Autor Thema: Neue Generation MediaTV Digital Home III wird unter VU+ Duo2 nicht erkannt  (Gelesen 17132 mal)
Cyborg90
« am: Dezember 27, 2013, 02:17:30 Nachmittag »
ich habe mir von euch den neuen USB-Stick MediaTV Digital Home III zugelegt.
Leider wird dieser in der VU+ Duo2 nicht erkannt.
Treiber sind installiert vom 27.12.13. Im logfile mediasrv.log stehen folgende Einträge:
Wäre nett wenn mir jemand weiterhelfen könnte.
2013-12-27 12:53:15 [1759] Starting up Multimedia Framework (Dec 27 2013 06:46:53)
2013-12-27 12:53:15 [1759] API Version: 5.10
2013-12-27 12:53:15 [1759] Running on Linux (3.3.8-2.0)
2013-12-27 12:53:15 [1759] unable to load acceleration module
2013-12-27 12:53:15 [1759] scanning devices
2013-12-27 12:53:15 [1759] scanning for drivers
2013-12-27 12:53:15 [1759] scanning for plugins
2013-12-27 12:53:15 [1759] Starting up device manager
2013-12-27 12:53:15 [1760] Starting service processor (PID 1760)
2013-12-27 12:53:15 [1759] registering ID: 0
2013-12-27 12:53:15 [1759] scanning devices done
2013-12-27 12:53:15 [1759] attached devices:
2013-12-27 12:53:15 [1760] Autostarting scripts in /etc/sundtek/
2013-12-27 12:53:15 [1760] executed all available items
2013-12-27 12:53:15 [1759] Using dynamic configuration
2013-12-27 12:53:15 [1759] DTV1 Transfer is set to: Bulk
2013-12-27 12:53:17 [1760] trying to load uinput module
2013-12-27 12:53:17 [1760] loading uinput kernel extention failed, remote control will not work with lirc
2013-12-27 12:53:17 [1759] No remote control support available
2013-12-27 12:53:17 [1759] Allocation using pg for type 65678
2013-12-27 12:53:17 [1759] attaching DVB-T, DVB-C, DVB-T2
2013-12-27 12:53:17 [1759] demodulator successfully attached (DVB-C)!
2013-12-27 12:53:17 [1759] This device uses the third generation Tuner
2013-12-27 12:53:17 [1759] Power up demodulator
2013-12-27 12:53:18 [1759] configure urbs for bulk
2013-12-27 12:53:18 [1759] Registering OSS emulation
2013-12-27 12:53:18 [1759] registering: adapter1/0
2013-12-27 12:53:18 [1759] registered virtual: /dev/dvb/adapter1/frontend0
2013-12-27 12:53:18 [1759] registered virtual: /dev/dvb/adapter1/demux0
2013-12-27 12:53:18 [1759] registered virtual: /dev/dvb/adapter1/dvr0
2013-12-27 12:53:18 [1759] Initializing Remote Control Support
2013-12-27 12:53:18 [1759] This system does not support memory mapped USB transfers
2013-12-27 12:53:18 [1759] Once your system reaches the latest kernel version the
2013-12-27 12:53:18 [1759] performance will increase automatically
2013-12-27 12:53:18 [1759] registered virtual: /dev/mediainput0
2013-12-27 12:53:18 [1759] Initialized MediaTV Digital Home III (EU)
2013-12-27 12:53:18 [1759] Driver loaded within 3055 milliseconds
2013-12-27 12:53:18 [1759] Stopping Remote Control support
2013-12-27 12:53:18 [1759] Enabling Standby
2013-12-27 12:53:18 [1759] clearing id: 0
2013-12-27 12:53:21 [1747] No Sundtek device Detected
2013-12-27 12:53:23 [1759] Initial devicescan done, switching detection mode
Re:Neue Generation MediaTV Digital Home III wird unter VU+ Duo2 nicht erkannt
« Antwort #1 am: Dezember 27, 2013, 02:19:56 Nachmittag »
um das eventuell etwas abzukürzen kontaktiere uns am Besten via Chat
http://chat.sundtek.de oder ggf. Skype "sundtek"
Ich denke auf der VU+ Duo2 wurde nur der Sundtek MediaTV Pro getestet, kann sein das dort eine Konfiguration noch nicht abgestimmt wurde.
« Antwort #2 am: Dezember 27, 2013, 04:23:06 Nachmittag »
Falls du wieder online bist melde dich bei uns ggf. auch telefonisch.
Der offizielle Treiber wurde aktualisiert, es sollte nun klappen
« Letzte Änderung: Dezember 27, 2013, 08:25:13 Nachmittag von Sundtek »
Cyborg90
« Antwort #3 am: Dezember 27, 2013, 09:02:44 Nachmittag »
der USB-Stick wird jetzt von der VU+ Duo2 erkannt. Danke.
