Autor Thema: USB dvb-c make tuner-b fail  (Gelesen 17210 mal)
Pade2204
Re:USB dvb-c make tuner-b fail
« Antwort #15 am: Juni 17, 2014, 08:14:50 Nachmittag »
It does not work.   ???
I installed driver and plugin via SSI.exe - changed to dvb-c in tuner settings and rebooted.
It STILL make Tuner-B go "Tuner failed"
The only thing I can see has changed is that it doesnt say "No stick found" in the plugin - now its says that it has found a USB tuner. It still finds all 3 tuners - but when I record 1 program, changing to use tuner B - it fails! It doesnt try to hook to tuner C (USB).
Aww I just thought it would work now  :-(
« Antwort #16 am: Juni 17, 2014, 08:30:23 Nachmittag »
Did you attach the Antenna to all DVB-C inputs (one to the USB TV Tuner and one to the internal tuner - best way is to use a 2 way splitter)?
Well it just works here we tested OpenPLI 4.0
« Antwort #17 am: Juni 17, 2014, 08:47:18 Nachmittag »
Try to contact us via Skype so we can go through that together (our skype account is sundtek)
Pade2204
« Antwort #18 am: Juni 17, 2014, 09:04:18 Nachmittag »
I have:
Internal:
Tuner A (dvb-c)
Tuner B (dvb-c)
USB:
Tuner C Set to (dvb-c)
I have a splitter already. In the start I tried to make a loop from A -> B -> C.  That did not work.
Now I have the splitter setup like this:
1 output to Tuner A -> B   (Works fine when Tuner C is not enabled)
1 output direct to Tuner C  (works fine, but when connected it makes Tuner B Fail!)
I use all updated (today) OpenPli 4.0 as well.
I will try to contact you on SKype - right now I have to see Brasil - Mexico, though I really would like to have this working.
I will contact you guys - Can it be thursday evening maybe or when fits you best ?
« Antwort #19 am: Juni 18, 2014, 11:28:13 Vormittag »
Just contact us via skype any time, we're available most of the time with Skype; if unavailable just leave your message and we'll reply asap.
