17818 Beiträge in 2134 Themen- von 3035 Mitglieder - Neuestes Mitglied: Pazzeo
Juni 21, 2018, 09:55:12 pm
Sundtek Support ForumEnglishSundtek MediaTV Pro (Europe)sundtek control center enigma2
Seiten: 1 [2]
Autor Thema: sundtek control center enigma2  (Gelesen 10002 mal)
« Antworten #15 am: Juli 09, 2014, 03:45:45 pm »
Ok I see this settopbox was not supported yet, I just added support for it to our installer. Just re-install the driver in the sundtek control center and it should work.
mipsel = generic mips driver
mipsel2 = generic mips driver (same driver as above) + settopbox configuration
So if you get "mipsel" on the settopbox it is certainly the wrong driver configuration
jteeuw
« Antworten #16 am: Juli 09, 2014, 05:57:07 pm »
I can confirm that the new drivers is working now with xtrend et-8000,
The support was fast within 10min the new driver was made , thanks Sundtek
« Letzte Änderung: Juli 09, 2014, 06:00:34 pm von jteeuw » Gespeichert
« Antworten #17 am: Juli 09, 2014, 09:02:56 pm »
The drivers are the same but the configuration in the driver package for your Settopbox changed that's why it was so quick.
Smokey
« Antworten #18 am: Februar 27, 2018, 03:13:02 pm »
Hi there,
there is a small translation error in the Dutch translation.
msgid "OK/ green = activate settings"
msgstr "OK/ greon = activeer instellingen"
'greon' should be 'groen'
msgstr "OK/ groen = activeer instellingen"
Smokey
edit: some other small translation errors.
msgid "Add show plugin"
msgstr "Voeg 'toon plugi' toe"
'plugi' should be 'plugin'
msgstr "Voeg 'toon plugin' toe"
msgid "ext/scan menu"
msgstr "Verlaat/scan menu"
'Verlaat' should be 'extensie'
msgstr "extensie/scan menu"
msgid "ext menu"
msgstr "sluit menu af"
'sluit menu af' should be 'extensie menu'
msgid "ext menu"
msgstr "extensie menu"
« Letzte Änderung: Februar 27, 2018, 10:16:13 pm von Smokey » Gespeichert
Seiten: 1 [2]
