Autor Thema: Fritzbox - Treiber oder was auch immer funktioniert nicht richtig.  (Gelesen 4831 mal)
mm93
« am: Januar 10, 2017, 06:46:15 Nachmittag »
da ich im Chat nun die ganze Zeit gekonnt ignoriert wurde, obwohl mir zugesagt wurde, dass sich heute um das Problem angenommen wird, versuche ich es nochmal auf diesem Weg.
Ich kann den Treiber auf der Fritzbox via Telnet installieren. Versuche ich jedoch dann zu tunen, so erhalte ich folgende Fehler:
# /tmp/opt/bin/mediasrv -v
1970-01-01 01:08:18 [3054] Alsa Blocking on (default)
1970-01-01 01:08:18 [3054] Starting up Multimedia Framework (Dec 31 2016 20:06:4        1)
1970-01-01 01:08:18 [3054] API Version: 5.10
1970-01-01 01:08:18 [3054] Running on Linux (2.6.32.61)
1970-01-01 01:08:18 [3055] Starting service processor (PID 3055)
1970-01-01 01:08:18 [3054] scanning devices
1970-01-01 01:08:18 [3054] scanning for drivers
1970-01-01 01:08:18 [3054] scanning for plugins
1970-01-01 01:08:18 [3054] Starting up device manager
1970-01-01 01:08:18 [3054] scanning devices done
1970-01-01 01:08:18 [3054] attached devices:
1970-01-01 01:08:18 [3055] Autostarting scripts in /etc/sundtek/
1970-01-01 01:08:18 [3055] executed all available items
1970-01-01 01:08:18 [3054] registering ID: 0
1970-01-01 01:08:18 [3054] Memory mapped transfers are not available
1970-01-01 01:08:18 [3054] Using dynamic configuration
1970-01-01 01:08:18 [3054] DTV1 Transfer is set to: Bulk
1970-01-01 01:08:20 [3055] trying to load uinput module
1970-01-01 01:08:20 [3055] loading uinput kernel extention failed, remote contro        l will not work with lirc
1970-01-01 01:08:20 [3054] No remote control support available
1970-01-01 01:08:20 [3054] Allocation using pg for type 65678
1970-01-01 01:08:20 [3054] demodulator successfully attached (DVB_S/S2)!
1970-01-01 01:08:20 [3054] Allocation using pg for type 16
1970-01-01 01:08:20 [3054] Setting up default decoder settings
1970-01-01 01:08:20 [3054] attaching video decoder
1970-01-01 01:08:21 [3054] Configure urbs for bulk
1970-01-01 01:08:21 [3054] Registering OSS emulation
1970-01-01 01:08:21 [3054] registering: adapter0/0
1970-01-01 01:08:21 [3054] registered virtual: /dev/dvb/adapter0/frontend0
1970-01-01 01:08:21 [3054] registered virtual: /dev/dvb/adapter0/demux0
1970-01-01 01:08:21 [3054] registered virtual: /dev/dvb/adapter0/dvr0
1970-01-01 01:08:21 [3054] Unable to create /dev/dsp0 (17/File exists)
1970-01-01 01:08:21 [3054] registered virtual: /dev/dsp0
1970-01-01 01:08:21 [3054] registered virtual: /dev/video1
1970-01-01 01:08:21 [3054] registered virtual: /dev/vbi1
1970-01-01 01:08:21 [3054] Initializing Remote Control Support
1970-01-01 01:08:21 [3054] Unable to create /dev/mediainput0 (17/File exists)
1970-01-01 01:08:21 [3054] registered virtual: /dev/mediainput0
1970-01-01 01:08:21 [3054] Initialized Sundtek SkyTV Ultimate IV
1970-01-01 01:08:21 [3054] Driver loaded within 2258 milliseconds
1970-01-01 01:08:25 [3054] Initial devicescan done, switching detection mode
1970-01-01 01:08:36 [3054] Enabling complete device standby
1970-01-01 01:08:36 [3054] Set Voltage off
1970-01-01 01:08:58 [3054] Waking up device
1970-01-01 01:08:58 [3054] Set Voltage off
1970-01-01 01:08:58 [3054] Switching to Digital TV
