Autor Thema: Sky Ultimate IV an ipfire mit VDR  (Gelesen 32538 mal)
reverend666
Re:Sky Ultimate IV an ipfire mit VDR
« Antwort #30 am: Februar 16, 2015, 01:02:15 Vormittag »
[root@ipFIRE bin]# ./mediasrv -v
2015-02-15 23:49:40 [17181] Alsa Blocking on (default)
2015-02-15 23:49:40 [17181] Starting up Multimedia Framework (Feb 15 2015 19:26:06)
2015-02-15 23:49:40 [17181] API Version: 5.10
2015-02-15 23:49:40 [17181] Running on Linux (3.10.44-ipfire-pae)
2015-02-15 23:49:40 [17181] Detected: AuthenticAMD
2015-02-15 23:49:40 [17181] This CPU supports: MMX, SSE, SSE2
2015-02-15 23:49:40 [17181] scanning devices
2015-02-15 23:49:40 [17181] Scanning for drivers
2015-02-15 23:49:40 [17181] found lib: libdrv_em28xx.so
2015-02-15 23:49:40 [17181] found lib: libdrv_tntdvb.so
2015-02-15 23:49:40 [17182] Starting service processor (PID 17182)
2015-02-15 23:49:40 [17181] found lib: libdrv_ngTV.so
2015-02-15 23:49:40 [17181] found lib: libdrv_fm.so
2015-02-15 23:49:40 [17181] found lib: libdrv_hikarisoft_isdb.so
2015-02-15 23:49:40 [17181] found lib: libdrv_net.so
2015-02-15 23:49:40 [17181] found lib: libdrv_vivi.so
2015-02-15 23:49:40 [17181] Scanning for plugins
2015-02-15 23:49:40 [17181] found lib: libencoder_plugin.so
2015-02-15 23:49:40 [17181] MediaAVPlugin: MPEG Encoder
2015-02-15 23:49:40 [17181] Copyright: (C) Tpe 2011/2012
2015-02-15 23:49:40 [17181] pthread_create() error 1, Operation not permitted
2015-02-15 23:49:40 [17181] Starting up device manager
2015-02-15 23:49:40 [17181] scanning devices done
2015-02-15 23:49:40 [17181] attached devices:
2015-02-15 23:49:40 [17182] Autostarting scripts in /etc/sundtek/
2015-02-15 23:49:40 [17182] executed all available items
das Verzeichnis /etc/sundtek ist auf meinem System gar nicht vorhanden
« Antwort #31 am: Februar 16, 2015, 01:17:26 Vormittag »
/etc/sundtek ist ein kleines Helper Verzeichnis, die Skripte die man dort ablegt werden vom Treiber automatisch gestartet - sobald der Treiber gestartet wird.
Warum der Thread nicht erstellt werden kann ist die Frage, sobald du Remote Zugriff eingerichtet hast würde ich mir das gerne noch einmal genauer ansehen.
Was zeigt denn folgender Befehl an?
/opt/bin/mediaclient --arch
« Letzte Änderung: Februar 16, 2015, 01:20:43 Vormittag von Sundtek »
reverend666
« Antwort #32 am: Februar 16, 2015, 01:22:04 Vormittag »
Architecture: 32bit
« Antwort #33 am: Februar 16, 2015, 01:28:51 Vormittag »
Hast du den aktuellen Netinstaller heruntergeladen?
http://sundtek.de/media/sundtek_netinst.sh
Wenn du einfach ein wget ausführst und der alte Installer noch vorhanden ist wird eine .1 hinter dem neuen Download angehängt
bash-4.3# chmod 777 sundtek_netinst.sh
bash-4.3# ./sundtek_netinst.sh
(C)opyright 2008-2014 Sundtek <kontakt... sundtek.de>
unpacking...
checking system... overriding SYSTEM parameter with 32bit-ipfire
Downloading architecture specific driver ... 32bit-ipfire
Starting driver...
done.
bash-4.3#
bash-4.3# /opt/bin/mediaclient --arch
Architecture: 32bit-ipfire
« Letzte Änderung: Februar 16, 2015, 01:35:56 Vormittag von Sundtek »
reverend666
« Antwort #34 am: Februar 16, 2015, 01:42:16 Vormittag »
Habe den aktuellsten heruntergeladen?
