Autor Thema: Blindscan on VU+ Solo2 with OpenPLI image  (Gelesen 58277 mal)
v1c10u5
« am: Februar 01, 2015, 08:14:59 Nachmittag »
Hello,
I recently purchased your your MediaTV Digital Home and managed to install it succesfully on my VU+ solo2 running the latest OpenPLI image.
Currently the only option to scan for channels is through the Manual scan.
The Automatic scan is giving me:"ERROR - failed to scan (error starting scanning)!".
Blindscan 1.4 and Fast scan are not recognizing the DVB-C tuner in the Tuner option inside the plugin. (I can only scan the built-in Tuner A and Tuner B).
Any ideas what i'm doing wrong or how can i get the blindscan plugin to recognize your usb tuner?
Thanks in advance,
Re:Blindscan on VU+ Solo2 with OpenPLI image
« Antwort #1 am: Februar 01, 2015, 11:51:16 Nachmittag »
Blindscan is not supported by external tuners at the moment, we will release an update within the next 1-2 Weeks which finally will add support for this.
For now you need to scan one frequency manually and enable the network scan. This should discover all Transponders in your network.
Please note even we add support for Blindscan in the near future this will only work with tuners from 2014 on (earlier versions do not have hardware support for that).
v1c10u5
« Antwort #2 am: Februar 02, 2015, 02:12:04 Nachmittag »
Thank you for the fast and informative reply.
Do you by any chance know how i could check if my solo2 hardware supports blindscan or not?
And also do you have any idea why the Automatic scan is giving me an error message?
« Letzte Änderung: Februar 02, 2015, 04:21:37 Nachmittag von v1c10u5 »
« Antwort #3 am: Februar 02, 2015, 11:18:19 Nachmittag »
When did you buy the Tuner?
All tuners from 2014 support Blindscan.
« Antwort #4 am: April 08, 2015, 05:09:09 Nachmittag »
Blindscan support is available with the latest driver update.
Dima73
« Antwort #5 am: April 07, 2016, 07:13:47 Nachmittag »
openpli 4 et8500
et8500 login: root
root@et8500:~# /opt/bin/mediaclient  --blindscan 5
waiting for 1 seconds
Scanning 13V Lowband
OK 968531 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1006579 27499 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1045411 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1083876 27501 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1121689 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1199053 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1241576 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1283529 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1366119 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1407853 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1449517 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1527929 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1565821 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1642485 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1719620 27501 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1758435 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1790734 22000 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1834496 29899 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1873110 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1911252 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1976636 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 2053649 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 2091872 29901 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
scan took 35899 ms (found 23 muxes)
Scanning 18V Lowband
OK 977039 30000 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1024288 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1064483 27501 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1102519 29900 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1141275 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1179779 30000 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1220971 29700 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1262442 29901 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1304004 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1344848 29901 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1387013 27499 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1583393 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1659924 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1699306 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1737222 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1853449 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1891774 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1930355 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1996403 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 2034334 29899 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 2073045 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
scan took 33276 ms (found 21 muxes)
Scanning 13V Highband
OK 985159 29901 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1023445 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1061877 27501 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1127794 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1165629 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1242792 29899 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1281108 27499 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1319362 29899 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1357169 27501 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1472277 29900 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1587338 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1626211 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1702675 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1741065 29899 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1779255 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1817391 29901 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1865801 29900 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1919845 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1957901 27499 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1996884 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
scan took 35692 ms (found 20 muxes)
Scanning 18V Highband
OK 1004153 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1042628 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1080693 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1146236 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1185000 29900 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1223392 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1261954 29901 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1300078 29900 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1337908 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1376715 29900 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1453236 29901 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1491829 29900 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1530255 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1568463 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1606407 29900 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1645320 29899 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1683136 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1721839 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1759809 29900 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1837006 29899 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1875705 29900 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 1976975 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 2053411 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
OK 2092282 27500 FEC_AUTO NOT_IMPLEMENTED INVERSION_OFF
scan took 34548 ms (found 24 muxes)
root@et8500:~#
scaning sat 13e
Question what is the frequency?
The second column?
« Antwort #6 am: April 07, 2016, 07:39:08 Nachmittag »
Is that Ku-Band? The frequency is usually the second column. The third column is the symbol rate.
Dima73
« Antwort #7 am: April 07, 2016, 07:45:35 Nachmittag »
Yes Ku band 13E
In the second column the wrong digit.
if freq < 4201000 and freq > 2999000 :
band = 'C'
self.is_c_band_scan = True
elif freq < 12751000 and freq > 10700000 :
band = 'Ku'
« Antwort #8 am: April 07, 2016, 08:14:45 Nachmittag »
It depends how you scan, I see that the value is in the intermediate band 950-2150 MHz you need to re-calculate it by yourself.
