Autor Thema: signalstärke  (Gelesen 48876 mal)
hlzhnz
signalstärke
« am: November 07, 2014, 11:49:15 Vormittag »
Hallo, eine Frage zur Signalstärke:
Ist sowas normal? Ist doch eher sehr schwankend.
     STATUS: ACTIVE
SIGNAL: [.................                ] ( 52%)  BER:  17334 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [...............                  ] ( 47%)  BER:  16727 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [...............                  ] ( 47%)  BER:  17141 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [......                           ] ( 20%)  BER:  15487 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [                                 ] (  0%)  BER:  16562 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [................                 ] ( 48%)  BER:  17003 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [.................                ] ( 52%)  BER:  16204 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [................                 ] ( 50%)  BER:  16755 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [.................                ] ( 51%)  BER:  17168 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [.............                    ] ( 39%)  BER:  17058 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [...........                      ] ( 35%)  BER:  17609 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [.........                        ] ( 29%)  BER:  17389 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [............                     ] ( 38%)  BER:  18739 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [............                     ] ( 38%)  BER:  18546 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [...............                  ] ( 45%)  BER:  17637 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [..........                       ] ( 30%)  BER:  17967 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [........                         ] ( 26%)  BER:  18491 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [.......                          ] ( 21%)  BER:  18298 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [                                 ] (  0%)  BER:  18022 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [                                 ] (  0%)  BER:  17637 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [                                 ] (  0%)  BER:  18408 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [.....                            ] ( 16%)  BER:  18656 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [.....................            ] ( 63%)  BER:  18794 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [.............                    ] ( 40%)  BER:  18188 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [.............                    ] ( 40%)  BER:  18243 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [...........                      ] ( 35%)  BER:  17967 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [..........                       ] ( 30%)  BER:  16424 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [..                               ] (  8%)  BER:  16755 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [...                              ] ( 10%)  BER:  18326 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [....................             ] ( 61%)  BER:  17086 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [....................             ] ( 61%)  BER:  18739 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [....                             ] ( 12%)  BER:  18656 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [......                           ] ( 18%)  BER:  17086 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [....                             ] ( 14%)  BER:  18050 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [.......                          ] ( 23%)  BER:  17168 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [.......                          ] ( 22%)  BER:  18519 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
SIGNAL: [...................              ] ( 57%)  BER:  18601 FREQ: 778000000  Hz LOCKED: YES BW: 8 Mhz
Re:signalstärke
« Antwort #1 am: November 07, 2014, 03:37:08 Nachmittag »
Das ist halt DVB-T und ortsabhängig von der Antenne, justiere die Antenne und versuche ein besseres Signal einzufangen.
Alternativ geht natürlich auch eine grössere Antenne.
hlzhnz
Re:signalstärke
« Antwort #2 am: November 08, 2014, 10:22:34 Vormittag »
Danke!
Ich habe eine zwar ziemlich grosse aber alte Dachantenne - noch aus den "Analog Zeiten". Sollte ich auf etwas modernes wechseln? Bringt das Besserung?
Gibt es Empfehlungen diesbezüglich?
Ich habe eine Technisat 5/8 G2 Multischalter, und die beiden Sundtek Sicks (DVBS2 + DVBT)
« Letzte Änderung: November 08, 2014, 11:14:30 Vormittag von hlzhnz »
Re:signalstärke
« Antwort #3 am: November 08, 2014, 11:13:04 Nachmittag »
Den Tuner so nah wie es geht an die Antenne, suche einfach mal einen Platz wo es Empfang gibt.
Eventuell schwächt ja auch nur das Antennenkabel zu sehr ab.
Die alten analog Antennen sind üblicherweise auch für DVB-T in Ordnung.