Leider lässt es sich für den DVB-C Modus nicht konfigurieren.
2013-12-27 19:54:34 [1446] Starting up Multimedia Framework (Dec 27 2013 15:36:23)
2013-12-27 19:54:34 [1446] API Version: 5.10
2013-12-27 19:54:34 [1447] Starting service processor (PID 1447)
2013-12-27 19:54:34 [1446] Running on Linux (3.3.8-2.0)
2013-12-27 19:54:34 [1446] unable to load acceleration module
2013-12-27 19:54:34 [1446] scanning devices
2013-12-27 19:54:34 [1446] scanning for drivers
2013-12-27 19:54:34 [1446] scanning for plugins
2013-12-27 19:54:34 [1446] Starting up device manager
2013-12-27 19:54:34 [1446] scanning devices done
2013-12-27 19:54:34 [1446] attached devices:
2013-12-27 19:54:34 [1447] Autostarting scripts in /etc/sundtek/
2013-12-27 19:54:34 [1447] executed all available items
2013-12-27 19:54:35 [1446] registering ID: 0
2013-12-27 19:54:35 [1446] Using dynamic configuration
2013-12-27 19:54:35 [1446] DTV1 Transfer is set to: Bulk
2013-12-27 19:54:36 [1447] trying to load uinput module
2013-12-27 19:54:36 [1447] loading uinput kernel extention failed, remote control will not work with lirc
2013-12-27 19:54:36 [1446] No remote control support available
2013-12-27 19:54:36 [1446] Initial mode request: DVBC
2013-12-27 19:54:36 [1446] Allocation using pg for type 65678
2013-12-27 19:54:36 [1446] attaching DVB-T, DVB-C, DVB-T2
2013-12-27 19:54:36 [1446] demodulator successfully attached (DVB-C)!
2013-12-27 19:54:36 [1446] This device uses the third generation Tuner
2013-12-27 19:54:36 [1446] Power up demodulator
2013-12-27 19:54:38 [1446] configure urbs for bulk
2013-12-27 19:54:38 [1446] Registering OSS emulation
2013-12-27 19:54:38 [1446] registering: adapter2/0
2013-12-27 19:54:38 [1446] registered virtual: /dev/dvb/adapter2/frontend0
2013-12-27 19:54:38 [1446] registered virtual: /dev/dvb/adapter2/demux0
2013-12-27 19:54:38 [1446] registered virtual: /dev/dvb/adapter2/dvr0
2013-12-27 19:54:38 [1446] Initializing Remote Control Support
2013-12-27 19:54:38 [1446] This system does not support memory mapped USB transfers
2013-12-27 19:54:38 [1446] Once your system reaches the latest kernel version the
2013-12-27 19:54:38 [1446] performance will increase automatically
2013-12-27 19:54:38 [1446] registered virtual: /dev/mediainput0
2013-12-27 19:54:38 [1446] Initialized MediaTV Digital Home III (EU)
2013-12-27 19:54:38 [1446] Driver loaded within 3032 milliseconds
2013-12-27 19:54:38 [1446] Enabling Dreambox Support for first Adapter (/dev/dvb/adapter2/frontend0)
2013-12-27 19:54:38 [1446] Supporting DVB-S/S2 API for Dreambox
2013-12-27 19:54:38 [1446] starting up dreambox /dev/dvb/adapter2/frontend0
2013-12-27 19:54:38 [1446] Using local device
2013-12-27 19:54:38 [1446] Disabling HW PID filter for this settopbox (dmhwpidfilter=off)
2013-12-27 19:54:38 [1446] in /etc/sundtek.conf
2013-12-27 19:54:38 [1446] Device is currently in DVB-S2 mode
2013-12-27 19:54:38 [1446] VTUNER_SET_NAME: MediaTV Digital Home III (EU)
2013-12-27 19:54:38 [1446] FE SET VOLTAGE
2013-12-27 19:54:38 [1446] Disconnect request
2013-12-27 19:54:40 [1436] Using /etc/sundtek.conf for deviceconfiguration
« Antwort #4 am: Dezember 27, 2013, 09:07:40 Nachmittag »
Kannst du uns eventuell kurz nocheinmal via Skype oder Chat kontaktieren?
Der Treiber wurde aktualisiert.
« Letzte Änderung: Dezember 28, 2013, 11:48:37 Vormittag von Sundtek »
scholl
« Antwort #5 am: Dezember 28, 2013, 05:59:10 Nachmittag »
Hallo, auch ich habe das Problem mit dem Digital Home III Stick. Wird in der Duo2 nicht erkannt. Heute mit dem neuesten Treiber installiert - 2013-12-27 15:28:39.
