Autor Thema: sundtek control center enigma2  (Gelesen 22682 mal)
jteeuw
« am: Juli 08, 2014, 08:04:29 Nachmittag »
I use the latest sundtek control center enigma2 for my xtrend 8000
The Sundtek usb dongle is connected to my QNAP
Everthing is working but when i reboot my xtrend reciever, the enigma 2 software does not automount the Sundtek dongle.
i have to run /opt/bin/mediaclient --mount=192.168.1.200 on the reciever tt get everthing working.
Is there a automount option in sundtek control center enigma2
thanks
Re:sundtek control center enigma2
« Antwort #1 am: Juli 08, 2014, 08:45:49 Nachmittag »
Did you set the driver to autostart in the sundtek control center?
jteeuw
« Antwort #2 am: Juli 08, 2014, 08:58:46 Nachmittag »
Driver is set to autostart, this is my sundtek.conf :
# created / modified: Jul 08 2014, 19:25h by sundtekcontrolcenter 1.4.0-20140223-r2
loglevel = off
autoupdate = off
dmhwpidfilter = off
vtuner_acceleration = off
enablenetwork = off
###### configuration network
[NETWORK]
device=192.168.1.200:0
###### configuration stick 1
[U120105091633]
netrecoverymode=on
initial_dvb_mode=DVBC
dreambox_support_fe1=on
« Antwort #3 am: Juli 08, 2014, 09:55:46 Nachmittag »
The configuration looks okay, can you make a screenshot that shows that the driver is set to autostart in the sundtek control center?
Last time I tested it with our DM800HD SE it worked without any problems.
Also is your device visible via network? eg. what is the output of following command when you start it on the settopbox:
jteeuw
« Antwort #4 am: Juli 08, 2014, 10:49:42 Nachmittag »
 192.168.1.200    | 0   | Sundtek MediaTV Digital Home (USB 2.0)  | 40   | DVB-T                                                     , DVB-C | U120105091633
« Antwort #5 am: Juli 08, 2014, 11:08:24 Nachmittag »
Can you make a screenshot of the sundtek control center?
and cat /proc/bus/nim_sockets
by the way if you want the answers a little bit quicker just contact us via Skype (sundtek)
« Letzte Änderung: Juli 08, 2014, 11:10:02 Nachmittag von Sundtek »
jteeuw
« Antwort #6 am: Juli 09, 2014, 08:56:03 Vormittag »
root@et8000:~#  cat /proc/bus/nim_sockets
NIM Socket 0:
        Type: DVB-C
        Has_Outputs: yes
        Frontend_Device: 0
        I2C_Device: 3
NIM Socket 1:
        Type: DVB-C
        Name: Sundtek DVB-C (192.168.1.200) (USB)
        Has_Outputs: no
        Frontend_Device: 1
        I2C_Device: -1
NIM Socket 2:
        Type: DVB-C
        Has_Outputs: no
        Frontend_Device: 2
        I2C_Device: -1
jteeuw
« Antwort #7 am: Juli 09, 2014, 09:01:53 Vormittag »
after a reboot :
NIM Socket 0:
        Type: DVB-C
        Has_Outputs: yes /opt/bin/mediaclient --mount=192.168.1.200
        Frontend_Device: 0
        I2C_Device: 3
Then i run /opt/bin/mediaclient --mount=192.168.1.200 with output :
driver is possibly not started, trying to start now...
Successfully mounted: 192.168.1.200
then  cat /proc/bus/nim_sockets gives the following output :
NIM Socket 0:
        Type: DVB-C
        Has_Outputs: yes
        Frontend_Device: 0
        I2C_Device: 3
NIM Socket 1:
        Type: DVB-C
        Has_Outputs: no
        Frontend_Device: 1
        I2C_Device: -1
NIM Socket 2:
        Type: DVB-C
        Has_Outputs: no
        Frontend_Device: 2
        I2C_Device: -1
« Antwort #8 am: Juli 09, 2014, 12:23:38 Nachmittag »
this is not correct, do you have 2 network devices or only one?
jteeuw
« Antwort #9 am: Juli 09, 2014, 01:05:25 Nachmittag »
I have one network deices
« Antwort #10 am: Juli 09, 2014, 01:19:45 Nachmittag »
Can you contact us via Skype chat (sundtek)?
I was just wondering because you loaded the network device twice.
jteeuw
« Antwort #11 am: Juli 09, 2014, 01:53:09 Nachmittag »
Hi ,
I am not able to skype , can i provide some other information ?
« Antwort #12 am: Juli 09, 2014, 02:44:00 Nachmittag »
http://chat.sundtek.de how about that?
jteeuw
« Antwort #13 am: Juli 09, 2014, 02:55:20 Nachmittag »
jteeuw
« Antwort #14 am: Juli 09, 2014, 03:05:49 Nachmittag »
I did a ./sundtek_netinst.sh –u
Then go to the control center and start the driver
But I get e error :
