Autor Thema: USB dvb-c make tuner-b fail  (Gelesen 17234 mal)
Pade2204
« am: Juni 10, 2014, 07:52:48 Nachmittag »
Hi Sundtek,
I have connected my USB stick and it starts ok - I install the sundtek center.
Info on Vu+ - Tuner C is the USB stick and default registered as dvb-T:
https://www.dropbox.com/sc/xbq8rjw79vc1uo9/AAAlKXTe6f036rsa00z2Mu0Na
Tuner settings:
https://www.dropbox.com/sc/ai70a6kcce1y9yw/AACQupXkNdUFq4qKbAQP0N91a
Sundtek Controlcenter:
https://www.dropbox.com/sc/fdfgz6xlvnx7xr8/AAC5ISYq0kriC9T430d_5KPSa
My problem - when I go into tuner settings and set the TUNER C for dvb-c, only tuner A works. In other words tuner starts "Tuner failed"
Then when I unplug the USB stick it works again.
What should I do ?
Please help !
THANKS
Re:USB dvb-c make tuner-b fail
« Antwort #1 am: Juni 10, 2014, 07:54:58 Nachmittag »
What do you want to use DVB-C or DVB-T/T2?
Pade2204
« Antwort #2 am: Juni 10, 2014, 07:55:40 Nachmittag »
I want to use dvb-C
So at the end I have 3 x dvb-c tuners.
« Antwort #3 am: Juni 10, 2014, 08:52:28 Nachmittag »
Let me update our windows settopbox installer .. I think I can test it until 10pm today.
The device is in DVB-T2 mode so basically that's the reason.
Pade2204
« Antwort #4 am: Juni 10, 2014, 09:11:29 Nachmittag »
OK.
When I go into Tuner Settings and put the TUNER-C into DVB-C thats where it fails.
Then the USB tuner works, but it makes TUNER-B fail!
I tried to update to latest Sundtek center as well - still same :/
The windows intaller is another way of installing driver and so on, through windows and not via plugins - correct ?
Pade2204
« Antwort #5 am: Juni 10, 2014, 09:11:47 Nachmittag »
And thanks for taking the time in this late hours :-)
« Antwort #6 am: Juni 10, 2014, 10:01:24 Nachmittag »
I just tested the Settopbox Installer and it works properly.
Try to use the Sundtek Settopbox Installer
Windows:
Mac::
The Sundtek Controlcenter still needs some updates for VU+ boxes, originally it was made for Dreamboxes.
To delete the settings which were made by the sundtek controlcenter, delete /etc/sundtek.conf before using the Settopbox Installer.
Pade2204
« Antwort #7 am: Juni 10, 2014, 10:09:58 Nachmittag »
Pade2204
« Antwort #8 am: Juni 10, 2014, 10:17:23 Nachmittag »
I installed everything (checked all)
Autostart tuner dvb-c  and so on.
But everything is still the same. (I deleted the Center plugin and the "/etc/sundtek.conf " file.
It starts up, and I see the USB tuner is dvb-t2
« Antwort #9 am: Juni 10, 2014, 10:21:58 Nachmittag »
Ok, then we have to check it on VU+ Settopboxes seems like they work different here than Dreamboxes.
I'll check that tomorrow morning, just don't have any VU+ set up here at the moment.
Pade2204
« Antwort #10 am: Juni 10, 2014, 10:22:47 Nachmittag »
Thats OK.
I will wait.
Thank you very much!
Pade2204
« Antwort #11 am: Juni 12, 2014, 07:55:31 Nachmittag »
Any news about VU+ compability ?
« Antwort #12 am: Juni 16, 2014, 07:28:49 Vormittag »
Will be checked today.
Pade2204
« Antwort #13 am: Juni 16, 2014, 09:01:03 Nachmittag »
OK, sounds good!
« Antwort #14 am: Juni 17, 2014, 03:06:32 Nachmittag »
Can you update everything using the Settopbox Installer Application?
Does it work now?
You might have to switch the Tuner to DVB-C mode (if it is set to DVB-T2) in the Tuner Configuration
1. Tuner Configuration
2. Sundtek DVB-C
3. Tuner Type DVB-C
Done.
We just added a small update in order to support the Sundtek Control Center properly on VU+ systems.
However the tuner itself just works and worked fine.
« Letzte Änderung: Juni 17, 2014, 03:30:21 Nachmittag von Sundtek »
