Autor Thema: Install driver fails on banana pi running bananian (debian wheezy)  (Gelesen 5607 mal)
albino71
« am: Januar 06, 2016, 10:11:06 Nachmittag »
It looks like it's installing the driver, but afterwards it's not installed.
./sundtek_netinst.sh
unpacking...
checking system... ARM SYSV HF System detected
Downloading architecture specific driver ... armsysvhf
Starting driver...
done.
/opt/bin/mediaclient -e
dpkg -i sundtek-netinst-driver.deb
Selecting previously unselected package sundtek-netinst-driver.
(Reading database ... 29297 files and directories currently installed.)
Unpacking sundtek-netinst-driver (from sundtek-netinst-driver.deb) ...
rm: cannot remove `sundtek_netinst.sh': No such file or directory
--2016-01-06 21:07:51--  http://www.sundtek.de/media/sundtek_netinst.sh
Resolving www.sundtek.de (www.sundtek.de)... 85.10.198.106
Connecting to www.sundtek.de (www.sundtek.de)|85.10.198.106|:80... connected.
Length: 122987 (120K) [text/x-sh]
Saving to: `sundtek_netinst.sh'
100%[======================================>] 122,987     --.-K/s   in 0.09s
2016-01-06 21:07:51 (1.24 MB/s) - `sundtek_netinst.sh' saved [122987/122987]
(C)opyright 2008-2015 Sundtek <kontakt@sundtek.de>
Legal notice:
Nutzungsbedingungen:
Wollen Sie fortfahren [J/N]:
AUTO_INST is set
unpacking...
Starting driver...
done.
Setting up sundtek-netinst-driver (1.0) ...
Still nothing...
Re:Install driver fails on banana pi running bananian (debian wheezy)
« Antwort #1 am: Januar 06, 2016, 10:13:11 Nachmittag »
The driver installation is ok -- the driver is installed successfully.
what does the command "lsusb" show up?
If mediaclient -e shows up List of Media Hardware Devices only that means that the device is not recognised by the system at all.
First the device needs to be recognised by the system - afterwards the driver will load and attach to it.
Try to use a different USB Port.
« Letzte Änderung: Januar 06, 2016, 10:21:37 Nachmittag von Sundtek »
albino71
« Antwort #2 am: Januar 06, 2016, 10:22:44 Nachmittag »
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
It's not recognising the stick is it?
edit: That's it. Tried the other port already. Also not working..... Any way to solve this?
edit2: Let me try some USB sticks. Just to check if there is not something wrong with my build.
edit3; Getting help via IRC also now, so hold on :)
« Letzte Änderung: Januar 06, 2016, 10:45:16 Nachmittag von albino71 »
« Antwort #3 am: Januar 06, 2016, 10:56:55 Nachmittag »
The device is not recognized by the system if it's not displayed with "lsusb".
But as you wrote in the chat other USB Devices were not recognized either; that could have several root causes on your side.
lsusb needs to show up something like that
Bus 002 Device 007: ID 2659:1401 Sundtek
Your problems could be:
* Faulty USB Controller (onboard of this banana pi) driver
* Faulty USB Controller (onboard of this banana pi) hardware
* Faulty USB Controller (onboard of this banana pi) settings
it's yet not related to our USB tuner.
albino71
« Antwort #4 am: Januar 06, 2016, 11:00:04 Nachmittag »
dmesg output
[    0.435981] WRN:L287(drivers/usb/sunxi_usb/manager/usb_manager.c):ERR: det_vbus pin is invaild
[    0.443298] WRN:L426(drivers/usb/sunxi_usb/manager/usb_manager.c):ERR: check_usb_board_info failed
[    0.450981] WRN:L480(drivers/usb/sunxi_usb/manager/usb_manager.c):ERR: get_usb_cfg failed
I'm gonna try another linux and report back
albino71
« Antwort #5 am: Januar 07, 2016, 12:26:51 Vormittag »
Seems the USB ports have died on me...
Sundtek is now attached to a Rpi 2 and shared from there.
Great help via the IRC channel!
