5 am: August 24, 2017, 11:18:01 Vormittag »
Don't see a direct issue from the logfile, it needs some further investigation (best is via chat and remote desktop)
try to join the chat http://chat.sundtek.de
« Letzte Änderung: August 24, 2017, 11:59:52 Vormittag von Sundtek »
Tryon
Improve output
« Antwort #6 am: September 16, 2017, 03:15:47 Nachmittag »
User may be confused by 12207(000)000 (k)Hz ???
SIGNAL: [                                 ] (  0%) QUALITY:0%  SNR:0  BER: 0 FREQ: 12207 MHz LOCKED:NO SYS: DVB-S SYM: 27500 FEC: FEC_5_6 MOD: QPSK VOLTAGE: V(13V) TONE: ON
« Letzte Änderung: September 16, 2017, 03:21:50 Nachmittag von Tryon »
dpdpkpcom
« Antwort #7 am: September 16, 2017, 03:25:38 Nachmittag »
This case can be closed now. Was a faulty unit, efficiently replaced by Sundtek :-)
