Autor Thema: port 1 disabled by hub (EMI?)?  (Gelesen 4548 mal)
chris_g
« am: Oktober 16, 2014, 01:48:48 Nachmittag »
Ich betreibe den Stick an einem Minix X7 mini (Rockchip RK3188 SoC).
Aus irgendeinem Grund verschwindet der USB Stick regelmäßig (bei nicht benutzung). Im syslog steht folgendes:
Oct 16 16:52:01 LINUXIUMONE tvheadend[1349]: htsp: 192.168.178.30 [ christoph | XBMC Media Center ]: Disconnected
Oct 16 16:53:42 LINUXIUMONE kernel: [  829.555538] hub 1-0:1.0: port 1 disabled by hub (EMI?), re-enabling...
Oct 16 16:53:42 LINUXIUMONE kernel: [  829.555641] usb 1-1: USB disconnect, device number 2
Oct 16 16:53:42 LINUXIUMONE tvheadend[1349]: dvb: diseqc setup failed -1
Oct 16 16:53:42 LINUXIUMONE tvheadend[1349]: dvb: "/dev/dvb/adapter0" tuning to "BetaDigital: 12,148,500 kHz Horizontal (Default (Port 0, Universal LNB))" -- Front configuration failed -- Permission denied, frequency: 1548500
Oct 16 16:53:42 LINUXIUMONE kernel: [  829.905559] usb 1-1: new high speed USB device number 3 using usb20_otg
Oct 16 16:53:42 LINUXIUMONE kernel: [  830.118636] usb 1-1: New USB device found, idVendor=2659, idProduct=1405
Oct 16 16:53:42 LINUXIUMONE kernel: [  830.118702] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Oct 16 16:53:42 LINUXIUMONE kernel: [  830.118752] usb 1-1: Product: SkyTV Ultimate IV
Oct 16 16:53:42 LINUXIUMONE kernel: [  830.118788] usb 1-1: Manufacturer: Sundtek
Oct 16 16:53:42 LINUXIUMONE kernel: [  830.118820] usb 1-1: SerialNumber: U141008161227
Oct 16 16:53:42 LINUXIUMONE mtp-probe: checking bus 1, device 3: "/sys/devices/platform/usb20_otg/usb1/1-1"
Oct 16 16:53:42 LINUXIUMONE mtp-probe: bus: 1, device: 3 was not an MTP device
Oct 16 16:53:43 LINUXIUMONE kernel: [  831.360110] input: Sundtek Ltd. Remote Control as /devices/virtual/input/input3
Oct 16 16:53:44 LINUXIUMONE kernel: [  832.310521] usb 1-1: usbfs: process 839 (mediasrv) did not claim interface 0 before use
Oct 16 16:55:03 LINUXIUMONE kernel: [  910.805550] hub 1-0:1.0: port 1 disabled by hub (EMI?), re-enabling...
Oct 16 16:55:03 LINUXIUMONE kernel: [  910.805651] usb 1-1: USB disconnect, device number 3
Oct 16 16:55:03 LINUXIUMONE kernel: [  911.155542] usb 1-1: new high speed USB device number 4 using usb20_otg
Oct 16 16:55:03 LINUXIUMONE kernel: [  911.368611] usb 1-1: New USB device found, idVendor=2659, idProduct=1405
Oct 16 16:55:03 LINUXIUMONE kernel: [  911.368677] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Oct 16 16:55:03 LINUXIUMONE kernel: [  911.368728] usb 1-1: Product: SkyTV Ultimate IV
Oct 16 16:55:03 LINUXIUMONE kernel: [  911.368763] usb 1-1: Manufacturer: Sundtek
Oct 16 16:55:03 LINUXIUMONE kernel: [  911.368795] usb 1-1: SerialNumber: U141008161227
Oct 16 16:55:03 LINUXIUMONE mtp-probe: checking bus 1, device 4: "/sys/devices/platform/usb20_otg/usb1/1-1"
Oct 16 16:55:03 LINUXIUMONE mtp-probe: bus: 1, device: 4 was not an MTP device
Danach sieht der mediaclient das Gerät nicht mehr:
$ /opt/bin/mediaclient -e
was könnte der Grund sein?
