Autor Thema: sundtek control center enigma2  (Gelesen 22676 mal)
Re:sundtek control center enigma2
« Antwort #15 am: Juli 09, 2014, 03:45:45 Nachmittag »
Ok I see this settopbox was not supported yet, I just added support for it to our installer. Just re-install the driver in the sundtek control center and it should work.
mipsel = generic mips driver
mipsel2 = generic mips driver (same driver as above) + settopbox configuration
So if you get "mipsel" on the settopbox it is certainly the wrong driver configuration
jteeuw
« Antwort #16 am: Juli 09, 2014, 05:57:07 Nachmittag »
I can confirm that the new drivers is working now with xtrend et-8000,
The support was fast within 10min the new driver was made , thanks Sundtek
« Letzte Änderung: Juli 09, 2014, 06:00:34 Nachmittag von jteeuw »
« Antwort #17 am: Juli 09, 2014, 09:02:56 Nachmittag »
The drivers are the same but the configuration in the driver package for your Settopbox changed that's why it was so quick.
Smokey
« Antwort #18 am: Februar 27, 2018, 03:13:02 Nachmittag »
Hi there,
there is a small translation error in the Dutch translation.
msgid "OK/ green = activate settings"
msgstr "OK/ greon = activeer instellingen"
'greon' should be 'groen'
msgstr "OK/ groen = activeer instellingen"
Smokey
edit: some other small translation errors.
msgid "Add show plugin"
msgstr "Voeg 'toon plugi' toe"
'plugi' should be 'plugin'
msgstr "Voeg 'toon plugin' toe"
msgid "ext/scan menu"
msgstr "Verlaat/scan menu"
'Verlaat' should be 'extensie'
msgstr "extensie/scan menu"
msgid "ext menu"
msgstr "sluit menu af"
'sluit menu af' should be 'extensie menu'
msgid "ext menu"
msgstr "extensie menu"
« Letzte Änderung: Februar 27, 2018, 10:16:13 Nachmittag von Smokey »
