Autor Thema: Vu+ Duo2 Tuner B problem with Sundtek as Tuner C  (Gelesen 11303 mal)
CuriousCorn
  • Gast
« am: Februar 10, 2015, 11:29:52 Vormittag »
Hi all,
I see that my issue has been discussed before, but the thread concerned did not give any final conclusion. So, I start a new thread.
I have a Vu+ Duo2 with the OpenPLI 4.0 latest image, with a USB Sundtek tuner installed as Tuner C and the latest Sundtek drivers installed.
All of the tuners (the two internal ones, A & B and the Sundtek, C) should be allocated to DVB-C.
But, Tuner C (Sundtek) appears to be in conflict with the internal Tuner B. If I set Tuner C to be DVB-C, then Tuner B resets itself as DVB-T (which is of no use), with the result that Tuner B then fails with "Tune Failed"
If I then set Tuner B as DVB-C, Tuner C then resets itself to DVB-T2..
As a result, I cannot seem to be able to set all three tuners to DVB-C! At one point, I was able to set all three as DVB-C, but then after a hard reboot, Tuner B came up as DVB-T. But, when I go into Tuner Configuration and select Tuner B it says it's DVB-C (which it is not). To get it back, I have to set it to DVB-T, click OK, then select DVB-C again. But then Tuner C goes to DVB-T!
I have re-installed the Sundtek drivers, but this made no difference.
Is there somewhere a configuration conflict, or something? Possibility that it's something on Sundtek's side? Might seem likely, given what I have to do to get Tuner B back to DVB-C. Why would Tuner B suddenly re-invent itself as DVB-T after a reboot?
I removed the Sundtek USB tuner last night, and then Tuners A and B were fine; both on DVB-C. I put the Sundtek back in, and then Tuner B got unhappy and went to DVB-T!
Please advise if I should send any further information that may be useful, or if you have any advice as to what I could do.
Thanks in advance and best regards,
CuriousCorn
Re:Vu+ Duo2 Tuner B problem with Sundtek as Tuner C
« Antwort #1 am: Februar 10, 2015, 11:41:08 Vormittag »
Did you install the driver using the Windows-Settopbox Installer?
Can you show us the output of following telnet command on the Settopbox
cat /proc/bus/nim_sockets
when things are not as you would expect them to be?
CuriousCorn
  • Gast
« Antwort #2 am: Februar 10, 2015, 06:34:29 Nachmittag »
Hi Sundtek,
I did the installation with the Mac OS X installer.
Output from cat /proc/bus/nim_sockets (With Sundtek attached; Tuner B is showing DVB-T):
root@vuduo2:~# cat /proc/bus/nim_sockets
NIM Socket 0:
        Type: DVB-C
        Name: Vuplus DVB-C NIM(CXD1978)
        Mode 0: DVB-C
        Mode 1: DVB-T
        Frontend_Device: 0
        I2C_Device: 2
NIM Socket 1:
        Type: DVB-T
        Name: Vuplus DVB-T NIM(CXD1978)
        Mode 0: DVB-C
        Mode 1: DVB-T
        Frontend_Device: 1
        I2C_Device: 3
NIM Socket 2:
        Type: DVB-C
        Name: Sundtek DVB-C (III) (0/0) (USB)
        Frontend_Device: 2
This is the output when I set Tuner B to be DVB-C:
NIM Socket 0:
        Type: DVB-C
        Mode 0: DVB-C
        Mode 1: DVB-T
        Frontend_Device: 0
        I2C_Device: 2
NIM Socket 1:
        Type: DVB-C
        Mode 0: DVB-C
        Mode 1: DVB-T
        Frontend_Device: 1
        I2C_Device: 3
NIM Socket 2:
        Type: DVB-C
        Frontend_Device: 2
This is the same, but after a reboot:
NIM Socket 0:
        Type: DVB-C
        Mode 0: DVB-C
        Mode 1: DVB-T
        Frontend_Device: 0
        I2C_Device: 2
NIM Socket 1:
        Type: DVB-T
        Mode 0: DVB-C
        Mode 1: DVB-T
        Frontend_Device: 1
        I2C_Device: 3
NIM Socket 2:
        Type: DVB-C
        Frontend_Device: 2
Thanks and best regards.
CuriousCorn
  • Gast
« Antwort #3 am: Februar 10, 2015, 06:35:32 Nachmittag »
And just for completeness, here is the output of medicament -e
root@vuduo2:~# mediaclient -e
  [DVB-T2]:
« Antwort #4 am: Februar 10, 2015, 07:31:54 Nachmittag »
Ok, this is very likely a topic for an OpenPLI developer. I forwarded it to pieterg in the openpli forum since he seems to be involved with the latest OpenPLI changes.
CuriousCorn
  • Gast
« Antwort #5 am: Februar 10, 2015, 08:16:54 Nachmittag »
OK, thanks, let's see what happens  :)
« Antwort #6 am: Februar 10, 2015, 08:21:57 Nachmittag »
http://forums.openpli.org/topic/36922-vuduo2-tuner-b-resetting-to-dvb-t-after-reboot/?hl=sundtek
let's stop this discussion here and continue in the openpli Forum with that, I think this is something that might affect OpenPLI and not our tuners but let's see.
Better to have the other guys involved.
For the record:
seems like this issue has been in the forum already but your post gives most details about the problem so far:
http://support.sundtek.com/index.php/topic,1647.0.html
« Letzte Änderung: Februar 11, 2015, 12:02:19 Nachmittag von Sundtek »
