Autor Thema: How to record analog-tv with mencoder?  (Gelesen 36642 mal)
ingo
« am: September 03, 2012, 05:26:37 Nachmittag »
I recently received my Media TV Pro stick and got it work to watch analog TV via cable (Gremany) and FM radio..
First I tried to watch with 'tvtime' but that results in frequently lost frames with short stuttering during playback. 'xawtv' however works fine. I am using the latest driver dd Aug. 20th on Debian-Wheezy-amd64, CPU and graphics card is Ivy-Bridge i5-3570K with Intel HD4000 graphics.
I tried to record using the OSD-menu of 'xawtv', but this results in an error messages and says:
xawtv -c /dev/video0
This is xawtv-3.102, running on Linux/x86_64 (3.2.0-3-amd64)
xinerama 0: 1920x1080+0+0
Alsa devices: cap: (null) (/dev/video0), out: default
v4l2: ioctl(fildes = 5 { sa_family = PF_UNIX } => { sa_family = PF_UNIX, sun_path = "" }, request = VIDIOC_DQBUF, struct v4l2_buffer *data = { index = 0, type = 0, memory = 0 }): success
oss: open /dev/dsp: Datei oder Verzeichnis nicht gefunden
The Sundtek driver however creates /dev/dsp0. I tried to create a symlik 'ln -s dsp0 dsp', but that doesn't work either.
Then I tried to record usig 'mencoder' from the command line:
mencoder -tv norm=PAL-BG:device=/dev/video0:fps=25:buffersize=64:adevice=/dev/dsp0:amode=1:audiorate=48000:input=1 -af format=s16le -ovc lavc -lavcopts vcodec=mjpeg -oac pcm -o test.avi tv://
MEncoder 1.1-4.7 (C) 2000-2012 MPlayer Team
success: format: 9  data: 0x0 - 0x0
TV file format detected.
Selected driver: v4l2
 name: Video 4 Linux 2 input
 Tuner cap: STEREO
 Tuner rxs:
 Capabilities:  video capture  tuner  audio  streaming
 supported norms: 0 = PAL-BG; 1 = PAL-DK; 2 = PAL-I; 3 = PAL-M; 4 = NTSC-M; 5 = Secam-L; 6 = Secam-LC; 7 = Secam-K;
 Current input: 1
 Current format: YUYV
v4l2: current audio mode is : STEREO
unsupported format
Audio block size too low, setting to 16384!
[V] filefmt:9  fourcc:0x32595559  size:640x480  fps:25.000  ftime:=0.0400
Opening audio decoder: [pcm] Uncompressed PCM audio decoder
AUDIO: 48000 Hz, 2 ch, s16le, 1536.0 kbit/100.00% (ratio: 192000->192000)
Selected audio codec: [pcm] afm: pcm (Uncompressed PCM)
libavcodec version 54.23.100 (internal)
Opening video filter: [expand osd=1]
Expand: -1 x -1, -1 ; -1, osd: 1, aspect: 0.000000, round: 1
Opening video filter: [scale]
[swscaler @ 0xf3cc20]using unscaled yuyv422 -> yuv420p special converter
videocodec: libavcodec (640x480 fourcc=47504a4d [MJPG])
[mjpeg @ 0xe73020]Specified pix_fmt is not supported
Could not open codec.
FATAL: Cannot initialize video driver.
VDecoder init failed :(
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
Selected video codec: [ffrawyuy2] vfm: ffmpeg (RAW YUY2)
Forcing audio preload to 0, max pts correction to 0.
Exiting...
I am quite sure the proper codecs are installed, also I can watch smoothly on the screen.
The driver itself reports:
/opt/bin/mediaclient -e
and /var/log/messages says:
cat /var/log/messages | grep -i -A 1 -B3 sundtek
usb 1-1.3: New USB device found, idVendor=eb1a, idProduct=51b2
usb 1-1.3: New USB device strings: Mfr=1, Product=3, SerialNumber=2
usb 1-1.3: Product: MediaTV Pro
usb 1-1.3: Manufacturer: Sundtek
usb 1-1.3: SerialNumber: U120820070038
input: Sundtek Ltd. Remote Control as /devices/virtual/input/input11
Any hints how I can manage to record analog-tv?
