Autor Thema: updating driver in Synology NAS versus settopbox, which steps?  (Gelesen 7957 mal)
hansputters
« am: Juni 12, 2014, 08:44:28 Nachmittag »
I noticed in the SSC plugin that another driver update is ready tot be installed...
Would you be as kind as to specify procedure in which order?
a. is Sundtek Synology package automatically updated?
b. if not, uninstall present version (0.15) and reinstall Package again?
c. is restart required in that case?
d. finally, after updating settopbox through SSC: is restart required too?
Thank you
Re:updating driver in Synology NAS versus settopbox, which steps?
« Antwort #1 am: Juni 12, 2014, 08:51:15 Nachmittag »
On a Synology NAS you have to De-Install and Install the package again, the package itself downloads the latest driver in the background. The package version itself does not reflect the current driver version, it really only reflects the package itself (which comes without driver).
On Settopboxes just use the Sundtek Control Center, or SSI (settopbox installer) to update the driver.
hansputters
« Antwort #2 am: Juni 12, 2014, 10:51:56 Nachmittag »
Much obliged for your comments!
What about restarts after an update (NAS and/or settopbox):is/are it/they required?
« Antwort #3 am: Juni 13, 2014, 02:14:50 Vormittag »
After updating rebooting is the easiest way to get it work (it is not really necessary but you need to restart all the applications, the reboot just makes sure that everything is restarted)
« Letzte Änderung: Juni 13, 2014, 07:08:20 Vormittag von Sundtek »
hansputters
« Antwort #4 am: Juni 13, 2014, 10:18:11 Vormittag »
Thanx!
In the meantime i uninstalled Sundtek package in the NAS and unfortunately after adding "http://sundtek.de/synology" in Community section message WRONG LOCATION keeps coming up.
Refreshing does not help at all.
Help please......
« Antwort #5 am: Juni 13, 2014, 10:56:51 Vormittag »
Try again, seems like you are using an old DSM Version. We had to update the Access Policy in order to support the new DSM Version yesterday.
hansputters
« Antwort #6 am: Juni 13, 2014, 11:03:12 Vormittag »
Thank you for responding.
I tried many many times and guess what: over night it worked again!
Yes, i use(d) the former DSM 5.0 version.
Will update it at once
« Antwort #7 am: Juni 13, 2014, 11:04:12 Vormittag »
I just updated the access policy when I wrote the previous post so that's why it should just work again now.
No need to update your DSM version in order to get it work just try to add the Repository link again and it should work.
