Autor Thema: Pixelated Image. Vu SOLO2  (Gelesen 14906 mal)
angel
« am: März 18, 2014, 07:28:07 Nachmittag »
Hi.
VU SOLO2:
  Linux vusolo2 3.3.8-2.0
  Image: OPENSPA Version 3.0
I bought a SundTek Media TV Digital Home (DVB-C/T/T2) and installed.
I follow this steps:
wget http://www.sundtek.de/media/sundtek_installer_development.sh
chmod 755 sundtek_installer_development.sh
./sundtek_installer_development.sh
Installed driver correctly.
Now I created a xml file (cable.xml) with this information:
<cables>
<cables>
    <cable name="CABLE R" satfeed="true" flags="9">
    <transponder frequency="706000" symbol_rate="6875000" fec_inner="0" modulation="5"/>
</cable>
</cables>
Copy to /etc/tuxbox  , reboot and searching for new channels.
All ok. I found 136 channels (is a cable TV).
BUT ALL CHANNELS ARE PIXELATED (least 2)
Same cable connect to TV works correctly and I watch all channels without pixelated.
Can you help me ?
I don't Know is a image problem (openspa) or a wrong configuration....
Thank's you.
Re:Pixelated Image. Vu SOLO2
« Antwort #1 am: März 18, 2014, 08:00:17 Nachmittag »
Try to connect the tuner directly to the DVB-C plug at the wall.
The sensitivity of those tuners is excellent, you should not have any issues with it, additionally we tested all tuners before we shipped them out, so the only possibility that could be here is that the tuner got damaged during the shipping or something is wrong with the Antenna cable / your signal
Also VU+ Solo should just work fine.
If you cannot fix your issue I propose to ship the tuner back for checking it again
« Letzte Änderung: März 18, 2014, 08:24:43 Nachmittag von Sundtek »
angel
« Antwort #2 am: März 19, 2014, 07:39:20 Nachmittag »
Hi.
I connect directly and not working.
Signal is good (99%). Connect cable to tv watch correctly.
I try to use TDT USB with a computer with Linux Mint installed.
I install drivers (appears whith /opt/bin/mediaclient --e) and follow this link:
http://support.sundtek.com/index.php/topic,4.0.html
I write:
$ /opt/bin/mediaclient --setdtvmode=DVBC
$ kaffeine
But Kaffeine not detect TDT / USB.
Can I do anything ?
« Antwort #3 am: März 19, 2014, 09:21:40 Nachmittag »
You need to install kaffeine Packages from there: (search for kaffeine)
angel
« Antwort #4 am: März 19, 2014, 11:29:18 Nachmittag »
I try install this:
Neuere Versionen:
But Linux Mint inform that I have a newer version...
« Antwort #5 am: März 20, 2014, 01:18:00 Vormittag »
just a newer build but the version should be the same.
angel
« Antwort #6 am: März 28, 2014, 06:03:18 Nachmittag »
Hi.
I think your product is broken.
Finally, I got it would work in linux, but channels appears pixelated.
Into terminal appears those messages when I watch a HD TV:
[h264 @ 0x7f0d40022380] Reference 2 >= 2
[h264 @ 0x7f0d40022380] error while decoding MB 82 6, bytestream (14354)
[h264 @ 0x7f0d40022380] concealing 5547 DC, 5547 AC, 5547 MV errors
[h264 @ 0x7f0d40022380] concealing 4274 DC, 4274 AC, 4274 MV errors
[h264 @ 0x7f0d40022380] concealing 822 DC, 822 AC, 822 MV errors
[h264 @ 0x7f0d40022380] concealing 5359 DC, 5359 AC, 5359 MV errors
kaffeine(9983) DvbEpgModel::addEntry: invalid entry
[h264 @ 0x7f0d40022380] concealing 2994 DC, 2994 AC, 2994 MV errors
[h264 @ 0x7f0d40022380] error while decoding MB 34 18, bytestream (7214)
[h264 @ 0x7f0d40022380] concealing 4515 DC, 4515 AC, 4515 MV errors
[h264 @ 0x7f0d40022380] concealing 1073 DC, 1073 AC, 1073 MV errors
[h264 @ 0x7f0d40022380] Reference 4 >= 2
[h264 @ 0x7f0d40022380] error while decoding MB 26 26, bytestream (12379)
[h264 @ 0x7f0d40022380] concealing 3803 DC, 3803 AC, 3803 MV errors
kaffeine(9983) DvbEpgModel::~DvbEpgModel: filter list not empty
[h264 @ 0x7f0d40022380] cabac decode of qscale diff failed at 57 27
[h264 @ 0x7f0d40022380] error while decoding MB 57 26, bytestream (7769)
[h264 @ 0x7f0d40022380] concealing 3772 DC, 3772 AC, 3772 MV errors
[h264 @ 0x7f0d40022380] left block unavailable for requested intra mode at 0 4
[h264 @ 0x7f0d40022380] error while decoding MB 0 4, bytestream (76811)
[h264 @ 0x7f0d40022380] concealing 5809 DC, 5809 AC, 5809 MV errors
If I watch a TV (not HD):
kaffeine(10267) DvbEpgModel::addEntry: invalid entry
All channels pixexated.
Any idea ???
« Letzte Änderung: März 28, 2014, 06:45:19 Nachmittag von angel »
« Antwort #7 am: März 29, 2014, 12:53:39 Vormittag »
we guess so too the device is probably broke during shipping, please contact back via Email for either a refund or a replacement. Something like that is not the normal behavior and no device from the new stock leaves our office without testing.
