Autor Thema: Media TV Digital Home III and T2  (Gelesen 39339 mal)
tappari
« am: Februar 07, 2014, 10:20:35 Vormittag »
I have tested this stick in VU+ Duo2, VU+ Ultimo, Dreambox 8000HD and DM800HD, but in none of these STB:s there is T2 function. Only T. So please stop advertising this model as suitable USB-T2 tuner for T2 use in STB:s.
Re:Media TV Digital Home III and T2
« Antwort #1 am: Februar 07, 2014, 11:24:21 Vormittag »
We told you to contact us via Skype, those Models and the driver supports DVB-T2.
http://wiki.sundtek.de/index.php/Mediaclient#Tuning_DVB-T2
Other ones usually get back to us and we solve or at least analyze possible issues.
tappari
« Antwort #2 am: Februar 07, 2014, 01:02:56 Nachmittag »
It was Sundtek that promised to come back with this issue when having enough of time. Normally it is on suppliers responsibility to guarantee the operation, not customers.
« Antwort #3 am: Februar 07, 2014, 01:20:46 Nachmittag »
Well you have the choice:
Find another Manufacturer who will give you direct support (and I can guarantee that any other manufacturer is scared to touch such systems)
or
Try to work with us, and find a solution for your issue.
tappari
« Antwort #4 am: Februar 07, 2014, 01:31:58 Nachmittag »
sO IS IT UP TO ME
So is it up to me to make Your product to do what You have promised?
tappari
« Antwort #5 am: Februar 07, 2014, 01:45:16 Nachmittag »
Normally I see it is on suppliers responsibility to see if the product is operating as promised. Not customers.
« Antwort #6 am: Februar 07, 2014, 02:09:55 Nachmittag »
We are not going to struggle with you, you have the choice either try to cowork with us or ship it back.
The time you are spending on writing those posts might be enough to fix your issue.
The entire Settopbox Support was made that way, customers asking if we could support their boxes and we tried to help them, and there was a lot experimenting involved. The same with supporting several routers and other systems.
tappari
« Antwort #7 am: Februar 07, 2014, 02:14:43 Nachmittag »
It is not the question if I want to co-operate or not. I would like to co-operate, but I`m waiting for Your activivities to do something.
« Antwort #8 am: Februar 07, 2014, 03:25:49 Nachmittag »
I think we tried to contact you through skype/chat earlier already, but also no response. Our Skype account always shows away that's normal.
We have several settopboxes here but eg no DM8000, no VU+ Ultimo and no DM800HD (we only have the DM800HD SE and VU+ duo 2)
We have prepared some updates, but would like to see the output on your side.
All those boxes which you have use slightly different Enigma versions.
So once you have some time get back to us via Skype chat and we can give it a go.
« Letzte Änderung: Februar 07, 2014, 03:37:12 Nachmittag von Sundtek »
« Antwort #9 am: Februar 08, 2014, 11:10:04 Vormittag »
There are some Tuner Startscripts in /usr/script
DVB_T2_Tuner_autostart.sh <- autostart on reboot
DVB_T2_Tuner_starten.sh <- start immediately (should only be run from console)
tappari
« Antwort #10 am: Februar 09, 2014, 10:16:44 Vormittag »
Sundtek Control Center/Info-button says:
[DVB-T2]
But in  Dreambox Control Center FTP /dev/dvb/adapter0
No adapter1
This is in VU+Ultimo, but same situation with other STB`s.
« Antwort #11 am: Februar 09, 2014, 11:50:53 Vormittag »
Start the DVB-T2 Script in /usr/script
The Sundtek Controlcenter still needs some update it doesn't include DVB-T2 yet.
Our driver does not register /dev/dvb/adapterN on Settopboxes because it is not needed.
cat /proc/bus/nim_sockets shows up the registered tuners.
« Letzte Änderung: Februar 09, 2014, 11:59:00 Vormittag von Sundtek »
tappari
« Antwort #12 am: Februar 09, 2014, 01:10:16 Nachmittag »
There is no /cat directory in STB`s.
tappari
« Antwort #13 am: Februar 09, 2014, 01:19:14 Nachmittag »
And /proc/bus/nim_sockets is empty
« Antwort #14 am: Februar 09, 2014, 01:35:54 Nachmittag »
Seems like you need some howto with pictures, I'll do that a little bit later.
