Autor Thema: Blindscan on VU+ Solo2 with OpenPLI image  (Gelesen 57846 mal)
Dima73
Re:Blindscan on VU+ Solo2 with OpenPLI image
« Antwort #15 am: April 08, 2016, 12:32:20 Nachmittag »
Thanks for the help.
But still full information would be more practical to get by for --blindscan [nim_socket]
Or add a response from drivers:
/opt/bin/mediaclient --frontend [nim_socket]
return /dev/dvb/adapterN/frontend0
« Antwort #16 am: April 08, 2016, 04:57:56 Nachmittag »
I think you can just figure it out by doing cat /proc/bus/nim_sockets
it will show you nim_socket and the frontend number
The frontend number you can connect with /dev/dvb/adapter/frontendN
which you should be able to use with blindscan as well.
Dima73
« Antwort #17 am: April 08, 2016, 06:03:38 Nachmittag »
Super
root@et8500:~# /opt/bin/mediaclient  --blindscan /dev/dvb/adapter0/frontend4
MODE: DVB-T FREQUENCY: 474000000 BANDWIDTH: 8000000
MODE: DVB-T FREQUENCY: 490000000 BANDWIDTH: 8000000
^C
root@et8500:~# /opt/bin/mediaclient  --blindscan /dev/dvb/adapter0/frontend5
Scanning 13V Lowband
MODE: DVB-S  FREQUENCY(MHz): 10718 SYMBOL_RATE: 27500 MODULATION: QPSK VOLTAGE: 13V TONE: OFF
MODE: DVB-S2 FREQUENCY(MHz): 10757 SYMBOL_RATE: 27499 MODULATION: PSK8 VOLTAGE: 13V TONE: OFF
MODE: DVB-S2 FREQUENCY(MHz): 10795 SYMBOL_RATE: 27500 MODULATION: PSK8 VOLTAGE: 13V TONE: OFF
^C
Dima73
« Antwort #18 am: April 08, 2016, 10:45:46 Nachmittag »
There is one problem.
Earlier, last year, each scan line ends '\n'
Now it's one line.
And
MODE: DVB-S2 FREQUENCY(MHz): 10757 SYMBOL_RATE: 27499 MODULATION: PSK8 VOLTAGE: 13V TONE: OFFPSK8 need 8PSK
Dima73
« Antwort #19 am: April 09, 2016, 11:14:34 Vormittag »
Please help, give me a command response DVB-C mode,I do not use DVB-C:
1)
/opt/bin/mediaclient --blindscan [nim_socket]
2)
/opt/bin/mediaclient --blindscan /dev/dvb/adapter0/frontend[nim_socket]
First, see [nim_socket]:
« Antwort #20 am: April 09, 2016, 11:41:55 Vormittag »
I don't understand, we already have support for
/opt/bin/mediaclient --blindscan [nimsocket]
The modes and everything can either be picked up from /proc/bus/nim_sockets or the python structures itself within enigma2
Dima73
« Antwort #21 am: April 09, 2016, 03:36:07 Nachmittag »
I have to compare the answers DVB-C mode.
Dima73
« Antwort #22 am: April 09, 2016, 10:33:35 Nachmittag »
Universal LNB
Scanning 18V Lowband
OK 1024288 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
That's right?
FREQUENCY: 1024288+9750000
Polarisation: Horizontal
Tryon
« Antwort #23 am: April 10, 2016, 10:34:31 Nachmittag »
Super
^C
^C
Cleaner output?
root@et8500:~# mediaclient  --blindscan /dev/dvb/adapter0/frontend4
MODE   FREQUENCY    BANDWIDTH
DVB-T  474.000        8
DVB-T  490.000        8
^C
root@et8500:~# mediaclient  --blindscan /dev/dvb/adapter0/frontend5
Scanning 13V Lowband(TONE: OFF)
MODE   FREQUENCY(MHz) SYMBOL_RATE   POL     MODULATION
DVB-S     10718         27500        V       QPSK
DVB-S2    10757         27499        V       8PSK
DVB-S2    10795         27500        V       8PSK
^C
Can you confirm overlap of some results(like 11824 both in Lowband and highband)?
Also add option for scanning only 1 band(--range VL)?
« Letzte Änderung: April 10, 2016, 10:52:54 Nachmittag von Tryon »
« Antwort #24 am: April 10, 2016, 10:55:18 Nachmittag »
which satellite?
I haven't noticed any overlapping results but I'm mainly using Astra 19.2 at Sundtek (though others could be used)
we certainly can do that, there are some more updates coming including a nice small streamingserver.
