Autor Thema: Unknown modulation?  (Gelesen 5778 mal)
Tryon
Unknown modulation?
« am: Februar 09, 2017, 10:42:29 Nachmittag »
I know this is unlikely, but some users may encounter undefined modulation in blindscan.
Read signal should display 8-PSK and 16-APSK(although real property names are PSK_8 and APSK_16).
Best part in all this is that somehow it is possible to receive such broadcasts in Tvheadend. 8)
Thanks.
Re:Unknown modulation?
« Antwort #1 am: Februar 10, 2017, 12:27:33 Vormittag »
Where do you see unknown modulation?
Can you put a screenshot online?
Our blindscan does not have unknown modulation implemented as far as I see.
Tryon
« Antwort #2 am: Februar 11, 2017, 08:13:29 Nachmittag »
Thanks. I will wait for next opportunity. In any case, tool will not recognize 16-APSK.
Manual tuning also can be expanded -M modulation (QPSK, 8PSK,...)
Tryon
« Antwort #3 am: Februar 19, 2017, 03:59:53 Nachmittag »
FEC: FEC_AUTO MOD: UNKNOWN VOLTAGE: V(13V) TONE: ONCan we have POL: V instead of voltage?
It is also interesting to read research article about DVB-S2X:
Zitat von: Development of satellite high-definition television in Europe
In order to ensure transmission of the greatest possible number of HDTV and UHDTV channels via satellites, it is necessary to convert the satellite DVB-S transponders to DVB-S2 transponders. Conversion to the 16APSK modulation will result in the increased capacity for HDTV channels. Furthermore, in order to use satellite capacity as cost effectively as possible, the MPEG-4 compression standard should also be used for the transmission of SDTV channels.
