Autor Thema: Dead Sundtek MediaTV Digital Home (DVB-CT)  (Gelesen 13213 mal)
dorinineu
« am: Mai 06, 2013, 08:55:10 Nachmittag »
I recently bought from you,abour a mounth ago Sundtek MediaTV Digital Home (DVB-CT) ,now is compleatly dead.I have used it with Vu+solo2 setopbox,and for about 3 days sometimes when I have swiched from satellit chanels to cable chanels usb tuner does not respond,blue led dosent light,only reboot of the box make it work.I have reflashed firmware on box,reinstalled drivers for usb tuner but same result,and today usb tuner died for good I think,becouse is not starting at all anymore,not reboot helps,not reinstalled firmware nothing.I also tried today to install usb tuner to my old dreambox800hd,but not any sign of life.On Sundtek Control center for bouth setopboxes shows same masage No stick found.So what to do?
« Letzte Änderung: Mai 06, 2013, 08:56:46 Nachmittag von dorinineu »
Re:Dead Sundtek MediaTV Digital Home (DVB-CT)
« Antwort #1 am: Mai 06, 2013, 10:45:37 Nachmittag »
What do following commands output if you connect with telnet or dreambox control center:
lsusb
dmesg
dorinineu
« Antwort #2 am: Mai 06, 2013, 11:07:46 Nachmittag »
=~=~=~=~=~=~=~=~=~=~=~= PuTTY log 2013.05.06 23:56:57 =~=~=~=~=~=~=~=~=~=~=~=
BlackHole 2.0.2 vusolo2
vusolo2 login: root t
root@vusolo2:~# /opt/bin/mediaclient -e
device 0: [Sundtek MediaTV Digital Home (USB 2.0)]  DVB-C, DVB-T, REMOTE-CONTROL
root@vusolo2:~# lsusb
Bus 001 Device 001: ID 1d6b:0002
Bus 002 Device 001: ID 1d6b:0002
Bus 003 Device 001: ID 1d6b:0002
Bus 004 Device 001: ID 1d6b:0002
Bus 005 Device 001: ID 1d6b:0001
Bus 006 Device 001: ID 1d6b:0001
Bus 007 Device 001: ID 1d6b:0001
Bus 001 Device 002: ID eb1a:51b2
Bus 008 Device 001: ID 1d6b:0001
root@vusolo2:~# dmesg
et -71
usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd mediasrv rqt 64 rq 2 len 2 ret -71
usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd mediasrv rqt 64 rq 2 len 1 ret -71
usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd mediasrv rqt 64 rq 2 len 5 ret -71
usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd mediasrv rqt 192 rq 0 len 1 ret -71
usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd mediasrv rqt 64 rq 0 len 1 ret -71
DVB: registering adapter 0 frontend 0 (Sundtek DVB-C (0/0))...
[LCD]: unknown cmd 0x1015
[CI]: CI interface initialised
root@vusolo2:~#
« Antwort #3 am: Mai 06, 2013, 11:13:01 Nachmittag »
Is the tuner connected to a USB Hub?
Try to use another USB Port.
And enable logging in the sundtek controlcenter, afterwards reboot and show me what /var/log/mediasrv.log shows up.
dorinineu
« Antwort #4 am: Mai 06, 2013, 11:38:50 Nachmittag »
no usb hub,sundtek is now on upper usb slot,on lower usb I have usb stick wich I use for swab and for multiboot,now is on cable channel spinner is rounding and I cant move to another channel.
1970-01-01 02:00:38 [1515] Starting up Multimedia Framework (Mar 15 2013 23:09:30)
1970-01-01 02:00:38 [1516] Starting service processor (PID 1516)
1970-01-01 02:00:38 [1515] API Version: 5.9
1970-01-01 02:00:38 [1515] Running on Linux (3.3.6-1.2)
1970-01-01 02:00:38 [1515] scanning devices
1970-01-01 02:00:38 [1515] scanning for drivers
1970-01-01 02:00:39 [1515] scanning for plugins
1970-01-01 02:00:39 [1515] Starting up device manager
1970-01-01 02:00:39 [1515] scanning devices done
1970-01-01 02:00:39 [1515] attached devices:
1970-01-01 02:00:39 [1515] registering ID: 0
1970-01-01 02:00:39 [1516] Autostarting scripts in /etc/sundtek/
1970-01-01 02:00:39 [1516] executed all available items
1970-01-01 02:00:39 [1515] disconnecting kernel driver
1970-01-01 02:00:39 [1515] Initial mode requested: DVBC
1970-01-01 02:00:39 [1515] attaching DVB-T, DVB-C
1970-01-01 02:00:40 [1515] Using first generation demodulator
1970-01-01 02:00:44 [1515] SETTING DVB-C
1970-01-01 02:00:44 [1515] demodulator successfully attached (DVBC)!