Dima73
« Antwort #25 am: April 11, 2016, 06:49:58 Vormittag »
yes,full scan 13e
root@et8500:~# /opt/bin/mediaclient  --blindscan 5
waiting for 1 seconds
OK 968531 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1006579 27499 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1045411 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1083876 27501 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1121689 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1199053 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1241576 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1283529 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1366119 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1407853 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1449517 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1527929 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1565821 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1642485 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1719620 27501 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1758435 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1790734 22000 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1834496 29899 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1873110 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1911252 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1976636 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 2053649 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 2091872 29901 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
scan took 35899 ms (found 23 muxes)
OK 977039 30000 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1064483 27501 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1102519 29900 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1141275 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1179779 30000 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1220971 29700 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1262442 29901 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1304004 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1344848 29901 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1387013 27499 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1583393 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1659924 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1699306 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1737222 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1853449 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1891774 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1930355 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1996403 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 2034334 29899 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 2073045 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
scan took 33276 ms (found 21 muxes)
Scanning 13V Highband
OK 985159 29901 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1023445 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1061877 27501 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1127794 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1165629 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1242792 29899 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1281108 27499 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1319362 29899 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1357169 27501 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1472277 29900 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1587338 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1626211 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1702675 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1741065 29899 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1779255 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1817391 29901 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1865801 29900 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1919845 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1957901 27499 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1996884 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
scan took 35692 ms (found 20 muxes)
Scanning 18V Highband
OK 1004153 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1042628 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1080693 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1146236 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1185000 29900 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1223392 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1261954 29901 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1300078 29900 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1337908 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1376715 29900 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1453236 29901 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1491829 29900 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1530255 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1568463 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1606407 29900 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1645320 29899 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1683136 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1721839 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1759809 29900 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1837006 29899 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1875705 29900 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1976975 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 2053411 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 2092282 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
scan took 34548 ms (found 24 muxes)
After channel scan for this frequency there a lot of wrong services.
When zap to on such a service,show message "Service not found!\n(SID not found in PAT)"
« Letzte Änderung: April 11, 2016, 06:51:38 Vormittag von Dima73 »
Dima73
« Antwort #26 am: April 11, 2016, 07:55:08 Vormittag »
The principle is (universal lnb):
OK frequency 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
13V Lowband
Frequency: frequency KHz+9750000
Polarisation: vertical
13V Highband
Frequency: frequency KHz+10600000
18V Lowband
Polarisation: horizontal
18V Highband
That's right?
« Letzte Änderung: April 11, 2016, 07:59:25 Vormittag von Dima73 »
« Antwort #27 am: April 11, 2016, 12:29:11 Nachmittag »
Should be right that way, the blindscan is okay we have tested this. If you get wrong channels then you have probably saved the wrong values (maybe mixed up KHz with MHz somewhere?)
Dima73
« Antwort #28 am: April 14, 2016, 09:32:02 Vormittag »
Ок,this solved.
Next big problem...
example:
We are aware of only three values-->frequency,symbol rate, polarisation
orbpos
For enigma2 service scan need this values:
transponder = (frequency, symbolrate, polarisation, fec, inversion, orbpos, system, modulation, rolloff, pilot, tsid, onid)Substitute all the values automatically.
+ parm = eDVBFrontendParametersSatellite()
+ parm.orbital_position = self.orb_position
+ parm.polarisation = self.Sundtek_pol
+ frequency = ((int(data[1]) + self.offset) / 1000) * 1000
+ parm.frequency = frequency
+ symbol_rate = int(data[2]) * 1000
+ parm.symbol_rate = symbol_rate
+ parm.system = parm.System_DVB_S
+ parm.inversion = parm.Inversion_Off
+ parm.pilot = parm.Pilot_Off
+ parm.fec = parm.FEC_Auto
+ parm.modulation = parm.Modulation_QPSK
+ parm.rolloff = parm.RollOff_alpha_0_35
+ self.tmp_tplist.append(parm)
After scan tuner (sundtek sky tv ultimate 5) --> 0 channels found
After scan any internal tuner  --> more channels found (all values is same)
So.
It is a bug in the sundtek drivers.
« Letzte Änderung: April 14, 2016, 09:35:47 Vormittag von Dima73 »
« Antwort #29 am: April 14, 2016, 12:30:21 Nachmittag »
I see what you mean the values are incomplete compared with the "native scan" using adapterN/frontendN
I think that output is derived from the DVB-C scan, it will be updated with the next version.
The next version should be available around next week (due other updates as well).