1970-01-01 01:08:59 [3054] Set Voltage off
1970-01-01 01:09:00 [3054] Set Voltage Horizontal (18V)
1970-01-01 01:09:00 [3054] Disabling High Tone (22khz)
1970-01-01 01:09:00 [3054] Setting Frequency: 994000
1970-01-01 01:09:00 [3054] Frequency: 994
1970-01-01 01:09:00 [3054] Symbolrate: 22000
1970-01-01 01:09:01 [3054] Checking lock
1970-01-01 01:09:01 [3054] Frontend has locked
1970-01-01 01:09:01 [3054] sending command failed with status ffffffff (Unknown error -1)
1970-01-01 01:09:01 [3054] Set Voltage Vertical (13V)
1970-01-01 01:09:01 [3054] send vendor cmd failed with status --1
1970-01-01 01:09:01 [3054] The device just got disconnected from the system
1970-01-01 01:09:01 [3054] Shutting down this device instance
1970-01-01 01:09:01 [3054] USB Transfer problem, shutting down driver instance (-1 - 19 / 1)/2
1970-01-01 01:09:01 [3054] Abnormal deinitialization, device got disconnected or driver is shutting down
1970-01-01 01:09:01 [3054] Disabling High Tone (22khz)
1970-01-01 01:09:01 [3054] Setting Frequency: 1788000
1970-01-01 01:09:01 [3054] Frequency: 1788
1970-01-01 01:09:01 [3054] Symbolrate: 22000
1970-01-01 01:09:01 [3054] Stopping Remote Control support
1970-01-01 01:09:01 [3054] Enabling complete device standby
1970-01-01 01:09:01 [3054] Set Voltage off
1970-01-01 01:09:01 [3054] clearing id: 0
1970-01-01 01:09:01 [3054] registering ID: 0
1970-01-01 01:09:01 [3054] Memory mapped transfers are not available
1970-01-01 01:09:01 [3054] Using dynamic configuration
1970-01-01 01:09:01 [3054] DTV1 Transfer is set to: Bulk
1970-01-01 01:09:03 [3055] trying to load uinput module
1970-01-01 01:09:03 [3055] loading uinput kernel extention failed, remote control will not work with lirc
1970-01-01 01:09:03 [3054] No remote control support available
1970-01-01 01:09:03 [3054] Allocation using pg for type 65678
1970-01-01 01:09:04 [3054] demodulator successfully attached (DVB_S/S2)!
1970-01-01 01:09:04 [3054] Allocation using pg for type 16
1970-01-01 01:09:04 [3054] Setting up default decoder settings
1970-01-01 01:09:04 [3054] attaching video decoder
1970-01-01 01:09:04 [3054] Configure urbs for bulk
1970-01-01 01:09:04 [3054] Registering OSS emulation
1970-01-01 01:09:04 [3054] registering: adapter0/0
1970-01-01 01:09:04 [3054] registered virtual: /dev/dvb/adapter0/frontend0
1970-01-01 01:09:04 [3054] registered virtual: /dev/dvb/adapter0/demux0
1970-01-01 01:09:04 [3054] registered virtual: /dev/dvb/adapter0/dvr0
1970-01-01 01:09:04 [3054] registered virtual: /dev/dsp0
1970-01-01 01:09:04 [3054] registered virtual: /dev/video1
1970-01-01 01:09:04 [3054] registered virtual: /dev/vbi1
1970-01-01 01:09:04 [3054] Initializing Remote Control Support
1970-01-01 01:09:04 [3054] registered virtual: /dev/mediainput0
1970-01-01 01:09:04 [3054] Initialized Sundtek SkyTV Ultimate IV
1970-01-01 01:09:04 [3054] Driver loaded within 3055 milliseconds
Leider kann ich das Problem nicht eingrenzen, weder bei Google noch selbst kann ich den/die Fehler nachvollziehen.
Ein "ir_disabled=1" in der Config hilft nichts.
Das Log ist kopiert worden, nachdem ich den Befehl
/tmp/opt/bin/mediaclient --testastra -d /dev/dvb/adapter0/frontend0
ausgeführt habe.