With best regards,
Ingo
Re:How to record analog-tv with mencoder?
« Antwort #1 am: September 03, 2012, 07:06:34 Nachmittag »
sudo -s
cd /tmp
wget http://sundtek.de/support/buildffmpeg.sh
chmod 777 buildffmpeg.sh
./buildffmpeg.sh
sudo /opt/bin/mediaclient --start
anschliessend mittels tvtime den Sender auswählen
cat /dev/video1 > /tmp/test.mpg
ingo
« Antwort #2 am: September 03, 2012, 08:04:43 Nachmittag »
Zunächst Danke für die schnelle Antwort!
Leider funktioniert der Build nicht:
HEAD is now at cfd64ee... Merge remote-tracking branch 'qatar/master'
+ ./configure --disable-filters --disable-devices --disable-encoders --disable-decoders --disable-muxers --disable-demuxers --enable-shared --enable-pthreads --enable-libmp3lame --enable-encoder=mpeg2video,libmp3lame,mp2 --prefix=/opt/bin/plugins --enable-nonfree --disable-bsfs --disable-protocols --disable-parsers --enable-muxer=mpegts,mpeg2video,mpeg2dvd
ERROR: libmp3lame >= 3.98.3 not found
If you think configure made a mistake, make sure you are using the latest
version from Git.  If the latest version fails, report the problem to the
ffmpeg-user@ffmpeg.org mailing list or IRC #ffmpeg on irc.freenode.net.
Include the log file "config.log" produced by configure as this will help
solving the problem.
+ [ 1 != 0 ]
+ echo failed to configure ffmpeg
+ make
Makefile:2: config.mak: Datei oder Verzeichnis nicht gefunden
Makefile:45: /common.mak: Datei oder Verzeichnis nicht gefunden
Makefile:85: /libavutil/Makefile: Datei oder Verzeichnis nicht gefunden
Makefile:85: /library.mak: Datei oder Verzeichnis nicht gefunden
Makefile:162: /doc/Makefile: Datei oder Verzeichnis nicht gefunden
Makefile:163: /tests/Makefile: Datei oder Verzeichnis nicht gefunden
make: *** Keine Regel, um »/tests/Makefile« zu erstellen.  Schluss.
+ [ 2 != 0 ]
+ echo failed to build ffmpeg
+ make install
+ [ 2 != 0 ]
+ echo failed to install ffmpeg
Zur Info: 'yasm' mußte ich nachinstallieren. Die Fehlermeldung
bekomme ich aber nicht weg, obwohl ich den SymLink auf libmp3lame.so.0.0.0 manuell angelegt habe (per default ist nur der Link zu libmp3lame.so.0 vorhanden. Problem ist wohl, daß der interne Paketname "libmp3lame0" ist ?
/usr/lib/x86_64-linux-gnu# ls -l libmp3*
lrwxrwxrwx 1 root root     19 Sep  3 19:39 libmp3lame.so -> libmp3lame.so.0.0.0
lrwxrwxrwx 1 root root     19 Mai  1 15:26 libmp3lame.so.0 -> libmp3lame.so.0.0.0
-rw-r--r-- 1 root root 298536 Mai  1 15:26 libmp3lame.so.0.0.0
und die installierte Version ist:
dpkg -l libmp3lame0
Gewünscht=Unbekannt/Installieren/R=Entfernen/P=Vollständig Löschen/Halten
| Status=Nicht/Installiert/Config/U=Entpackt/halb konFiguriert/
         Halb installiert/Trigger erWartet/Trigger anhängig
|/ Fehler?=(kein)/R=Neuinstallation notwendig (Status, Fehler: GROSS=schlecht)
||/ Name               Version        Architektur    Beschreibung
ii  libmp3lame0:amd64  1:3.99.5-dmo1  amd64          LAME Ain't an MP3 Encoder (shared library)
What to do?
