Autor Thema: Help with monobloc LNB (Hotbird/Astra)  (Gelesen 4554 mal)
sbi
« am: November 11, 2013, 11:24:24 Nachmittag »
Hello,
I'm have difficulties tuning to Astra 19.2 with the SkyTV Ultimate USB.
This works fine (13.0E):
~$ mediaclient -d /dev/dvb/adapter1/frontend0 -m DVBS -f 11137000 -S 27500000 -V H -E 3/4 -M QPSK
using HI/LO Band frequency: 11137000
Modulation: QPSK (DVB-S)
Symbolrate: 27500000
Voltage: 18 Volt (Horizontal)
FEC: 3/4
Tone OFF
Frequency: 1387000
Syntax OK
How can I switch to 19.2E?
I have tried --secmini=A/B but it seems to have no effect.
mediaclient --list-diseqc gives mediaclient: unrecognized option '--list-diseqc'
mediaclient --build and mediasrv --build both give
Build date: 2013-11-06 14:42:40
Can you help?
-Stéphane
Re:Help with monobloc LNB (Hotbird/Astra)
« Antwort #1 am: November 12, 2013, 12:03:26 Vormittag »
Well it depends on your switch. Does it support modulated burst tone / Sec Mini?
/opt/bin/mediaclient --secmini=A -d /dev/dvb/adapter0/frontend0
I think you might need to take care about the standby feature which kicks in after 15 seconds it might reset the previous settings on the LNB.
you can send manual Diseqc commands
/opt/bin/mediaclient --diseqc="AA BB CC DD" -d /dev/dvb/adapter0/frontend0
where AA BB CC DD is the Diseqc Command in HEX