1970-01-01 02:00:44 [1515] Allocation using pg for type 65678
1970-01-01 02:00:44 [1515] requesting to attach tuner(s) now
1970-01-01 02:00:46 [1515] registering: adapter1/0
1970-01-01 02:00:46 [1515] registered virtual: /dev/dvb/adapter1/frontend0
1970-01-01 02:00:46 [1515] registered virtual: /dev/dvb/adapter1/demux0
1970-01-01 02:00:46 [1515] registered virtual: /dev/dvb/adapter1/dvr0
1970-01-01 02:00:46 [1515] Setting RC Protocol to NEC
1970-01-01 02:00:46 [1515] registered virtual: /dev/mediainput0
1970-01-01 02:00:46 [1515] Remote Control Layout: 1
1970-01-01 02:00:46 [1516] trying to load uinput module
1970-01-01 02:00:46 [1516] loading uinput kernel extention failed, remote control will not work with lirc
1970-01-01 02:00:46 [1515] No remote control support available
1970-01-01 02:00:46 [1515] Sundtek MediaTV Driver loaded. This driver is licensed for non-commercial use
1970-01-01 02:00:46 [1515] with Sundtek MediaTV only
1970-01-01 02:00:46 [1515] Driver loaded within 7246 milliseconds
1970-01-01 02:00:46 [1515] Serial(0): U120611200223
1970-01-01 02:00:46 [1515] Enabling Dreambox Support for first Adapter (/dev/dvb/adapter1/frontend0)
1970-01-01 02:00:46 [1515] Initial devicescan done, switching detection mode
1970-01-01 02:00:46 [1515] Supporting DVB-S/S2 API for Dreambox
1970-01-01 02:00:46 [1515] starting up dreambox /dev/dvb/adapter1/frontend0
1970-01-01 02:00:46 [1515] Using local device
1970-01-01 02:00:46 [1515] Disabling HW PID filter for this settopbox (dmhwpidfilter=off)
1970-01-01 02:00:46 [1515] in /etc/sundtek.conf
1970-01-01 02:00:46 [1515] Device is currently in DVB-C mode
1970-01-01 02:00:46 [1515] VTUNER_SET_NAME: Sundtek MediaTV Digital Home (USB 2.0)
1970-01-01 02:00:46 [1515] FE_SET_VOLTAGE not supported by DVB-C
1970-01-01 02:00:48 [1506] Using /etc/sundtek.conf for deviceconfiguration
« Antwort #5 am: Mai 07, 2013, 09:13:21 Vormittag »
Possibly your other stick causes the problems, the logfile looks fine.
For further investigation you might contact our support via Skype "sundtek".
"usb 1-1: usbfs: USBDEVFS_CONTROL failed cmd mediasrv rqt 64 rq 2 len 2 ret -71" is usually an indicator that something on the USB Controller side went wrong, even possible that there's a bad USB cable or bad physical connection between the Box and the stick.
dorinineu
« Antwort #6 am: Mai 07, 2013, 11:58:21 Vormittag »
I dont know,I have tried only with sundtek,with and without that small usb adapter that came whit it,I have tried in different box,same result,sometimes after reboot boxes detedt sundtek sometimes dont,sometimes even stock on boot,only after removing sundtek continue booting.But even if box boot and detect sundtek when I swich to cable channel,box freezes and start spiner to round and round.Bot more often bouth my boxes doesent detect sundtek.
« Antwort #7 am: Mai 07, 2013, 12:19:25 Nachmittag »
To me it looks like one of both options:
1. faulty USB port/controller
2. faulty stick.
you might also try to use an active USB hub (with AC adapter) to check if there's something wrong with the usb power supply.
dorinineu
« Antwort #8 am: Mai 07, 2013, 04:21:31 Nachmittag »
Ok but on my both boxes  USB port/controller are faulty?I dont know,but I am very sad becouse until few days ago it worked very good.
« Antwort #9 am: Mai 07, 2013, 04:29:12 Nachmittag »
Well you can check with our support directly. The skype account is "sundtek"
