Autor Thema: DiSEqC Switch issue  (Gelesen 4986 mal)
anilw
DiSEqC Switch issue
« am: Mai 11, 2017, 04:27:53 Nachmittag »
HI..
I am using my Sundtek SkyTV Ultimate DVB-S2 USB tuner along with Diseqc switch, (my box is Vu+ SOLO SE V2) seems the usb tuner does not support properly. after some times tuner gets failed.
I have tried with DISEqC switches 1.0 and 1.1.. both have problems with USB tuner, after some time TUNER failed.
both the above diseqc switches are working properly with Vu+ tuners and other set-top boxes...
Seems the SUNDTEK tuner has a problem with Diseqc switches..
Pls make the correct updates to support diseqc switches immediately...
we cannot just watch one satellite with this tuner.. we want to watch multiple satellites...
Re:DiSEqC Switch issue
« Antwort #1 am: Mai 11, 2017, 06:17:40 Nachmittag »
Diseqc is properly supported by the tuner. You might have to send the Diseqc commands again before tuning to a new channel.
The tuner enters standby after 15 seconds inactivity - and turns off the LNB Voltage output.
anilw
« Antwort #2 am: Mai 11, 2017, 06:45:00 Nachmittag »
Ok pls send me the correct settings for diseqc swicth
« Antwort #3 am: Mai 11, 2017, 06:48:24 Nachmittag »
You can try to increase the standby_timeout in /etc/sundtek.conf
you have to add the configuration manually with an editor and save it back to the settopbox.
standby_timeout=90000
maybe that will help you a bit. Which multiswitch/es do you have, what does your wired configuration look like?
anilw
« Antwort #4 am: Mai 11, 2017, 07:06:28 Nachmittag »
Hi pls see the Tuner configuration for Diseqc switch, \
Pls tell me whether is correct or not, if this is incorrect pls give correct instructions