Welche ipFire Version habt ihr denn vor euch?
Wollen Sie fortfahren [J/N]:
J
unpacking...
checking system... ./sundtek_netinst.sh: line 655: /tmp/.sundtek/chk32bit-ipfire: No such file or directory
testing libc OK 2.12.0
32Bit System detected
Starting driver...
done.
dieses 32Bit-ipfire
wird bei mir ja gar nicht angezeigt
« Letzte Änderung: Februar 16, 2015, 01:44:25 Vormittag von reverend666 »
« Antwort #35 am: Februar 16, 2015, 01:48:34 Vormittag »
das ist noch ein alter Netinstaller, wo der IPFire Support noch gefehlt hat.
Das ist der neue: ->
Lösche sundtek_netinst* und:
rm -rf sundtek_netinst.sh
./sundtek_netinst.sh -easyvdr
Ich denke das klappt alles, VDR sollte auf dem IPFire Image auch funktionieren.
« Letzte Änderung: Februar 16, 2015, 01:51:13 Vormittag von Sundtek »
reverend666
« Antwort #36 am: Februar 16, 2015, 01:54:21 Vormittag »
Irgendwas scheint da nicht in Ordnung zu sein.
[root@ipFIRE tmp]# ./sundtek_netinst.sh -easyvdr
(C)opyright 2008-2014 Sundtek <kontakt@sundtek.de>
Legal notice:
Nutzungsbedingungen:
AUTO_INST is set
unpacking...
Starting driver...
done.
[root@ipFIRE tmp]#
reverend666
« Antwort #37 am: Februar 16, 2015, 01:56:21 Vormittag »
Habe gerade per wget den netins heruntergeladen...
irgendwas scheint da doch nicht zu funzen...
lade ich immer von einer alten quelle?
habt ihr noch eine andere download möglichkeit?
« Antwort #38 am: Februar 16, 2015, 02:02:37 Vormittag »
Falls du cachest...
wget "http://sundtek.de/media/sundtek_netinst.sh?1234"
md5sum sundtek_netinst.sh
5216711....350c9
reverend666
« Antwort #39 am: Februar 16, 2015, 02:08:46 Vormittag »
Falls du cachest...
5216711....350c9
Keine Änderung....
hilft das weiter?
[root@ipFIRE tmp]# uname -ar
Linux ipFIRE 3.10.44-ipfire-pae #1 SMP Mon Jun 23 23:23:33 GMT 2014 i686 athlon-4 i386 GNU/Li
reverend666
« Antwort #40 am: Februar 16, 2015, 02:10:36 Vormittag »
Kann ich nicht direkt den Treiber für ipfire herunterladen?
Ohne diese Prüfung?
Vielleicht erkennt der mir nicht die Architektur.
« Antwort #41 am: Februar 16, 2015, 02:12:20 Vormittag »
Einfacher geht's nicht, herunterladen und ausführen kann jedes Kind.
Überprüfe ob die MD5Summe Deines Downloads übereinstimmt.
bash-4.3# md5sum sundtek_netinst.sh
5216711f23d5b4896990df6cf0e350c9  sundtek_netinst.sh
reverend666
« Antwort #42 am: Februar 16, 2015, 02:14:48 Vormittag »
[root@ipFIRE tmp]# md5sum sundtek_netinst.sh
« Antwort #43 am: Februar 16, 2015, 02:16:25 Vormittag »
Ja und jetzt starten?
sh sundtek_netinst.sh
oder
reverend666
« Antwort #44 am: Februar 16, 2015, 02:17:26 Vormittag »
J
unpacking...
Starting driver...
done.
SOrry das mache ich ja die ganze Zeit auch so
edit2: entweder liegt es an meinem IPFire 2.15 Core 86 oder an was anderem.
« Letzte Änderung: Februar 16, 2015, 02:18:59 Vormittag von reverend666 »
