Autor Thema: [solved] RPI3 OpenElec + tvheadend + tvheadend client  (Gelesen 18092 mal)
Re:RPI3 OpenElec + tvheadend + tvheadend client
« Antwort #15 am: August 28, 2016, 05:57:13 Nachmittag »
is there any other problem left, other than the PID filters on your system?
I wonder we have tested the PID filters with Settopboxes last time (although our testing was not a long term test only for a few minutes).
I will put this on our TODO list that someone will check it on a Raspberry PI with openelec.
Thanks for your report!
thecyclist
« Antwort #16 am: August 28, 2016, 06:22:28 Nachmittag »
I don't think so - I have just been watching again for about 30mins and the picture is still stable. I am guessing but it could be that the 'PID filters' are not compatible with the RPi's hardware mpeg2 codec in someway; which means that OpenElec drops back to the software mpeg2 codec and hence the blocking and pixelation.
So the solution at the moment, for anyone else experiencing this, is to turn off the hardware PID filters in the sundtek driver add-on configuration in OpenElec.
Thanks for your help!...and can you add a 'Solved' tag to the title of the thread?
JT