/opt/bin/mediaclient --blindscan /dev/dvb/adapter1/frontend0 will retrieve the Ku-Band frequencies.
Dima73
« Antwort #9 am: April 07, 2016, 08:21:16 Nachmittag »
/dev/dvb/adapter1/frontend0 busy DVB-T
root@et8500:~# /opt/bin/mediaclient --blindscan /dev/dvb/adapter1/frontend0
MODE: DVB-T FREQUENCY: 474000000 BANDWIDTH: 8000000
MODE: DVB-T FREQUENCY: 490000000 BANDWIDTH: 8000000
^C
Please write re-calculate command :)
« Antwort #10 am: April 07, 2016, 09:57:00 Nachmittag »
What does /opt/bin/mediaclient -e show up? I guess you have more than one tuner attached.
I guess you have used the wrong tuner. try adapter2 then possibly.
« Letzte Änderung: April 08, 2016, 12:06:28 Vormittag von Sundtek »
Dima73
« Antwort #11 am: April 08, 2016, 07:13:41 Vormittag »
oot@et8500:~# /opt/bin/mediaclient -e
  [DVB-T2]:
device 1: [Sundtek SkyTV Ultimate V (2015)]  DVB-S/S2, ANALOG-TV, REMOTE-CONTROL, OSS-AUDIO
     FESTATUS: STANDBY
     LNBVOLTAGE: DISABLED
     LNBSUPPLY: ACADAPTER
     DVR: /dev/dvb/adapter2/dvr0
     DMX: /dev/dvb/adapter2/demux0
     INPUT0: /dev/mediainput1
root@et8500:~#
ok,excellent answers
root@et8500:~# /opt/bin/mediaclient --blindscan /dev/dvb/adapter2/frontend0
MODE: DVB-S  FREQUENCY(MHz): 10718 SYMBOL_RATE: 27500 MODULATION: QPSK VOLTAGE: 13V TONE: OFF
MODE: DVB-S2 FREQUENCY(MHz): 10756 SYMBOL_RATE: 27499 MODULATION: PSK8 VOLTAGE: 13V TONE: OFF
MODE: DVB-S2 FREQUENCY(MHz): 10795 SYMBOL_RATE: 27500 MODULATION: PSK8 VOLTAGE: 13V TONE: OFF
MODE: DVB-S2 FREQUENCY(MHz): 10833 SYMBOL_RATE: 27500 MODULATION: PSK8 VOLTAGE: 13V TONE: OFF
But...
I need this format for --blindscan [nim_socket]
I make support Sundtek in  plugin Blind scan.
Guess the number adapter[1? 2? 3? or 4???] can not be.
« Antwort #12 am: April 08, 2016, 09:43:45 Vormittag »
I think it is better to calculate it by yourself
                                                if(strcasecmp(band, "C-BAND")==0) {
                                                        frequency = 5150000-feparm.frequency;
                                                } else if(strcasecmp(band, "UNIVERSAL")==0) {
                                                        if (tone == SEC_TONE_ON) {
        frequency=feparm.frequency+10600000;
                                                        } else {
        frequency=feparm.frequency+9750000;
                                                } else {
There's C-band and Ku-band
Low Band V = 13V No tone
Low Band H = 18V No tone
High Band V = 13V + 22khz tone
High Band H = 18V + 22khz tone
edit: copied the wrong code snippet, the current one shows you how to calculate the frequency
« Letzte Änderung: April 08, 2016, 10:25:18 Vormittag von Sundtek »
Dima73
« Antwort #13 am: April 08, 2016, 10:29:28 Vormittag »
Sorry, this is С++.
I need Python code.
C-BAND? where does this matter?
this is egual value.Only different formats.
is 968531 need 10718 why?
« Antwort #14 am: April 08, 2016, 11:06:06 Vormittag »
C-Band is used in America, we also have users in the United States and Canada who use Settopboxes.
For Ku-Band:
it says 10718 MHz
while
is in KHz
10718XXX KHz = 968531 KHz + 9750000 (=10718531) -- since tone is off you only need to add 9750000, if tone would be on you would need to add 10600000
It's about the calculation itself and that one should be clear (regardless of the programming language).
For C-Band you need to calculate it that way:
cband_frequency = 5150000-tuner_frequency;
the tuner_frequency is always between 950 - 2150 MHz (950.000 - 2150.000 KHz)
This is an example for a C-Band Satellite:
http://www.lyngsat.com/Telkom-1.html
see the frequency they are comparable low compared with the Ku-Band Satellites.
« Letzte Änderung: April 08, 2016, 11:12:14 Vormittag von Sundtek »