Aktualisierung zeigt keinnen neueren Treiber. In der mediasrv.log ist lediglich der Eintrag 2013-12-28 16:24:56 [1007] No Sundtek device Detected.
Im Control Center auch der Hinweis "Kein Stick gefunden"
Brauche Hilfe.
scholl
« Antwort #6 am: Dezember 28, 2013, 06:29:30 Nachmittag »
Also genau das Problem wurde doch mit dem Treiberupdate gelöst.
Melde dich ggf. via Skype (sundtek) oder Chat
scholl
« Antwort #7 am: Dezember 28, 2013, 08:37:54 Nachmittag »
Nachdem mir durch Fernwartung neue Firmware aufgespielt wurde, wird der Stick zwar erkannt, er funktioniert jedoch leider nicht. Hier meine letzte Reaktion aus dem Chat.
- tuner wir als nicht konfiguriert angezeigt
- bei umschalten von "nicht konfiguriert" auf einfach wird DVB-S Einstellungen angezeigt
- weitere einstellung ist "verbunden mit" hier kann nur Tuner B:VUPLUS ... eingestellt werden
- im Controlcenter ist DVB-C eingestellt
- allerdings wird hier weiter "kein stick gefunden" angezeigt
- Tuner wird in der Konfig als Digital Home III (EU)(UDVB-S2(DVB-S2) angezeigt - richtig??
- Contolcenter Update durchgeführt - keine Änderung
- in der Konfiguration bei "verbunden mit" siehe oben kommt bei Bestätigung "die Einstellungen zum durchschleifen sind falsch"  - was kann ich tun
Da hierauf im Chat keine Antwort mehr kam - Feierabend? :-) stelle ich dies mal ins Forum ein.
scholl
« Antwort #8 am: Dezember 28, 2013, 11:48:01 Nachmittag »
Kontaktiere uns nochmal via Chat es darf auf keinem Fall als DVB-S/S2 angezeigt werden. Das wurde als ich es bei dir Installierte auch nicht als DVB-S/S2 angezeigt sondern als DVB-C.
scholl
« Antwort #9 am: Dezember 30, 2013, 08:47:12 Nachmittag »
Mittlerweile mit dem aktuellen Treiber wird der Stick wieder richtig angezeigt (2013-12-29 00:39:21). Sobald jedoch das Bild über den Stick erfolgt und  man eine weitere Taste drückt friert die Box ein. Folgendes getestet:
- da mit Stick 3 Tuner / 1 und 2 Aufnahme gestartet und auf weitere Frequenz/Kanal geschaltet
- 1 und 2 deaktiviert / Bild läuft über Stick
In beiden Varianten das gleiche.
Gruß und guten Rutsch
Scholl
roymarja
« Antwort #10 am: Dezember 31, 2013, 12:52:28 Nachmittag »
Hier (NL) mit einer DM 7020 HD leider die selben Erkenntnisse.
Der neue (C/T/T2) Stick wird zwar in der Tunerkonfiguration angezeigt aber keiner der vorhandenen DVB-C Sender ist sichtbar.
Bei einer Sendersuche, hängt sich die Box wiederholt auf.
Ich bin zuversichtlich, dass Sundtek dieses Wehwehchen in den Griff bekommen wird.
Bitte schildern Sie die Massnahmen die zur Behebung der Problematik nötig sind so ausführlich wie möglich.
Nicht alle User sind ja Linux-begabt
Danke und Allen einen gesunden Rutsch gewünscht!
scholl
« Antwort #11 am: Januar 07, 2014, 10:03:36 Vormittag »
Mit der Firmware vom 04.01. kein Einfrieren mehr - Danke. :)
« Antwort #12 am: Januar 07, 2014, 10:39:49 Vormittag »
Nur als Information, ich nehme an das du einen Stick vom 23 oder 24. Dezember hast du wirst wohl im Laufe der kommenden Woche einen Ersatzstick erhalten, wir tauschen die Sendungen von diesen beiden Tagen komplett aus. Falls bei dir irgendwo Bildfragmente auftreten wird sich dies damit dann lösen.
scholl
« Antwort #13 am: Januar 08, 2014, 08:13:48 Nachmittag »
Ja - Bildfragmente habe ich.
Ist es die Versandbenachrichtigung die ich jetzt erhalten habe mit gleicher Bestellnr. und ohne weiteren Hinweis? Habe mich schon gewundert.
« Antwort #14 am: Januar 08, 2014, 11:53:34 Nachmittag »
Genau.
