Autor Thema: issue with vu+ solo2 install  (Gelesen 8757 mal)
houlalajaimal
« am: Januar 29, 2016, 04:29:20 Nachmittag »
I've receive my MediaTV pro stick and installed driver on my vu+ solo2 box.
It run on on a blackHole image 2.1.7.
root@vusolo2:~# uname -a
Linux vusolo2 3.13.5 #1 SMP Thu Jun 25 01:46:24 CEST 2015 mips GNU/Linux
I used sundtek_netinst.sh as root thru a ssh session. Installation looks to go fine without any error. But I cannot see any extra tuner in settings/... menu
or with somme command lines
root@vusolo2:~# /opt/bin/mediaclient -e
root@vusolo2:~#
root@vusolo2:~#  cat /proc/bus/nim_sockets
NIM Socket 0:
        Type: DVB-S2
        Name: BCM7356 DVB-S2 NIM (internal)
        Frontend_Device: 0
NIM Socket 1:
        Type: DVB-S2
        Frontend_Device: 1
root@vusolo2:~#
Any idea?
Re:issue with vu+ solo2 install
« Antwort #1 am: Januar 29, 2016, 04:51:47 Nachmittag »
You installed it the "generic" way, this installs the driver but won't register it for your settopbox.
See following link how to set it up for your settopbox (it's much easier than the commandline way):
http://support.sundtek.com/index.php/topic,348.0.html
houlalajaimal
« Antwort #2 am: Januar 29, 2016, 05:20:26 Nachmittag »
Hi dear Sundtek
I've no win or mac computer at home...I have only linux...So I cannot use the click click way.
Thanks
« Antwort #3 am: Januar 29, 2016, 05:43:20 Nachmittag »
Install the Sundtek Controlcenter and install the driver inside it, afterwards configure it inside the Controlcenter Menu.
http://www.sundtek.de/media/enigma2-plugin-extensions-sundtekcontrolcenter_current_all.ipk
houlalajaimal
« Antwort #4 am: Januar 29, 2016, 10:45:13 Nachmittag »
hi,
no chance, it does not work.
during install this message is displayed:
ERROR:ld.so:object'/opt/lib/libmediaclient.so' from LD_PRELOAD cannot be preloaded
Install driver from controlcenter menu give the same message.
Then after that, i'm unable to configure tuner.
in /var/log/mediaclient.log
2016-01-29 20:25:15 [11937] unable to connect to driver (closing: 3 - Connection refused)
and in /var/log/mediasrv.log
No Sundtek device Detected
any idea?
« Antwort #5 am: Januar 30, 2016, 02:01:38 Vormittag »
For some reason you did not install the driver correctly.
This installation works, maybe you had some issues with your internet connection?
After installing the driver you have to reboot the box, after that you should be able to configure it.
You might have to set up autostart there depending on your box.
I don't even think that there's any possibility to get this wrong since it's proven for years, the only bad thing that could happen is bad internet or that you aborted the installation somehow.
« Letzte Änderung: Januar 30, 2016, 02:09:34 Vormittag von Sundtek »
houlalajaimal
« Antwort #6 am: Januar 30, 2016, 11:04:21 Vormittag »
no more chance.
I install plugin as you suggest but stick still not recognized at all.
I try on a vu+ solo2 with backhole image and an openPLi image. No way.
driver version is 2016-01-26 17:13:37
I've also make test on an Ubuntu x64 and the usb stick not recognized too.
Do it need a external power suply ?
« Antwort #7 am: Januar 30, 2016, 12:08:03 Nachmittag »
What does lsusb show up when the tuner is attached?
you can just join http://chat.sundtek.de to go through it quickly
« Letzte Änderung: Januar 30, 2016, 12:40:15 Nachmittag von Sundtek »
houlalajaimal
« Antwort #8 am: Januar 30, 2016, 12:41:38 Nachmittag »
root@vusolo2:~# lsusb -v
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0002
Bus 003 Device 001: ID 1d6b:0002
Bus 004 Device 001: ID 1d6b:0002
Bus 005 Device 001: ID 1d6b:0001
Bus 006 Device 001: ID 1d6b:0001
Bus 007 Device 001: ID 1d6b:0001
Bus 008 Device 001: ID 1d6b:0001
root@vusolo2:~#
« Antwort #9 am: Januar 30, 2016, 12:45:20 Nachmittag »
Did you try to connect it without the USB cable?
lsusb should show up 2659:XXXX (2659 is our USB Vendor ID, XXXX is the Product ID)
« Letzte Änderung: Januar 30, 2016, 12:47:37 Nachmittag von Sundtek »
houlalajaimal
« Antwort #10 am: Januar 30, 2016, 12:58:28 Nachmittag »
it is connected direclty on usb port
« Antwort #11 am: Januar 30, 2016, 01:03:33 Nachmittag »
That's very weird, try to use it with a USB cable then.
please join the chatroom in order to doublecheck that the system is ok.
All tuners are tested before shipping them out.
houlalajaimal
« Antwort #12 am: Januar 30, 2016, 04:06:16 Nachmittag »
tested with ou without usb cable. Not recognized at all on all my nix computers/boxes
I'm on chat now