Ach ja,
Danke für die Info, daß der Output von /dev/videoX im mpeg-Format ist und ein einfaches cat ... ausreicht!
Beste Grüße,
Ingo
ingo
« Antwort #3 am: September 03, 2012, 08:28:05 Nachmittag »
Noch eine Info - hatte ich vergessen:
ii  ffmpeg         7:0.11.1-dmo amd64
Es ist die Version von deb.multimedia für Wheezy.
Ingo
« Antwort #4 am: September 03, 2012, 08:56:43 Nachmittag »
apt-get install libmp3lame-dev
Anschließend nocheinmal das Script ausführen. Die Aufnahme mit dem Treiber wurde soweit über Stunden hinweg synchron getestet.
ingo
« Antwort #5 am: September 03, 2012, 09:20:08 Nachmittag »
1000 Dank!
Alles geht, tvtime ruckelt nicht mehr und /dev/video0 liefert jetzt auch einen mpeg-Stream.
Ingo
P.S.: Woran hat's denn nun letztendlich gefehlt?
ingo
« Antwort #6 am: September 03, 2012, 11:11:01 Nachmittag »
Vielleicht kann ich mich mit dieser Info noch für den super Service bedanken. Der entscheidende Tipp war die Zeile zur Aufnahme des MPEG-Streans:
Da habe doch glatt mein geliebtes TV-Record von Christian Rapp (ist original für Hauppauge PVR-Karten gedacht) installiert. Quelle: http://sourceforge.net/projects/tv-viewer/.
Und siehe da, es klappt einwandfrei. Das Beste dabei: es enthält einen sehr komfortablen Recorder, der zeitgesteuert aufnehmen kann, auch über Reboots hinweg. Habe das gute Stück mit meiner alten PVR150 jahrelang benutzt - einfach praktisch.
Daß man wegen der Herkunft auch die 'ivtv-utils' mit > 50MB installieren mus, kann man sicher ändern. Ich werde die Info auch bei IVTV bekannt machen, ist der ideale analog TV-Recorder und Viewer für uns in Germania.
Beste Grüße,
Ingo
« Antwort #7 am: September 03, 2012, 11:14:24 Nachmittag »
Danke für die Information, der Treiber hat eine IVTV Emulationsschicht die das MPEG-2 ausgibt. Mit dem Skript hast du ffmpeg als Plugin für den Treiber erstellt. Durch das Plugin kommt dann die zusätzliche Funktionalität.
Einige Firmenkunden verwenden dies zum streamen, Du bist wohl der erste Endkunde der damit etwas anfangen kann :-)
« Letzte Änderung: September 03, 2012, 11:16:47 Nachmittag von Sundtek »
ingo
« Antwort #8 am: September 05, 2012, 08:38:39 Nachmittag »
Noch eine Frage zu meiner Kombination mit TV-Viewer:
Fernsehen schauen geht perfekt! Nur Recording und die Nutzung von Timeshift benötigt einen Trick:
Ich sag's mal salopp: "man muß /dev/video0 busy halten", sonst wird nur eine 0 Byte-Datei aufgezeichnet.
Mein Würgeround: bevor man aufzeichnet bzw. Timeshift aktiviert, einfach im Terminal
cat /dev/video0 > /dev/nullstarten und während der ganzen Zeit laufen lassen. Dann funktioniert alles bestens. Wo müßte man da anfangen zu suchen, woran das liegt? (habe inzwischen mit der stable 0.8.1.1 und der Beta 0.8.2b1 getestet).
Beste Grüße,
Ingo
« Antwort #9 am: September 05, 2012, 09:21:49 Nachmittag »
Wir sehen es uns morgen kurz mal an.
ingo
« Antwort #10 am: September 06, 2012, 09:44:12 Vormittag »
Danke, zur Info: Dokumentation, Installation, ... findet sich hier: http://tv-viewer.sourceforge.net/mediawiki/index.php/Documentation:dev:installation.