# uname -a
Linux fritz.box 2.6.32.61 #1 SMP Tue May 5 11:31:15 CEST 2015 mips GNU/Linux
Das ganze ist für mich notwendig, weil mir zuvor gesagt wurde, dass die Bandbreite meines USB-Passthrough in die virtuelle Maschine nicht ausreichen würde.
Vielen Dank!!!!!!
« Letzte Änderung: Januar 10, 2017, 06:54:14 Nachmittag von mm93 »
mm93
Re:Fritzbox - Treiber oder was auch immer funktioniert nicht richtig.
« Antwort #1 am: Januar 10, 2017, 07:17:15 Nachmittag »
Hier nochmal ein weiterer Auszug aus dem Log:
1970-01-01 01:37:36 [3054] Enabling complete device standby
1970-01-01 01:37:36 [3054] Set Voltage off
1970-01-01 01:38:27 [3054] error submitting urb, retrying (but please check your hardware -1 No such device)
1970-01-01 01:38:27 [3054] URB LENGTH: 32
1970-01-01 01:38:27 [3054] URB TYPE: ISO
1970-01-01 01:38:27 [3054] Decreasing to: 0
1970-01-01 01:38:27 [3054] Error (second time): -1 No such device
1970-01-01 01:38:27 [3054] error submitting urb after second attempt, marking request as not submitted
1970-01-01 01:38:27 [3054] this now very likely leads to stream corruptions
1970-01-01 01:38:27 [3054] The device just got disconnected from the system
1970-01-01 01:38:27 [3054] Shutting down this device instance
1970-01-01 01:38:27 [3054] USB Transfer problem, shutting down driver instance (-1 - 19 / 1)/2
1970-01-01 01:38:27 [3054] Stopping Remote Control support
1970-01-01 01:38:27 [3054] clearing id: 0
1970-01-01 01:38:35 [3054] registering ID: 0
1970-01-01 01:38:35 [3054] Memory mapped transfers are not available
1970-01-01 01:38:35 [3054] Using dynamic configuration
1970-01-01 01:38:35 [3054] DTV1 Transfer is set to: Bulk
1970-01-01 01:38:36 [3055] trying to load uinput module
1970-01-01 01:38:37 [3055] loading uinput kernel extention failed, remote control will not work with lirc
1970-01-01 01:38:37 [3054] No remote control support available
1970-01-01 01:38:37 [3054] Allocation using pg for type 65678
1970-01-01 01:38:37 [3054] demodulator successfully attached (DVB_S/S2)!
1970-01-01 01:38:37 [3054] Allocation using pg for type 16
1970-01-01 01:38:38 [3054] Setting up default decoder settings
1970-01-01 01:38:38 [3054] attaching video decoder
1970-01-01 01:38:38 [3054] Configure urbs for bulk
1970-01-01 01:38:38 [3054] Registering OSS emulation
1970-01-01 01:38:38 [3054] registering: adapter0/0
1970-01-01 01:38:38 [3054] registered virtual: /dev/dvb/adapter0/frontend0
1970-01-01 01:38:38 [3054] registered virtual: /dev/dvb/adapter0/demux0
1970-01-01 01:38:38 [3054] registered virtual: /dev/dvb/adapter0/dvr0
1970-01-01 01:38:38 [3054] registered virtual: /dev/dsp0
1970-01-01 01:38:38 [3054] registered virtual: /dev/video1
1970-01-01 01:38:38 [3054] registered virtual: /dev/vbi1
1970-01-01 01:38:38 [3054] Initializing Remote Control Support
1970-01-01 01:38:38 [3054] registered virtual: /dev/mediainput0
1970-01-01 01:38:38 [3054] Initialized Sundtek SkyTV Ultimate IV
1970-01-01 01:38:38 [3054] Driver loaded within 3132 milliseconds
1970-01-01 01:38:53 [3054] Enabling complete device standby
1970-01-01 01:38:53 [3054] Set Voltage off
Der Treiber scheint immer das Gerät zu verlieren.
Ein Defekt des USB-Ports ist ausgeschlossen, da ich das ganze schon mit zwei Boxen probiert habe. Netzteil und LNB sind dran!
« Antwort #2 am: Januar 23, 2017, 11:33:46 Vormittag »
Um das hier abzuschließen das war ein Problem mit dem USB Kabel.
