Autor Thema: recording (analog) tv on synology  (Gelesen 4990 mal)
kobbejager
« am: April 07, 2013, 11:20:05 Nachmittag »
I'm trying to record tv using my MediaTV Pro device connected to my Synology DS212j.  I'm currently trying to record analog tv on the NAS, but it doesn't seem to work.
# export LD_PRELOAD=/opt/lib/libmediaclient.so
# /opt/bin/mediaclient --start
# /opt/bin/mediaclient -e
# /opt/bin/mediaclient -m ATV -f 133250000 -d /dev/video0 -v PAL-BG
Using device: /dev/video0
Tuning in ATV Channel...
Tuning to: PAL-BG, Freq: 133250000
setting standard... done
Checking for (analog) lock:
# cat /dev/video0  > test.mpg
cat: can't open '/dev/video0': No such device or address
# ls -la /dev/video0
crwxrwxrwx    1 root     root       81,   1 Apr  7 22:17 /dev/video0
What am I doing wrong? Has it anything to do with missing ffmpeg plugins (http://sundtek.de/support/buildffmpeg.sh)?  If so, how do I install those on my NAS, since that script needs git (and probably gcc?) to build these plugins?
My next job is to record digital tv (dvb-t and -c) using the command line on the NAS.  Would command would I then need to use?  I suppose I can't use "cat" in that case?  (I want to avoid using tvheadend, since it keeps the TV-stick from sleeping (and it's running quite hot, probably reducing its working life), switching between the modes (analog, dvb-t and -c) requires restarting tvheadend, and I guess tvheadend is quite demanding for my NAS.)
Re:recording (analog) tv on synology
« Antwort #1 am: April 08, 2013, 10:20:34 Vormittag »
You should try tvheadend on Synology.
I don't think that the NAS will be powerful enough for analog TV recording.
When installing tvheadend please note that you have to install the driver after tvheadend.
If you installed the driver first it's no problem, just install it again when tvheadend is installed.