Hinweis: die 64-bit Version von Tcl/TK 8.5 in Debian-Squeeze (und Ubuntu-Lucid) hat einen bekannten Bug und geht dehalb nicht korrekt. Da sollte man Tcl/Tk von ActiveState verwenden. In Wheezy ist alles ok.
« Letzte Änderung: September 06, 2012, 10:03:34 Vormittag von ingo »
ingo
« Antwort #11 am: September 09, 2012, 10:35:12 Nachmittag »
Ich habe inzwischen auch die ganz aktuelle Version von Christian aus dem trunk getestet:
http://tv-viewer.sourceforge.net/mediawiki/index.php/Development_Bazaar
Es ist die 0.8.2b2 und damit fast die finale 0.8.2. Leider ist das Problem das gleiche.
Meine Vermutung: der Stick liefert seinen Stream nicht auf /dev/videoX, wenn man nicht aktiv "daraus saugt", sondern nur "mitschneidet, was dort herauskommt". Mit den PVR-Karten und Hardware-Encoder geht tv-viewer dagegen problemlos.
Sorry, wenn das sehr laienhaft ausgedrückt ist, aber mit programmieren kenne ich mich praktisch nicht aus. Leider hat Christian im Moment wenig Zeit für die Fertigstellung der "final 0.8.2", Bug-Reports sind aber noch willkommen. Er wird wohl den MediaStick Pro in die Liste der unterstützten Geräte aufnehmen.
Beste Grüße,
Ingo
« Letzte Änderung: September 09, 2012, 11:06:19 Nachmittag von ingo »
ingo
« Antwort #12 am: September 28, 2012, 06:14:58 Nachmittag »
So, ich habe jetzt nochmal auf komplett anderer Hardware gegengecheckt:
aktueller PC:
Intel DH77EB mit H77-Chipsatz un Ivy-Bridge CPU an einem USB2.0-Port des MB, BS: Debian-Wheezy, aktuell 64-bit.
"alter" PC:
ASUS M2N-E mit nForce 570-Ultra Chipsatz und Athlon64-X2 an einem USB-Port des MB, BS: Debian-Squeeze-amd64. Zusätzlich hat dieser PC noch PCI-Slots und in einem einer Happauge PVR150, die einwandfrei mit beiden Vesionen des TV-Viewer (0.8.1.1 und 0.8.2b2) funktioniert.
Auf beiden PC's habe ich das oben beschiebene Phänomen mit dem MediaTV Pro , das analoges TV-sehen einwandfrei geht, aber bei Recording der Stream aus /dev/videoX nur eine Datei mit 0 Bytes Größe liefert. Auch der "Workaround", vor der geplanten Aufnahme ein "cat /dev/videoX > /dev/null" zu starten, hilft in beiden Fällen und liefert ein MPEG2-Video.
Noch eine Frage: gibt es eine Möglichkeit, die Bitrate bzw. Qualität der Codierung für diesen Weg/das Plugin einzusetllen? Gibt es inzwischen was Neues bei Sundtek zu dieser Sache?
Beste Grüße,
Ingo
« Antwort #13 am: Oktober 02, 2012, 09:43:15 Nachmittag »
Es wird aktuell noch am nächsten Update gearbeitet, sobald das abgeschlossen ist kann dieser Bereich auch feingetuned werden (hoffentlich noch diese Woche).
« Antwort #14 am: Oktober 06, 2012, 10:50:31 Nachmittag »
Das Problem bezüglich tv-viewer ist klar, wir haben soweit einen Workaround für diese Applikation hinzugefügt. Es handelt sich bei unserem Tuner um einen Tuner der Rohdaten zur Verfügung stellt ohne explizite Konfiguration weiß der Treiber nicht das die Applikation IVTV Daten erhalten möchte.
Mit dem kommendem Update klappt auch die Aufnahme mittels tv-viewer.
« Letzte Änderung: Oktober 07, 2012, 02:30:11 Nachmittag von Sundtek »
