Autor Thema: Sundtek Media TV v.s Set-top Box User Manual ( Compatible for Windows and Mac)  (Gelesen 41592 mal)
Introduction
Sundtek keeps concentrating on providing the user friendly experience to customers.
With Sundtek Settopbox Installer, you can connect the set-top box and Sundtek MediaTV series easily.
Just process this manual Step by Step.
Procedure
Three parts to complete the settings.
1. Get the IP address of the set-top box
2. Install Sundtek driver to the set-top box via PC/NB
3. Configure Sundtek Tuner on the Set-top Box
Part1. Get the IP address of your set-top box
1. Turn on the set-top box
(P.1)
2. Press "MENU" on Remote control
3. Press "OK" on each step :
Setup→System Settings→Network Setup→ Adapter settings→
(P2 to P5)
4. Get the IP address.( Please note this address)
(P6)
Part2.
Install Sundtek driver to the set-top box via Windows/ Mac PC or NB
1. Download "Sundtek Settopbox Installer" on:
  a.For Windows: http://sundtek.de/media/ssi.rar
  b. For Mac    : http://sundtek.de/media/ssi_mac.zip
(P7)
2. Click SSI.exe to call up "Sundtek Settopbox Installer"
(P8)
3. Enter IP Address / Password and Install
(P9)
4. Installer running and then completed
(P10)
Now Sundtek driver has been installed into the Set-top box.
Part3. Configure Sundtek Tuner on the Set-top Box
1. Plug Sundtek stick in Set-top Box and connect the cable or
   Antenna
3. Press "OK" on each step:
   Setup→Service Searching→Tuner Configuration→
(P11 to P13)
4. Select "Tuner B: Sundtek MediaTV.." ; Make sure it is ‘enabled’
(P14)
5. Press "EXIT" to back to "Service Searching"
6. Press "OK" on Manual Scan→
(P15)
7. a. On Tuner Bar, Press " " to get Tuner B Sundtek MediaTV.
(P16)
 b. Change Frequency to "121"
 c. On Network scan bar, change to "Yes"
(P17)
8. Press "OK" , start to Scan
(P18)
9.  Done ! You made it!!
(P19)
ENJOY!!
This User’s Manual is for specific product, and all its contents are processed with due care but are not ensured fully correct.
We assume no responsibility for any loss arising from use of this manual.
The manual is subject to change without notice. The right to interpret all contents of this User’s Maunal belongs to Sundtek .
