Autor Thema: Boot takes 3 minutes after installing Sundtek USB DVB-S2 driver  (Gelesen 7208 mal)
MikeT23
« am: Dezember 06, 2014, 08:08:44 Nachmittag »
I have recently updated to OpenSuse 13.2 (complete re-installation) on a 64 bit computer.
After I installed the Sundtek driver for my Sundtek USB DVB-S/S2, booting now takes
3 minutes. If I remove the driver, the boot process is again very fast. With
the same device on the same computer running OpenSuse 12.2, I had no problems, it
installed easily & had no problems.
Can anyone please help or advise what to do?
The boot.log contains:
g for udev Wait for Complete Device Initialization (55s / 2min 59s)
[  *** ] A start job is running for udev Wait for Complete Device Initialization (56s / 2min 59s)
[   ***] A start job is running for udev Wait for Complete Device Initialization (56s / 2min 59s)
[    **] A start job is running for udev Wait for Complete Device Initialization (57s / 2min 59s)
[     *] A start job is running for udev Wait for Complete Device Initialization (57s / 2min 59s)
..... the same for 3 minutes ....
[ ***  ] A start job is running for udev Wait for Complete Device Initialization (2min 58s / 2min 59s)
[***   ] A start job is running for udev Wait for Complete Device Initialization (2min 58s / 2min 59s)
[**    ] A start job is running for udev Wait for Complete Device Initialization (2min 59s / 2min 59s)
[*     ] A start job is running for udev Wait for Complete Device Initialization (2min 59s / 2min 59s)
[FAILED] Failed to start udev Wait for Complete Device Initialization.
See "systemctl status systemd-udev-settle.service" for details.
         Starting Activation of LVM2 logical volumes...
[  OK  ] Started Activation of LVM2 logical volumes.
[  OK  ] Reached target Encrypted Volumes.
[  OK  ] Reached target Local File Systems.
         Starting Shadow /etc/init.d/boot.localfs...
[  OK  ] Started Shadow /etc/init.d/boot.localfs.
         Starting LSB: Set default boot entry if called...
         Starting Tell Plymouth To Write Out Runtime Data...
         Starting Trigger Flushing of Journal to Persistent Storage...
         Starting Create Volatile Files and Directories...
[  OK  ] Started Trigger Flushing of Journal to Persistent Storage.
[  OK  ] Started Create Volatile Files and Directories.
         Starting LSB: AppArmor initialization...
         Starting Security Auditing Service...
[  OK  ] Started LSB: Set default boot entry if called.
[  OK  ] Started Tell Plymouth To Write Out Runtime Data.
[  OK  ] Started Security Auditing Service.
         Starting Update UTMP about System Reboot/Shutdown...
[  OK  ] Started Update UTMP about System Reboot/Shutdown.
[  OK  ] Started LSB: AppArmor initialization.
[  OK  ] Reached target System Initialization.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Listening on Open-iSCSI iscsid Socket.
[  OK  ] Listening on PC/SC Smart Card Daemon Activation Socket.
[  OK  ] Listening on Avahi mDNS/DNS-SD Stack Activation Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Timers.
         Starting Restore Sound Card State...
[  OK  ] Reached target Basic System.
         Starting Machine Check Exception Logging Daemon...
[  OK  ] Started Machine Check Exception Logging Daemon.
         Starting Avahi mDNS/DNS-SD Stack...
         Starting Permit User Sessions...
         Starting Name Service Cache Daemon...
         Starting WPA Supplicant daemon...
         Starting Modem Manager...
         Starting irqbalance daemon...
[  OK  ] Started irqbalance daemon.
         Starting Sundtek MediaTV...
         Starting /etc/init.d/boot.local Compatibility...
         Starting D-Bus System Message Bus...
[  OK  ] Started D-Bus System Message Bus.
[  OK  ] Started Avahi mDNS/DNS-SD Stack.
[  OK  ] Started WPA Supplicant daemon.
         Starting SuSEfirewall2 phase 1...
[  OK  ] Started Restore Sound Card State.
[  OK  ] Started Permit User Sessions.
[  OK  ] Started Name Service Cache Daemon.
[  OK  ] Started Sundtek MediaTV.
         Starting Authorization Manager...
[  OK  ] Reached target User and Group Name Lookups.
         Starting Login Service...
[  OK  ] Reached target Host and Network Name Lookups.
         Starting X Display Manager...
[  OK  ] Started Login Service.
         Starting Locale Service...
[  OK  ] Started Authorization Manager.
[  OK  ] Started Locale Service.
[  OK  ] Started Modem Manager.
[  OK  ] Started X Display Manager.
[  OK  ] Created slice system-systemd\x2drfkill.slice.
         Starting Load/Save RF Kill Switch Status of rfkill0...
         Starting Bluetooth service...
[  OK  ] Started Load/Save RF Kill Switch Status of rfkill0.
[  OK  ] Started Bluetooth service.
[  OK  ] Reached target Bluetooth.
         Starting Hostname Service...
The Sundtek driver was installed with:
# cd /tmp
# wget http://www.sundtek.de/media/sundtek_netinst.sh
# chmod 777 sundtek_netinst.sh
# sudo ./sundtek_netinst.sh
with no errors:
Wollen Sie fortfahren [J/N]:
y
unpacking...
checking system... testing libc OK 2.19.0
64Bit System detected
Downloading architecture specific driver ... 64bit
Starting driver...
done.
linux-s7qt:/tmp #
The problem seems to be related to something called systemd-udev-settle.service
mike@linux-s7qt:~> systemctl status systemd-udev-settle.service
systemd-udev-settle.service - udev Wait for Complete Device Initialization
   Loaded: loaded (/usr/lib/systemd/system/systemd-udev-settle.service; static)
   Active: failed (Result: timeout) since Sat 2014-12-06 15:53:03 GMT; 26min ago
     Docs: man:udev(7)
           man:systemd-udevd.service(8)
  Process: 468 ExecStart=/usr/bin/udevadm settle (code=killed, signal=TERM)
 Main PID: 468 (code=killed, signal=TERM)
Re:Boot takes 3 minutes after installing Sundtek USB DVB-S2 driver
« Antwort #1 am: Dezember 07, 2014, 07:56:03 Nachmittag »
We'll check it within the next days.... it's a systemd configuration issue if it happens.
MikeT23
« Antwort #2 am: Dezember 14, 2014, 09:30:37 Nachmittag »
Solved.
In openSUSE, there is something called lvm2-activation-generator
which is invoked by 2 service files: lvm2-activation-early.service and
lvm2-activation.service.
I have no idea why installing the Sundtek driver causes a problem with these but as I don't use LVM, I've followed the advice to mask these two services and now my boot time is back to a few seconds.
The commands to disable them (as root):
systemctl mask lvm2-activation-early.service
systemctl mask lvm2-activation.service