Beste Grüsse,
Christoph
Re:port 1 disabled by hub (EMI?)?
« Antwort #1 am: Oktober 16, 2014, 01:52:53 Nachmittag »
Zu wenig Strom?
Beim Laden des Treibers benötigt der Tuner denke ich ca 350mA
Im Standby Modus immerhin noch 50mA (eigentlich sehr wenig).
Kannst du auf der Box denn von einer USB Festplatte mehr als 4 MB/Sek kopieren? (nur um sicherzugehen das diese auch wirklich USB 2.0 unterstützt und nicht nur USB 2.0 Kompatibilität aufweist). Das könnte ebenfalls ein Grund sein.
Das embedded System ist uns soweit nicht bekannt (dem Treiber ist das egal, der braucht nur einen funktionierenden USB Controller Treiber).
Dort steht auch etwas von DVB Diseqc setup failed -1
Das heisst das der Tuner zwar eventuell von dir nicht in Benutzung war aber dennoch von TVHEadend.
Zu diesem Zeitpunkt wird effektiv der LNB mit Strom versorgt und die Chipsätze sind eingeschalten (Wenn du das Netzteil verwendest wird die LNB Stromversorgung über das Netzteil gemacht - was im Normalfall schon helfen sollte, die Chipsätze werden aber dennoch vom Host aus mit Strom versorgt).
Versuch mal ein aktives USB Hub zwischenzuschalten.
« Letzte Änderung: Oktober 16, 2014, 02:06:53 Nachmittag von Sundtek »
chris_g
« Antwort #2 am: Oktober 16, 2014, 02:40:58 Nachmittag »
Hey,
danke für die schnelle Antwort.
Tatsächlich wird der LNB über das externe Netzteil versorgt. Das ist ein LNB mit 4fach-Multiswitch und der scheint zu viel Strom zu ziehen. Jedenfalls meldet euere Karte ohne externes Netzteil 'Kurzschluss' und fährt die Versorgung nicht an.
Mit externem Netzteil läuft's (d.h. man kann Fernsehen, auch über viele Stunden). Aber zumindest in den aktuellen logs finde ich immer ein
tvheadend[1349]: subscription: "192.168.178.30 [ christoph | XBMC Media Center ]" unsubscribing from "ZDF HD"
vor dem
einen externen hub hab' ich gerade nicht zur hand. Vielleicht kann ich das später mal probieren.
Beste Grüsse,
Christoph
« Antwort #3 am: Oktober 16, 2014, 02:48:00 Nachmittag »
Versuch auch mal den anderen USB Port.
Oh und falls das Ding eine variable CPU Geschwindigkeit unterstützt schalte diese auf eine stabile Frequenz während der Tuner benutzt wird. Wir haben schon Systeme gesehen wo es durch die variable CPU Geschwindigkeit beim USB Controller zu Problemen gekommen ist.
/opt/bin/mediaclient --cpucheck
Auch könntest du den Netzwerkmodus des Treibers verwenden, um zu überprüfen ob das auf einem anderen Rechner stabil läuft:
Der Treiber lässt sich auch auf einer Ubuntu livecd installieren, und von dort aus könnte man auch den Server verwenden.
« Letzte Änderung: Oktober 16, 2014, 02:52:27 Nachmittag von Sundtek »
chris_g
« Antwort #4 am: Oktober 18, 2014, 07:09:24 Nachmittag »
umstecken scheint geholfen zu haben. :-)
Der CPU scalinggovernor dagegen hat nichts geändert.
mal sehen wie's auf lange sicht aussieht.
Gruss,
Christoph
