Autor Thema: QAM256 channels give errors  (Gelesen 5033 mal)
Mark
« am: Mai 10, 2014, 08:53:31 Vormittag »
Hello,
I'm using a Sundtek MediaTV Digital Home III (EU) with DVB-C (Ziggo, Netherlands) and TVHeadend. With this combination I can watch channels which use QAM64 with no problems, but I cannot watch channels with QAM256.
When I open QAM256 channels I get Continuity counter errors and Transport error indicators in the TVHeadend log file.
May 10 08:51:19 E6410 tvheadend[2568]: TS: Sundtek DVB-C (III)/Ziggo Venlo: 372,000 kHz/Canvas: Transport error indicator, 2939576 duplicate log lines suppressed
May 10 08:51:19 E6410 tvheadend[2568]: TS: Sundtek DVB-C (III)/Ziggo Venlo: 372,000 kHz/Canvas: CA @ #5004: Continuity counter error, 418 duplicate log lines suppressed
May 10 08:51:20 E6410 tvheadend[2568]: TS: Sundtek DVB-C (III)/Ziggo Venlo: 372,000 kHz/Canvas: Transport error indicator, 2946250 duplicate log lines suppressed
May 10 08:51:20 E6410 tvheadend[2568]: TS: Sundtek DVB-C (III)/Ziggo Venlo: 372,000 kHz/Canvas: CA @ #5004: Continuity counter error, 419 duplicate log lines suppressed
When I check the signal level of the MediaTV it looks okay, no errors there:
root@E6410:~# /opt/bin/mediaclient --readsignal=0 -d /dev/dvb/adapter0/frontend0
SIGNAL: [.................................] ( 99%)  BER:      0 FREQ: 372000000  Hz LOCKED: YES SYM: 6875000 MOD: QAM256
Maybe you can tell me if this is a issue with the Sundtek DVC-C stick or do I need to dive into TVHeadend for this problem ?
Mark
Re:QAM256 channels give errors
« Antwort #1 am: Mai 10, 2014, 11:01:42 Vormittag »
Can you try to use 6900 as symbolrate? We already opened a ticket at the chip desing house to doublecheck whats best to do here in the future (either Firmwareupdate or just treat 6875 as 6900 in the driver)
Mark
« Antwort #2 am: Mai 10, 2014, 03:42:23 Nachmittag »
Thanks, that was the solution. I always thought that i wouldn't receive anything when using a wrong symbol rate. But when it's working you don't hear me complain :)
« Antwort #3 am: Mai 10, 2014, 03:49:53 Nachmittag »
This 6875 -> 6900 Symbolrate issue is currently on our todo list we will definitely update it once it's clarified with the chip manufacturer.
There's no side-effect on the sensitivity but having to set this manually is just not nice, so we have to handle this in order to work correctly.
